The.... "I have a dumb WK1 question" thread. - Page 5 - Cherokee SRT8 Forum
 119Likes
post #41 of 1661 (permalink) Old 01-16-2013, 01:29 PM
kmitch80's Avatar
if you havent had an alignment done recently, get one done
PWR 426
kmitch80 is offline
post #42 of 1661 (permalink) Old 01-16-2013, 01:36 PM
MaasSRT8's Avatar
Originally Posted by kmitch80 View Post
how many miles? check your brakes and wheels as well as wheel hub.
53,000 miles. I am due for new rotors. I just got it in September and they told me it just got new brakes. Unfortunately, long story short, my wife and I arrived at the dealership later than planned, about 30 min before closing time. It was also about 3.5 hours away. So it was dark and didn't notice the grooved rotors. So what he meant to say was that they did a pad slap on the old rotors. The tires we definitely new. I got a quote from Steven at R1 Concepts last week on rotors/pads. Potential warped rotor? Just strange that it only happens at exactly 85 :-\
Thanks so much for the help and input guys. I seriously am addicted to this forum. You guys are awesome.
MaasSRT8 is offline
post #43 of 1661 (permalink) Old 01-16-2013, 01:46 PM Thread Starter
Originally Posted by Untouchable View Post
1.how much over ambient temp is acceptable for a charge temp when making a high boost pass at the track?
2.what are the possible pitfalls/dangers of a high charge temp?
3. what can one do to avoid high charge temps or at least keep them best controlled?
1. The main issue with air to air intercoolers is heat soak before getting to the line. Mine can be anywhere from 10 to 30* over ambient when getting to the line. During the run, my temps either stay the same or drop about 4-6* once I let off the throttle. Having an inefficient intercooler like BBill used to have and Mike Smith's Blue Bee used to have would say start a run at 80* and end at 180* at the end of the run. BBills would raise 100* in 9 seconds.l with his old setup. Now, it stays the same or drops a few or raises 2-4* depending on the weather. Obviously a hot day it would rise a few clicks. Cooler and cold days it will drop.
2. Dangers and pitfalls would be getting a lot of detonation. Cooler air always makes more power.
3. Best thing you can do is use a quality intercooler core and make sure it will support the HP you're making at nominal flow. My intercooler and Bills intercooler is rated at 1225hp nominal. Meaning its constantly seeing 1225hp and peak will be much higher. Make sure the core has very little pressure drop. You don't want 12psi going in and 9psi coming out. Lol. Also, try keeping the engine off as much as possible in the staging lanes and try to keep air moving through the intercooler. Having an inside fan switch helps. Try to get some sort of air moving through the fins.
Hope that helps Doc.
2007 Jeep GCSRT Turbo 8.30@167
2015 Hellcat Charger 770rwhp no times yet
Harrison@Stage6 is offline
post #44 of 1661 (permalink) Old 01-16-2013, 02:52 PM
petersrt8's Avatar
So i guess a $99.00 E-BAY intercooler is def holding me back. I know Dwight and Shrek can install one for me at Darlington in about 1 hour.
Built by the HEMI-SHOP:Arrington 426,Tuned by AJ,TT-Creations/Hellbent and Builder Bill Driveline.
8.95@ 155 Bam
petersrt8 is offline
post #45 of 1661 (permalink) Old 01-16-2013, 03:14 PM
Untouchable's Avatar
Maybe you would have already had that 8-second pass lol
Guess the Jeep gods/devils want you to hang around just a little longer
8.90@157.59
Untouchable is offline
The Following User Says Thank You to Untouchable For This Useful Post:
petersrt8 (01-16-2013)
post #46 of 1661 (permalink) Old 01-16-2013, 04:09 PM Thread Starter
What do y'all's IAT's do during a run?
post #47 of 1661 (permalink) Old 01-16-2013, 04:10 PM Thread Starter
I wish Pete. There's a bit of cutting to do to fit our "Monster" intercooler in there.
post #48 of 1661 (permalink) Old 01-16-2013, 04:32 PM
nyjoed's Avatar
Harrison can I use one of those monster interoolers for my sc or would it be more of a negative I untill I'm running more boost?? Ill only be running about 7-8 lbs for now.
72mm FOGLIGHT TWIN TURBO
nyjoed is offline
post #49 of 1661 (permalink) Old 01-16-2013, 04:32 PM
On my logged 9.86 pass temp outside was 50. ambient was 68. After 1/2 shift it was 80. By 3/4 shift it was 120ish and almost 130 by 1/4.
post #50 of 1661 (permalink) Old 01-16-2013, 04:56 PM
Blown-WK's Avatar
Never seen mine more than 20* above ambient.
-CHRIS-
10.61 @ 129
Blown-WK is offline
Here's a dumb question!!! Grizz WK1 Troubleshooting / Problems Discussion / Dealer Service 3 01-25-2011 06:43 PM
Is this a dumb question? nyjoed WK1 Suspension / Driveline Discussion 11 06-03-2010 08:46 PM
A REALLY dumb question..... Harrison@Stage6 WK1 SRT8 General Discussion 10 01-06-2010 08:28 AM
got a really dumb question NorCaliSRT8 Off-Topic Discussion 18 04-15-2009 01:08 PM
Dumb Question TeaPz WK1 Troubleshooting / Problems Discussion / Dealer Service 1 04-12-2008 06:59 AM
