Jack points - Cherokee SRT8 Forum
post #1 of 4 (permalink) Old 11-19-2012, 05:27 PM Thread Starter
jvs0302's Avatar
Jack points
What points on the truck are you guys using to jack up the Jeep? I found a link to a diagram that suggest the rear axle to lift the rear. I have a set of race ramps and even with a good jack I cant get a high enough lift from that point to get the rear cradles under the wheels. Is it ok to jack up from the rear diff instead? Or should I use some part of the side frame rail?
Also for those of you who use jack stands, exactly where on the frame front and rear are you positioning them?
John
2010 Brilliant Black SRT8
Mopar intake | Corsa exhaust | Trinity | MTX-L wideband | Jersey Boy tuned | BT catch can | BT underhood kit | Eibach springs | BWoody swaybar links | Summer: Bridgestone Dueller HP Sport RF 275/315 on OEM wheels | Winter: Pirelli Scorpion Ice & Snow RF 275 on satin black reps | R1 Premium Slotted/Cross Drilled rotors | Stoptech pads | DC Customs headlights | TS LED taillights | TS painted moldings |
jvs0302 is offline
post #2 of 4 (permalink) Old 11-19-2012, 07:23 PM
Jacking the front end
2008 GC SRT8 - Techco Supercharger @ 5.3lbs, Paramount Stage II VB, Paramount Tranny Cooler, Walbro 400lph pump, HHP Tuned, BT Catch Can, QTP Cutouts, Borla S, QA1s, End Links, Volt 4300k HID fogs, Stant 18# cap, 1 pc Upper Hose, 180 thermo, WeatherTechs & Liquiddomes, Custom Stereo, Cryoed R1s/Stoptechs/ATE Super Blue, painted calipers, 22" Bonspeeds and CF Medic V1 hood.
Injuredoften is offline
The Following User Says Thank You to Injuredoften For This Useful Post:
jvs0302 (11-19-2012)
post #3 of 4 (permalink) Old 11-19-2012, 07:24 PM
LASRT's Avatar
I always use differential and put jack stands on the outer most shock mounts.
LASRT is offline
The Following User Says Thank You to LASRT For This Useful Post:
post #4 of 4 (permalink) Old 11-19-2012, 09:09 PM Thread Starter
jvs0302's Avatar
Originally Posted by Injuredoften View Post
thanks guys this is exactly what I was looking for. great link to follow as well
jvs0302 is offline
Recommend floor jack & jack stands? pjs1965 Off-Topic Discussion 10 03-19-2010 01:57 PM
Jack points? speakman WK1 SRT8 General Discussion 3 12-10-2009 01:14 PM
Idiot Question...Where are the Jack Points? AHurst WK1 SRT8 General Discussion 4 10-07-2007 09:58 PM
Jack points DanDE WK1 SRT8 General Discussion 7 07-16-2007 03:38 PM
Where are the jack points on GC SRT8? kman999 WK1 SRT8 General Discussion 4 01-14-2007 10:42 PM
