Transfer Case Removal Question - Cherokee SRT8 Forum
post #1 of 24 (permalink) Old 09-18-2012, 03:38 AM Thread Starter
Transfer Case Removal Question/ brief DIY
I plan on removing my transfer case and replacing all the internals, clutch pack, chain , gears, ect. Ive been running 2wd for around 9 months because the case started to bind up. Do i need to drop the tranny to remove the transfer case? Any points i need to support with a jack while im working on the transfer case? Other than the fluid inside of the case do i need to worry about any other fluid leaking? I've quoted around $800 to $900 in parts to completely rebuild. Any tips or tricks would be helpful.
Thanks -Jason
jabdelja is offline
post #2 of 24 (permalink) Old 09-18-2012, 08:20 AM
ekaz's Avatar
You don't have to remove the trans to remove the transfer case. I would put a floor jack under the trans to support it. No other fluids to be concerned about, pretty straight forward.
I'm BAAAAAAAACK....
2015 Billet Silver
past:
2012 300SRT
2009 Jeep SRT
2006 Charger SRT
ekaz is offline
post #3 of 24 (permalink) Old 09-18-2012, 08:52 AM
One, two, GIT SUM!!
gitrdun's Avatar
its almost light enough to just drop on your chest from the looks of it.. if you can support the splines when you remove it, if youve done alot of wrenching youd be able to get away with that
gitrdun is offline
post #4 of 24 (permalink) Old 09-18-2012, 09:35 AM
ekaz's Avatar
The transfer case isn't that heavy, but isn't super light either.
ekaz is offline
post #5 of 24 (permalink) Old 11-01-2012, 08:37 AM Thread Starter
so I have my jeep up on the ramps and i have 6 of the bolts out of the transfer case where it connects to the transmission. There are 3 on the passenger side of the case and 2 on top that are just about impossible to access with any type of tool. Is there a trick to getting to them or should i just chalk up my loses and take it to a shop?
also could i just slip the transfer case while still installed on the car to replace the clutches??
2006 SRT8 Jeep: Black, AFE Stage 2 intake, 180 Jet Tstat, BT Catch can, Blue Tops, Vred 315 combo, 15% tint.
jabdelja is offline
post #6 of 24 (permalink) Old 11-01-2012, 08:47 AM
ekaz's Avatar
A universal or two and a couple extensions should work just fine. They are a paint to get to, but can be taken out.
If you lower the trans a little (assuming you have a jack under it), it'll slant down and should give you a little more room in that area.
ekaz is offline
post #7 of 24 (permalink) Old 11-01-2012, 08:53 AM Thread Starter
the trans is still being held up my the trans mounts it wont move. There seems to be a bracket holding the exhaust that is directly in the way. Do i need to remove that I have tried all sorts of extensions and everything. My next option will be just splitting the case while still attached and trying to replace the clutches that way
jabdelja is offline
post #8 of 24 (permalink) Old 11-01-2012, 09:01 AM
ekaz's Avatar
Put a jack with a piece of wood under the trans pan, take the trans mount off, then lower the floor jack a little. The trans should tilt down enough to get in there for those bolts.
The trans mount should be right around where the trans and transfer case meet, it doesn't hold the exhaust at all.
ekaz is offline
post #9 of 24 (permalink) Old 11-01-2012, 12:48 PM Thread Starter
today i was defeated. I attempted to just crack open half of the unit while the other half stayed installed into the transmission. Everything was going great until i hit the bolt that holds the driveshaft coupler thing on. Didnt have any kind of tool that would work. I will regroup buy the proper tool and try again another day to finish the project. If not i have 300 bucks worth of clutch plates.Thanks for the help though.
jabdelja is offline
post #10 of 24 (permalink) Old 11-02-2012, 11:05 PM Thread Starter
Does anyone know what size socket is needed to remove the nut that holds the coupler on the tcase to the drive shaft coming out of the tcase
jabdelja is offline
noobie transfer case question ShaneN. WK1 Suspension / Driveline Discussion 3 05-27-2011 09:50 PM
Transfer Case/ESP 6.1_Toboggan WK1 Troubleshooting / Problems Discussion / Dealer Service 9 10-23-2009 02:01 PM
TRANNY and transfer case question PETERSRT-8/10 WK1 General Performance Discussion 55 03-03-2009 05:12 PM
Question regarding transfer case/rear end noise. 2BADGN WK1 SRT8 General Discussion 10 12-12-2007 05:06 AM
