So... when did the WK1 switch to a limited slip differential?? - Cherokee SRT8 Forum
post #1 of 24 (permalink) Old 12-05-2012, 03:55 PM Thread Starter
srt8gofast's Avatar
In an effort to collect some data points for arguing with the Dealer about putting Limited Slip Additive in the differentials unnecessarily, I called the SRT Consumer Assistance line.
After tons of fumbling around trying to answer the question on their end, they ultimately indicated that my 2010 WK1 indeed has a limited slip diff and would need the LSA fluid put in. (insert foot in mouth)
I've read lots of postings here and on wkjeeps that we do not need it in there. Does anybody know what model year this changed? Is that right!?!
2010 BLACK Jeep SRT/8/
All Option Groups | Mopar CAI | JET 180 Tstat | Trinity | Johan Toon | BT Catch Can | BT Underhood Kit and TB cover | R1 D/S + StopTech pads | Toyo Proxes STII 275/315
srt8gofast is offline
post #2 of 24 (permalink) Old 12-05-2012, 04:04 PM
AROD's Avatar
All models, all axles:
Mopar® SAE 75W-140 Synthetic (API-GL5)
Mopar p/n 04874469 (MSRP $30.00 per quart)
Mopar p/n 68003055AB (bulk, 16 gallon barrel)
Electronic axle notes:
Electronic (ELSD) axles require 118 ml (4 ounces) of Limited Slip Additive be added to the lubricant. (Mopar additive p/n 04318060AB $7.67 MSRP 4 oz. bottle)
ELSD axles are standard with Quadra-Drive II. SRT8 axles DO NOT require Limited Slip Additive.
rear diff - dealer put in limited slip additive??
I had my front/rear differential fluid changed today..
AROD is offline
The Following User Says Thank You to AROD For This Useful Post:
Muellge  (12-05-2012)
post #3 of 24 (permalink) Old 12-05-2012, 04:24 PM
DemonPerformance's Avatar
You have a stock lsd? Lol them guys...
Skip » Demon Performance
1-888-312-3666
DemonPerformance is offline
The Following User Says Thank You to DemonPerformance For This Useful Post:
yaccster (12-05-2012)
post #4 of 24 (permalink) Old 12-05-2012, 04:43 PM
nyjoed's Avatar
dumbasses..
72mm FOGLIGHT TWIN TURBO
nyjoed is offline
post #5 of 24 (permalink) Old 12-05-2012, 04:45 PM
nyjoed's Avatar
thats why i do all that i can on my own. the dealers are selling vehicles they cant even maintain correctly!! what a joke they are. only dealer i would truxt is one that does performance work like a hemishop
nyjoed is offline
post #6 of 24 (permalink) Old 12-05-2012, 04:47 PM Thread Starter
srt8gofast's Avatar
That's what's fascinating.... From the SRT Team!?!
Granted the "Quick Reference Guide" the dealer uses (I was give a print out, and its VIN based) is not clear on if it should be added or not. There's two rows listed, one with footnote to use LSA and one without the footnote. So I can see where somebody could have a question and lean toward adding it in. Good news it doesn't look like it hurts anything, but it was in the price and the job wasn't done "right".
Still baffling that the SRT Assistance line says otherwise?!?!
post #7 of 24 (permalink) Old 12-05-2012, 04:56 PM
Send a message via AIM to HUNTZ_PP
brining my truck to hemi shop at 50k to have every fluid done.
NY_PP
HUNTZ_PP is offline
post #8 of 24 (permalink) Old 12-05-2012, 05:05 PM
BWSRT-8's Avatar
Find a trusted INDY if you don't want to do it yourself. You will end up with tranny/TC problems 5,000mi down the road. You will become infuriated with the same peope that are, pretty much, telling you they don't know how to service your vehicle. Listen to your forums members, as they can save you a lot of pain and $$$. Hope you get everything taken care of.
BWSRT-8 is offline
post #9 of 24 (permalink) Old 12-05-2012, 05:43 PM
nyjoed's Avatar
the fluids are really really easy to do if you have a jack jackstands and some wrnches. the tricky one is the transfer case wich is still simple just gotta get the fill right.. NO ADDITIVES!!!!
nyjoed is offline
post #10 of 24 (permalink) Old 12-05-2012, 05:52 PM Thread Starter
srt8gofast's Avatar
Thanks everybody.
Would go DIY, but wanted the serviced registered with the dealer as I'm still in the drive train warranty. The job looks to be very straight forward. I haven't tracked down a 14mm hex yet. I picked up the 10mm hex at Sears HW, but they didn't have the 14mm. Need to check an auto parts store I guess.
SRT8 Dana 44 Rear Axle/ Viper Limited Slip Modification Blown7 WK1 General Performance Discussion 36 09-23-2014 11:43 AM
Limited slip diff 06WHTGC WK1 Suspension / Driveline Discussion 1 01-07-2011 07:34 AM
rear diff - dealer put in limited slip additive?? SRT8HC WK1 Suspension / Driveline Discussion 3 12-29-2009 10:05 PM
Limited Slip Differentials (Mechanical) jonvon WK1 SRT8 General Discussion 24 09-02-2007 03:50 PM
