max rpm? - Cherokee SRT8 Forum
post #1 of 7 (permalink) Old 09-13-2006, 04:52 AM Thread Starter
max rpm?
Is it possible to pull the max rpm an engine has seen from the computer? If so, is it possible to reset this?
What I would like is a way to check and see what the max my engine has seen when I recieve it and be able to reset and check this again in the future.
basicly like a tach with memory but without having to actually add one.
jaybruce is offline
post #2 of 7 (permalink) Old 09-17-2006, 02:55 PM
Re: max rpm?
to my knowledge, you cant!
sorry
srt8suv is offline
post #3 of 7 (permalink) Old 09-17-2006, 09:53 PM
Re: max rpm?
When it hits fuel cut-off, it's at 6000. Why would you want more data? There's a mod to raise the fuel cut-off to 6800, which I think, is a blessing. Too bad it acts weird when you overrrev (shutting down the engine, or something ridiculous like that). Current setup just sits there at 6000, providing fuel just enough to keep it at 6K, until you shift (if in manual mode). For best results, at WOT, keep it in auto.
GINTER is offline
post #4 of 7 (permalink) Old 09-18-2006, 06:08 AM Thread Starter
Re: max rpm?
To see if some nut job at a port took a little joy ride while loading/unloading my truck for delivery. I want to follow a very specific break-in and just wanted a way to check that it hasn't already 'violated' before I recieve it.
jaybruce is offline
post #5 of 7 (permalink) Old 09-18-2006, 06:49 AM
Send a message via AIM to radduc
Re: max rpm?
I think you might be a bit anal or paranoid
radduc is offline
post #6 of 7 (permalink) Old 09-18-2006, 07:58 AM Thread Starter
Re: max rpm?
LOL!!
quite possibly!!
jaybruce is offline
post #7 of 7 (permalink) Old 09-19-2006, 03:21 PM
Re: max rpm?
mind you. but i feel the car is faster when you are in the Manual mode.. just make sure to shift at the point befor the car gets into the red line and then ..boom
i had to do so many tests to make it, and now.. wow i can shift like auto with no single drop of power.. try it
srt8suv is offline
RPM limit at 3800?? larryc7777 WK1 SRT8 General Discussion 4 09-08-2006 07:07 AM
Break-in Procedures AaronC WK1 SRT8 General Discussion 2 08-05-2006 07:03 AM
What is the Max HP the 4wd Converter is Designed to Handle? SRT8 MAFIA WK1 General Performance Discussion 1 03-20-2006 04:08 PM
