Hurst releases paddle shifter... - Page 2 - Cherokee SRT8 Forum
post #11 of 13 (permalink) Old 01-28-2013, 08:07 PM
One, two, GIT SUM!!
gitrdun's Avatar
I just posted up about wiring something strait into the esm wiring harness, since all it is, is a contact, it's just a modulating switch, one for up shift, and one for down shift. So if you could manually wire into a switch and remove the nickle contactor ( to take care of the codes that I'm sure will pop up) all you are doing is moving the switch in the esm from down there to your steering column..
gitrdun is offline
post #12 of 13 (permalink) Old 01-28-2013, 11:19 PM
SRT-MANA's Avatar
Send a message via AIM to SRT-MANA
Re: Hurst releases paddle shifter...
TCI had a kit out for a while..I see your point...I was woundering why no one figured out why the tci kit wouldnt work..Im thinking the price is a big factor..that Hurst kit is alot cheaper..might be worth a try.
Sent from my SAMSUNG-SGH-I997 using AutoGuide.Com Free
SRT-MANA is offline
post #13 of 13 (permalink) Old 01-29-2013, 10:10 AM
One, two, GIT SUM!!
gitrdun's Avatar
Even a cheapo kit would work, as long as it has a switch in it, doesn't have to be a certain make it just can't be a digital switch. If someone had a spare esm and a harness I'd try it on my jeep..
gitrdun is offline
paddle shifter question bkarotkin WK2 SRT8 Troubleshooting / Problems Discussion / Dealer Service 18 03-04-2012 02:29 PM
Hurst Shifter DELTAWILL WK1 Interior/Exterior Visual Modifications 1 12-20-2011 11:09 AM
Paddle Shifter 07Beast WK1 General Performance Discussion 24 01-17-2011 08:46 PM
Hurst shifter! CHUCKTOWNSRT8 WK1 Interior/Exterior Visual Modifications 66 02-04-2010 10:23 AM
Hurst Shifter FDNY-L107 WK1 General Performance Discussion 11 07-07-2008 03:34 PM
