few questions... - Cherokee SRT8 Forum
post #1 of 17 (permalink) Old 11-24-2012, 11:14 PM Thread Starter
nubtard's Avatar
few questions...
I have a 06 w/22k on it. Has a mopar cai, and bgchrysler tune.
The cel comes on, checked codes and came back as a cylinder 1 misfire. What to do? Erased the code 2 times. Comes back on when starting after cold.
Next question, is there any guide on swapping cams? Can anyone chime in about needing a cam bearing tool?
Also diablosport gave a error when trying to modify the tune. Says that I needed to update. But is up to date.
Next is, what side to run a wide band in? I don't know it matters or not
nubtard is offline
post #2 of 17 (permalink) Old 11-25-2012, 07:31 AM
cmn1's Avatar
Specific cylinder misfire codes are bad news. I would pull the plugs and see if they are crushed. O2 sensor is best on the driver's side.
cmn1 is offline
post #3 of 17 (permalink) Old 11-25-2012, 07:37 AM
LASRT's Avatar
I agree with this guy ^^^^
LASRT is offline
post #4 of 17 (permalink) Old 11-25-2012, 08:20 AM
ekaz's Avatar
Agree with them. See if Diablo can force a stock flash and then use the Diablo, the bg tunes leave something to get desired. No need for a cam bearing tool to swap cams. There isn't a guide here, but there is one in the knowledge base on lxforums. Your username need to find out what's going on with cylinder 1 fast.
I'm BAAAAAAAACK....
2015 Billet Silver
past:
2012 300SRT
2009 Jeep SRT
2006 Charger SRT
ekaz is offline
post #5 of 17 (permalink) Old 11-25-2012, 07:59 PM Thread Starter
nubtard's Avatar
yep plug #2 in #1 cylinder was crushed. what causes this?
nubtard is offline
post #6 of 17 (permalink) Old 11-25-2012, 08:03 PM
cmn1's Avatar
Broken ringland, usually. Going to have to get it scoped and/or compression checked.
cmn1 is offline
post #7 of 17 (permalink) Old 11-25-2012, 08:36 PM
ekaz's Avatar
What cmn1 said.
ekaz is offline
post #8 of 17 (permalink) Old 11-26-2012, 12:29 AM Thread Starter
nubtard's Avatar
hrmm. So how worried should I be? I have about 450 miles on it since I bought it. it appears to have new plugs in it. I straightened out the plug and reset to gap and now has a tick and the idle is stuck higher at about 1100.
I do have a 3 month/3000 mile power train warranty from the dealer that I bought it from and Also purchased a extended bumper to bumper warranty from them that is a "MasterTech" brand. I am going to call them first thing in the morning. If anyone has any advice or suggestions, on how to work this so they do not try to give me a line of BS
nubtard is offline
post #9 of 17 (permalink) Old 11-26-2012, 01:27 AM
Did you buy it with the tune or did you do it? If you did it reset to stock before going in. If I were you, since you say you have a warranty, I would of left the plug the way it was & had it taken to the dealer in the morning. Something had to hit the plug to close it. Most likely its a broken ring land as mentioned. The top ring land on the stock piston is thin & known to break but mostly with boosted applications. A piece breaks off & gets smashed between the piston & plug closing the plug. Unfortunately you are probably going to need a new motor or have to have it rebuilt. Sometimes the dealer may just try & replace that one piston though.
J&D's SRT's is offline
post #10 of 17 (permalink) Old 11-26-2012, 01:59 AM Thread Starter
nubtard's Avatar
Thanks for the replies, I bought it with the bgchrysler tune and mopar cai.
nubtard is offline
got an 09, have some questions SRT8-MVP WK1 Audio/Video/Nav/UConnect/Electronics 6 04-19-2011 08:04 AM
cam questions dkone WK1 General Performance Discussion 5 04-22-2010 12:45 PM
questions RyBoSRT8 WK1 General Performance Discussion 6 11-10-2009 11:12 AM
AWD and other questions ChicagoGuy WK1 SRT8 General Discussion 1 10-16-2009 08:06 AM
My First SRT... MOD questions... BD997 WK1 General Performance Discussion 7 02-06-2009 04:22 PM
