One side of exhaust getting much hotter much faster than the other? - Cherokee SRT8 Forum
post #1 of 5 (permalink) Old 11-23-2012, 05:42 PM Thread Starter
Hey guys, I honestly haven't looked much into if there is a reason for this or not, but I bought my Jeep about a month ago now and have had it sitting in a garage for the most part while I buff the paint and detail everything inside and out.
It drives fine, pulls hard, etc but I notice when I start it up the left tail pipe is putting out considerably more hot exhaust than the right. I happened to start it tonight and grab both exhaust pipes under the middle of the car. The exhaust pipes leading to the right side were only luke warm after 2-3 mins of running whereas the pipes leading to the left tail pipe burned my fingers right away.
Is this normal for any particular reason? Again, no check engine lights, pulls hard, idles smooth, etc.
Also, what's that noise the Jeep makes when you turn it off? Hope it's normal, but it's like a mechanism type noise below the Jeep when I turn it off. I hear it when I use the remote automatic start/turn off also.
Thanks
Totsie7944 is offline
post #2 of 5 (permalink) Old 11-23-2012, 07:37 PM
Have no idea about the first part. But the noise is normal when you turn it off. Its the transfer case
2006 Jeep SRT (SOLD)
2009 Pontiac G8 GT (Hoping to be sold soon for a C6 Z06)
Theconnman2 is offline
post #3 of 5 (permalink) Old 11-24-2012, 12:12 AM
Could be a plugged exhaust from a broken cat. Is it only the temp that's different or is the amount of airflow from each pipe different too?
2008 GC SRT8 - Techco Supercharger @ 5.3lbs, Paramount Stage II VB, Paramount Tranny Cooler, Walbro 400lph pump, HHP Tuned, BT Catch Can, QTP Cutouts, Borla S, QA1s, End Links, Volt 4300k HID fogs, Stant 18# cap, 1 pc Upper Hose, 180 thermo, WeatherTechs & Liquiddomes, Custom Stereo, Cryoed R1s/Stoptechs/ATE Super Blue, painted calipers, 22" Bonspeeds and CF Medic V1 hood.
Injuredoften is offline
post #4 of 5 (permalink) Old 11-24-2012, 12:34 AM
blahson's Avatar
Part 1:
If the airflow is even out of both pipes, I wouldn't worry.
Uneven airflow, then I'd guess you have a hole in your exhaust but after the muffler/reso if there is no sound difference.
It may even be trapped water in the reso which would work as a temp buffer, which is completely harmless.
Part 2:
Not sure why most people say that noise is normal, my dealer said it was bad. If I were you do this:
If you have warranty where the tc (transfer case) is covered, take it to the dealer and ask the service rep to call over the transmission guy (be persistent) to hear the noise. He'll freak out and strongly advise to get it fixed. For me, they ended up replacing my tc and rebuilt my transmission. Haven't had the noise since
If you don't have a warranty then don't worry about it. Enough people on here have the noise as well and it hasn't done any harm.
Joeyyyyy
06 Jeep SRT8
blahson is offline
post #5 of 5 (permalink) Old 11-25-2012, 02:12 PM Thread Starter
Thanks for the responses guys. The air flow is the same on both pipes, probably just water or something with the cats. I'll probably throw on some kooks headers and a full exhaust, no cats by spring anyway. So it should open it up haha.
WK SRT8 with Side Exhaust and Tow Package jntdysf WK1 SRT8 General Discussion 18 02-19-2011 02:58 PM
side exhaust? BOBO_25 WK1 SRT8 General Discussion 50 02-29-2008 02:10 PM
Finally installed 180 tstat yet my engine is running hotter than usual. ckehl WK1 Troubleshooting / Problems Discussion / Dealer Service 6 05-18-2007 10:37 AM
Put in 195 thermo, now car tuns hotter Untouchable WK1 General Performance Discussion 4 07-02-2006 12:44 PM
