Transfer Case Removal Question - Page 2 - Cherokee SRT8 Forum
post #11 of 24 (permalink) Old 11-03-2012, 12:34 AM
WIPLASH's Avatar
you should contact Builder Bill, he should know the answer for anything drive train related.
I'm gettting frustrated
with modding
WIPLASH is offline
post #12 of 24 (permalink) Old 11-03-2012, 02:18 PM
DarknightSRT8's Avatar
where did u find the parts to rebuild i think i hv to do mine
OBX Headers/ppp stage 2 cam/paramount 3800 12.5@107
DarknightSRT8 is offline
post #13 of 24 (permalink) Old 11-03-2012, 03:54 PM Thread Starter
Factory mopar parts
2006 SRT8 Jeep: Black, AFE Stage 2 intake, 180 Jet Tstat, BT Catch can, Blue Tops, Vred 315 combo, 15% tint.
jabdelja is offline
post #14 of 24 (permalink) Old 11-03-2012, 04:22 PM
ok thanks bro
post #15 of 24 (permalink) Old 11-03-2012, 06:01 PM
There is definitely a bracket connecting the exhaust to the drivetrain and it is a ***** to get. I used an open end wrench and about an hour to get both bolts. lol. I only put 1 back in. F that noise.
Jack_Toepfer is offline
post #16 of 24 (permalink) Old 11-03-2012, 10:37 PM
Here is some info I got off my alldata.
Removal
torque specs
Hope this helps bro
Sent from my iPhone using Autoguide.com App
2009 JEEP SRT8 FULLY LOADED
BES/HHP 426 STROKER - 6.4L PORT&POLISHED HEADS - STAGE 4 CAM - REAR CROSS MEMBER/ENDLINKSPORT&POLISHED INTAKE MANIFOLD/ARRINGTON 90MM THROTTLE BODY/3000 STALL/INOVATE WIDEBAND/AMERICAN RACING LONGTUBE HEADERS/6K LOWS & FOGS/SOLO/DMH LOW PROFILE E-CUTOUTS/BC COILOVERS/ADDCO SWAYBARS FRONT&REAR/VREDS 275 315/180 THERMOSTAT/LED TAILS/TINTED REAR FOGS/TRINITY/DORMANT BLUE & BLACK POWDER COATING UNDER HOOD AND CALIPERS
Tuned by Josh at HHP
552 Max Horsepower - 528 Max Torque
Ride4life686 is offline
post #17 of 24 (permalink) Old 11-05-2012, 03:39 AM Thread Starter
Thanks for the links!!
Im going to split the case while still attached to the tranny. I just need to find out the size of the bolt that holds the output coupler to driveshaft on. When i figure it all out ill do a mini diy.
jabdelja is offline
post #18 of 24 (permalink) Old 11-15-2012, 06:30 PM Thread Starter
Ok the bolt is a 32mm and need a deep drive socket to get it. I took the rear most plate off the case today. Went to undo the bolts to crack the center open and one sheared right in half. Tomorrow im going to get a bolt extractor kit to remove it and attempt to finish the job. Does anyone know if the dealer sells those bolts? If so what the part number is. Im going to attempt to do a diy write up if i can finish. Any input would be much appreciated
jabdelja is offline
post #19 of 24 (permalink) Old 11-16-2012, 04:04 PM Thread Starter
Torn down the transfer case today.
Need
Full tool set, assorted extensions. Mainly 15mm and 10 mm sockets.
1.Rolled my rig up on wheel ramps to start the project(ebrake and wheel stops).
2.Unbolted the rear drive shaft that comes out of the t-case(4 bolts 15mm)
3. drain the fluid out of the tcase
4.Remove 32mm bolt that holds the drive shaft coupler to the output shaft and take off the coupler(may require a few light taps from a hammer) A little fluid will leak out the result is pictured.
5. Unbolt the rear most plate on the t-case itself (10mm) There are two pry spots on the plate on on the bottom and one on top, since the case is still installed on the car you have to take a large flat head and pry it off with the bottom one, it takes alittle cause you have to break the seals. After you take the plate off you will see below. The two gear like metal pieces need to be removed.
6. Unbolt the center of the t-case (may need some liquid wrench) I sheared one bolt so i had to drill it out. Just be careful when removing them.
7. Unplug the hose that is on the top of the case
8. Split the case using a larger screw driver.
9. After you remove the case theres a snap ring holding the plate into the clutch basket.
remove the snap ring and the top plate will come off and the clutches will be exposed. With the clutches removed it will look like so.
10. Took the case out and cleaned it up, new clutches and plates.
11. Put them back the way they came out. Make sure the magnet get cleaned and everything gets wiped out good.
12.Use high temp silicone to re-seal the case back together when its time to reinstall the half.
13. reinstall the rear most plate, make sure you seal inside where you see the old gasket as well as the outside.
14. torque all the bolts down and reinstall the hose on the top of the case.
15. Let the case dry before you add the fluid. Then add the fluid.
16. Reinstall the t-case motor and plug is back in.
17. Drive it and enjoy a fresh t-case.
old clutches
The clutches i removed were terrible, burnt all up. My case hummed alittle until i drove it around the neighborhood, now its functioning good.
I rode 2wd for over one year and now im happy and back to awd. Thanks for anyone who helped me. It ended up costing around $500 bucks to rebuild completely.
Ill get the part numbers that i purchased.
jabdelja is offline
The Following 2 Users Say Thank You to jabdelja For This Useful Post:
Knuckles (11-21-2012), WIPLASH (11-17-2012)
post #20 of 24 (permalink) Old 11-16-2012, 04:18 PM
SPEEDDEMON's Avatar
Great Job...Thanks for sharing! This should be a sticky in the do-it yourself section.
, Innovate MTX-L Wideband
Fluidyne Customized Radiator
More to come
SPEEDDEMON is offline
noobie transfer case question ShaneN. WK1 Suspension / Driveline Discussion 3 05-27-2011 10:50 PM
Transfer Case/ESP 6.1_Toboggan WK1 Troubleshooting / Problems Discussion / Dealer Service 9 10-23-2009 03:01 PM
TRANNY and transfer case question PETERSRT-8/10 WK1 General Performance Discussion 55 03-03-2009 06:12 PM
Question regarding transfer case/rear end noise. 2BADGN WK1 SRT8 General Discussion 10 12-12-2007 06:06 AM
