Anybody in the Northwest Indiana region - Cherokee SRT8 Forum
post #1 of 7 (permalink) Old 12-28-2012, 04:04 PM Thread Starter
Looking for member in the Northwest Indiana region. Need help with an issue and I like to try a new set of tires before I by some. My name is John and I live in Crown Point. If anyones lives near my location and may be willing to help let me know.
Thanks
John
Black JGC SRT-8 is offline
post #2 of 7 (permalink) Old 12-30-2012, 06:01 PM
Rufjatt's Avatar
Send a message via Yahoo to Rufjatt
What type of issue are u having?
2010... 393 PWR/ F1D Procharger/ PWR cam/ Mean street heads/ Ported intake to 90mm TB/ ARH/ Torque Converter/ Cutouts/ BB trans/ F&R Wavetrac/ BC Coils/ BB TCM/ Challengerhood/ Borla S/ 180tstat/ BT goodies/ Vreds/ R1 breaks/ Passport 9500ci.......BLOODIED
Rufjatt is offline
post #3 of 7 (permalink) Old 01-02-2013, 08:32 AM Thread Starter
I am experiencing a small vibration and grinding sound that seems like it comes from underneath my seat. It only happens for a few seconds when I barely give it a little bit of gas goes away after a couple 100 rpms. At WOT or enough throttle to create a down shift it does not occur or crusing or coasting on happens at very ltille trottle. Based on that I would assume its the transfer case. I took it in to my mechanic that specializes in transmissions and he examined it. He checked underneath and all driveshafts and componets are tight. The transfer case oil looked brand new and was filled properly. The only thing he came up with besides having to rebuild the transfer case was to try a new set of tires. He said he had an AWD ford explorer with a similar issue and it was becasue the front tires were different in diameter then the back due to normal wear. He had this circumference gauge he used on my tires with me obseriving and my passenger rear was the smallest out of the 4 and my drivers front was the largest of all 4. The total difference was 1/2" in circumference. He is betting that this is the problem. I would just like to try a set of tires off of someones jeep that does not have this issue and go around the block and see if this eliminates the issue. If it does then I will just purchase some rear tires, if not then I know I need to have th t/c fixed.
post #4 of 7 (permalink) Old 01-02-2013, 09:37 AM
Rufjatt's Avatar
are you running the stock goodyears?
Rufjatt is offline
post #5 of 7 (permalink) Old 01-02-2013, 09:43 AM
Rufjatt's Avatar
If i get my jeep in the next couple weeks. ill swing by there and u can try my tires and see if it solves the problem.
Rufjatt is offline
post #6 of 7 (permalink) Old 01-02-2013, 10:06 AM Thread Starter
No the stock crapyears are gone, changed to the nitto 420s with the same stock staggered sizes. 255/45 front 285/40 rear
post #7 of 7 (permalink) Old 01-02-2013, 10:21 AM
Btelander's Avatar
I ran nitto 420's 255/45 front 285/40 rear on both of my Jeep srt's. Never had a issue. Good Luck!
2015 WHITE JEEP OVERLAND
2008 BLACK ESCALADE EXT
Brian
Btelander is offline
Pac Northwest Sightings Mortivere Northwest / Pacific Northwest 275 08-31-2015 10:29 PM
Message to members in a Region ? Finchie Member Assistance 5 04-30-2012 03:58 PM
New guy from Northwest CT carscrash83 New Member Introductions 3 03-08-2012 07:32 AM
Northwest Indiana noob jmkiesz New Member Introductions 6 02-11-2011 11:13 PM
changed the region of the car ghost srt8 WK1 SRT8 General Discussion 38 02-05-2008 02:40 PM
