Motor swap! - Cherokee SRT8 Forum
post #1 of 14 (permalink) Old 01-29-2013, 08:39 AM Thread Starter
Motor swap!
I've been waiting to Do it for a while now...I have a 426 from HHP that's been sitting in my garage for months now. Prob goin to do it at the end feb but have a few questions....can the motor and trans be pulled out the top at the same time? Is it easier to leave the trans in and just pull the motor? Can AR LT Headers stay attached for the pull or do
They need to come off??? If the trans can some out at
The same time can the transfer case come
With it? This will be some in my garage with a cherry picker and some
Jack stands So any advice/tips would
Help
Sent from my iPhone using AG Free
-2006 Grand Cherokee SRT8 426, -V-3 SI Trim, ATI 17% OD, 30t pulley, AR Long Tube Headers, Gibson Exhaust, Custom Tips, 180 T-Stat, Catch Can, LC-1, Custom Tune
-IN THE WORKS meth injection
-05 RAM SRT 10 QC - 10000k HID head/fog lights, JMB Catless w/Maggie Cat Back, Ported Throttle Body, Caltracs, Rear Bushings, Suncoast Valve Body w/GM solenoid/TransGo Shift kit,170 T-stat, SCT Tuned By Torrie, B&B Headers, Cutouts, 2400 Stall, built tranny, Justin's E-Fan, Hard Radiator Pipes.
sparksftball69 is offline
post #2 of 14 (permalink) Old 01-29-2013, 08:48 AM
SRT8 & LT1's Avatar
Sounds awesome with the swap you're doing. I wish I could lend a hand as I love working on cars and getting my hands all dirty and banged up. I'm not an expert in the swap area so I'll leave it to the pro's. Good luck with your swap/build. God bless
SRT8 & LT1 is offline
post #3 of 14 (permalink) Old 01-29-2013, 10:10 AM
ekaz's Avatar
It would be very tricky to take all that out as one unit. I would take the transfer case off. I can't recall right now, but don't think it will come out with the headers attached, it'd be close.
Those ARH headers are a PITA, especially the driver side.
Good luck.
I'm BAAAAAAAACK....
2015 Billet Silver
past:
2012 300SRT
2009 Jeep SRT
2006 Charger SRT
ekaz is offline
post #4 of 14 (permalink) Old 01-29-2013, 11:19 AM
Premium Reformed Member
tugboatchad's Avatar
Motor swap!
If you knew someone with a lift you could drop the tray and pull it all really really easy.
Just like in the pics. My body shop had the tray out in the pics like you see it in less than 1.5 hrs.
Sent from AutoGuide.com App
tugboatchad is offline
post #5 of 14 (permalink) Old 01-29-2013, 11:26 AM
Premium Whore (Lifetime)
StangSlayerMA's Avatar
Transmission, and transfer case have to be disconnected, and removed from below. It will be much easier to unbolt things with the tranny out of the way. The headers should be unbolted and removed from below once you lift the engine slightly....they will not clear the fire wall. The only other thing we had to remove for the engine to come out, was the passenger side valve cover.
StangSlayerMA is offline
post #6 of 14 (permalink) Old 01-29-2013, 11:45 AM
Motor swap!
You swapping engines?
post #7 of 14 (permalink) Old 01-29-2013, 01:17 PM
No, I pulled my engine for a 426 about a year and a half ago, and there was an issue with the new engine.....so it got sent back and I bought the Procharger.
The Following User Says Thank You to StangSlayerMA For This Useful Post:
tugboatchad (02-01-2013)
post #8 of 14 (permalink) Old 01-29-2013, 01:17 PM
If it takes 1.5 hours to drop the cradle, why is anyone paying ridiculous labor on header installs? Looks like you could have a cam and headers installed in a day that way.
Probably remove the AC pump with the body... then you don't have to recharge...
Jack_Toepfer is offline
post #9 of 14 (permalink) Old 02-01-2013, 12:34 PM
jptaylor2's Avatar
Attachment 26971
Attachment 26972
picture is worth a 1000 words....had never thought about this with our Jeeps but i dont know why not, ive done it on camaros and firebirds for YEARS....bout the same time as well, only difference would be front driveshaft coming loose as front diff drops with subframe
***Charred***
2008 SRT8*Silver*CAI*Flowmaster*180 tstat*Catch Can*Comp Cams 273*8000k HIDs HI/LOW/FOG*all LED interior*Custom audio*ToonaTooned!!! Paramount Trans!!!
jptaylor2 is offline
post #10 of 14 (permalink) Old 02-01-2013, 12:59 PM
Motor swap!
Before I had my buddy committed to build and install my new engine I planned to buy a block from HHP and install it ourselves. The auto body shop that repaired it told me they would drop the tray on a Saturday, let us swap the block and reinstall the tray for $200 and then we could load it on a car trailer and take it back to my house to finish the install.
I think it would be a great way to do headers, heads, and cam too!
The Following User Says Thank You to tugboatchad For This Useful Post:
Jack_Toepfer (02-01-2013)
6.4l swap for a 06 to 10 SRT HOUSE8 Member Assistance 11 01-28-2013 09:27 AM
07 grand cherokee eagle 5.7 motor swap lehr69 Other Chrysler/Dodge/Jeep/Fiat Vehicle Discussion 1 04-06-2012 12:52 AM
Who here has done their own cam swap? HoustonHemi WK1 SRT8 General Discussion 88 11-20-2011 10:44 PM
Cam Swap Help !!! Can I Do It ?? 1_big_fan WK1 Engine Performance/Superchargers/Turbos/Nitrous 10 03-29-2010 05:23 PM
