Stage 6 fuel pump install questions - Cherokee SRT8 Forum
post #1 of 9 (permalink) Old 11-25-2012, 06:58 PM Thread Starter
Miss Understood
Vinnysrt8's Avatar
Send a message via AIM to Vinnysrt8
Does any one have a copy of the install instructions mine r hard to see.. And who ever did the install how did u wire it up thanks.
53 Studebaker 383stroker find out the 1/4 soon
72 SS Nova 468BB 11.7
88 Warlock boat 468BB 80mph
01 BATBOAT BLOWN 1100HP 121MPH
04 KFX700
07 Jeep SRT8 Black BLOWN AND KICKING ASS 11.4 at 116mph
10 SS/RS Camaro 12.9 inferno orange
13 Jeep Grand Cherokee DD
Vinnysrt8 is offline
post #2 of 9 (permalink) Old 12-01-2012, 10:52 PM Thread Starter
Miss Understood
Vinnysrt8's Avatar
Bump would like to finish it tomorrow. Thanks
post #3 of 9 (permalink) Old 12-02-2012, 05:48 AM
rmon's Avatar
Pm me tomorrow.
Rich
Vortech V3, Paramount transmission, and TCM, Dominator convertor, Stage 6 fuel hat, Inertia cam, StainlessWorks LTH, Wavetrac LSD, Modified Magnaflow Cat Back, Modern Muscle ported intake, Arrington 85mm TB, Tuned by Mike at OST
PB 11.56@118.3
street tune, full weight, all season tires, 93 octane
PB 11.17@122.3
Weld 17"wheels, timing and VP110 added, subwoofer left at home
rmon is offline
post #4 of 9 (permalink) Old 12-04-2012, 09:49 PM
Vinny...... you have my cell number. Just call me. Duh! BUT NOT NOW!! Tomorrow!!
Harrison@Stage6 is offline
post #5 of 9 (permalink) Old 12-08-2012, 06:51 AM Thread Starter
Miss Understood
Vinnysrt8's Avatar
Lol i know but i dont want to bother u when ur home relaxing, but i think ill be good now rmon gave me some info but if i get stuck ill call u thanks..
The Following User Says Thank You to Vinnysrt8 For This Useful Post:
Harrison@Stage6 (12-10-2012)
post #6 of 9 (permalink) Old 12-09-2012, 03:59 PM
rmon's Avatar
I had your back on this HB. After blowing up your phone the weekend I did mine, I owed you.
rmon is offline
The Following User Says Thank You to rmon For This Useful Post:
post #7 of 9 (permalink) Old 12-09-2012, 09:16 PM Thread Starter
Miss Understood
Vinnysrt8's Avatar
Thanks everyone its all hooked up and the jeep runs..
post #8 of 9 (permalink) Old 12-09-2012, 09:20 PM
Knuckles's Avatar
Any pointers for anyone who has not done it Vinny?
Thanks brother!
Knuckles
Knuckles is offline
post #9 of 9 (permalink) Old 12-10-2012, 06:34 AM Thread Starter
Miss Understood
Vinnysrt8's Avatar
This is what Rich sent me RMON
this helped alot the only thing i did different was i put the relay inside the fuse box.
Yellow = + bat terminal.
White = fuel pump power wire (it's red with orange stripe in the pwr distrib ctr on 08's)
Black = connect to a terminal on the hobs switch and connect the other terminal to a
good ground. (I used a lug on the fender well)
Blue = use the extension wire to run back to the harness that connects the fuel hat to
the chassis wiring. The connector is about 18 inches long and right above the
rear diff. It connects at the fuel hat plug and the other plug is in the "tunnel"
again right above the rear diff.
What you need to do is cut the black ground wire in the 18 inch harness. The end going to the connection for the chassis ground you just tape up. Connect the wire that you ran from the blue lead coming out of the relay the the other end of the black wire in the harness that was cut. The end of the black wire going to the fuel hat connector has the blue wire connected and now becomes the power wire for the second pump. Leave a little slack in the connection because you have to be able to drop the tank a bit to disconnect the connector at the hat if you need to do repairs later.
Fuel pump maansy WK1 Engine Performance/Superchargers/Turbos/Nitrous 7 05-11-2011 02:43 PM
Kenne Bell Boost A Pump install help and other BAP questions SrtJake WK1 Engine Performance/Superchargers/Turbos/Nitrous 11 04-12-2011 04:56 PM
Need help fuel pump went bad have alot of questions Vinnysrt8 WK1 Troubleshooting / Problems Discussion / Dealer Service 18 11-15-2010 03:02 PM
fuel pump? crumped7 WK1 Troubleshooting / Problems Discussion / Dealer Service 1 08-04-2007 10:28 AM
