quick oil question - Cherokee SRT8 Forum
post #1 of 14 (permalink) Old 01-10-2013, 05:14 PM Thread Starter
Btelander's Avatar
quick oil question
I had my forged motor installed 4 months ago and I have driven 2k miles since. I have now had to add my 3rd quart of mobile 1. I understand thats it normal to have to add more oil after a rebuild but is 3 quarts normal in 2k miles?
2015 WHITE JEEP OVERLAND
2008 BLACK ESCALADE EXT
Brian
Btelander is offline
post #2 of 14 (permalink) Old 01-10-2013, 06:16 PM
Premium Whore (Lifetime)
StangSlayerMA's Avatar
I don't think you're suppossed to use synthetic oil during the break-in period. When I had ordered a PWR 426, Andy told me to use traditional oil for the first 3000-5000 miles.....then switch to synthetic.
StangSlayerMA is offline
The Following User Says Thank You to StangSlayerMA For This Useful Post:
BJB (01-10-2013)
post #3 of 14 (permalink) Old 01-10-2013, 06:25 PM
cmn1's Avatar
I went through a lot of oil myself. I am almost to 3300 miles on mine and the missing oil has greatly subsided
Andy told me the same thing. Break in oil for 300 miles and then 3000 miles on regular oil and then whatever you want afterward.
cmn1 is offline
The Following User Says Thank You to cmn1 For This Useful Post:
Knuckles (01-10-2013)
post #4 of 14 (permalink) Old 01-11-2013, 07:03 PM
1st. You should not use Mobil1 to break in the motor, use a light weight detergent oil otherwise the rings won't seat properly and you will get blow by. 2nd. Loose fit engines will use oil, remember this and always keep an eye on the Oil. Check for leaks, have the Vehicle put on a lift and check for leaks with the motor running. Why did you Forge the motor are you going to Supercharge it?
Jack
dodgeboy16 is offline
post #5 of 14 (permalink) Old 01-11-2013, 07:40 PM Thread Starter
Btelander's Avatar
Jack
Yep, im supercharged. Blew my first motor. Josh at hhp never mentioned any of this. Also, I had an hhp dealer in minn install the reinstall the blower and motor.
post #6 of 14 (permalink) Old 01-11-2013, 08:06 PM Thread Starter
Btelander's Avatar
I just did some brief reading on blow by. I really hope this is not the case. I even told josh that the engine installer added 0-40 mobile and he didnt say anything. I guess ill have to talk to him on moday. What are some warning signs? Will he be able to tell in a log? let me remind you that im in des moines iowa 4 hours from where my engine was installed.
post #7 of 14 (permalink) Old 01-11-2013, 08:42 PM
cmn1's Avatar
I don't even use 0-40 any more. My motor uses 10w30. So you may want to check
cmn1 is offline
post #8 of 14 (permalink) Old 01-11-2013, 08:47 PM Thread Starter
Btelander's Avatar
are u running full sythetic?
post #9 of 14 (permalink) Old 01-11-2013, 08:50 PM
cmn1's Avatar
are u running full synthetic?
Not yet. Have 200 more miles to go till I hit my 3300. Real close though and then I will be running synthetic. Going to be sending a sample to Blackstone to see how the motor is wearing.
cmn1 is offline
post #10 of 14 (permalink) Old 01-14-2013, 08:56 AM Thread Starter
Btelander's Avatar
Update-if anyone cares. Spoke to the installed and he ran 10-30 on the dyno. Changed the oil to Mobile 1 0-40.
Does this sound ok?
quick question!! dashti01 Off-Topic Discussion 0 09-30-2012 08:57 PM
quick question please help Hussain90 WK1 General Performance Discussion 6 08-29-2011 01:01 AM
Quick Question..... urntfstenuf WK1 Suspension / Driveline Discussion 0 03-12-2011 01:01 PM
quick question?? SRT8-DOUGLAS JR WK1 Audio/Video/Nav/UConnect/Electronics 3 11-04-2010 05:13 PM
quick question srt4me WK1 SRT8 General Discussion 3 07-08-2008 08:01 PM
