Diesel Competition - Page 2 - Cherokee SRT8 Forum
post #11 of 62 (permalink) Old 08-06-2012, 06:34 PM
1 obvious advantage is a fuel that doesn't require additional octane to add timing or boost. The other is a very robust forged motor made for boost and tons of it. Oh, and they come from the factory with turbos already. So you're way ahead of the game there.
To be a top dog your going to spend a ton of cash, but you can run 11s in a 7.3 dinosaur with a way less than $10k into it. You can have a lot of fun in a diesel truck for $3k and beat most of what's out there. The transmissions are better now but not bulletproof, but everything else is usually up to the task.
They respond very well to nitrous, propane, methanol, water and just about anything else you can cram down the intake.
Jack_Toepfer is online now
post #12 of 62 (permalink) Old 08-06-2012, 07:11 PM
Coksmith&Master-Pintsman
navyavi469's Avatar
Stock diesel trucks are nothing to worry about, 16 and 17 second E/T quarter mile. However they can be made VERY fast much more easily than a gas rig. The one ton trucks come with gigantic axles, low gears, very heavy duty transfer cases, and decent transmissions that will gobble down 1000ftlb of torque with no issues and put every bit of it to the ground. Do with modest upgrades to the torque converter there isn't much reasonable limit to what the powertrains can handle.
So it comes down to the engine. Diesels work on detonation, so there is no amount of boat that will ever run you out of octane, more boost is more power as far as the turbo can go. Diesels have very long strokes and piston rings that will outlast the rest of the truck 10x over. The weaknesses of diesels start with the head gaskets, which usually require studs and o rings to make huge power, after this they need more turbo and fuel system to support the massive smoke blowing power outputs. At this point you're about 5-10k in engine mods and running 12s or better at the touch of a button, so WATCH OUT. It takes a pretty big jump from there to go much faster, 20-50k in mods on big turbo, big fuel, and custom tranny will net you 10s or better.
* 2006 WK1 JEEP SRT8 (THE FIRST) TURBO BUILD, 743AWHP/860AWTQ *SOLD*
__CREDITS: S6 Motorsports, Paramount, AJ Hemituner, Johan, LPM Engines
* 2013 WK2 JEEP SRT8 ALPINE (DAILY DRIVER/VISUAL MODS)
__CREDITS: BWoody Performance, Taillight Solutions
*I have plans, yes... I have plans
navyavi469 is offline
post #13 of 62 (permalink) Old 08-06-2012, 07:16 PM
navyavi469's Avatar
And if your curious, my dually has entry level mods, tuner, exhaust and CAI. I'm about $2g in mods and over 1000ftlb at the back wheels, I run 14s on the "evic" in an 8200lb mega cab.
post #14 of 62 (permalink) Old 08-06-2012, 07:28 PM
tmm403's Avatar
My Chevy duramax runs lows 12's. Tons of mods but transmission upgrade is a must to make diesel power. Ive seen guys get a programer and use max power but then fry their trannys. Definitely torque monsters. Also for launch i do 4wd boost launch. I can take mostly anything off the line unless im lined up against a twin or turbo Jeep...lol
JEEP SOLD....TODD..2006 JEEP SRT8 -- 4" Bwoody CAI, Borla S w/resonator delete, Stant 18lb rad cap , Lips Harness, Nitto Motivos 275/315, BT Catch Can, Diablo Predator, R1 Eline drilled and slotted front and rear rotors, Hawk ceramic pads
tmm403 is offline
post #15 of 62 (permalink) Old 08-07-2012, 04:14 AM
DCSpecial's Avatar
As mentioned, yes they can make huge power.
On the newer diesels once you remove all the emissions BS and do a full exhaust, an intake, etc there are tunes that will give you 200-300+hp boosts.
Hell, I have a 7.3L dinosaur and my chip will put me up to 140hp increase in the high setting.
DCSpecial is offline
post #16 of 62 (permalink) Old 08-07-2012, 05:55 AM Thread Starter
DCsnow1000's Avatar
Pretty Wild.
Sold the Jeep...waiting for the right time to get back on board
DCsnow1000 is offline
post #17 of 62 (permalink) Old 08-07-2012, 08:06 AM
I tripled the power in my 7.3 with sticks, turbo, tune, tranny and studs. Smoked 40s across intersections... on veggie fuel.
It rocked out man, I'll do it again.
post #18 of 62 (permalink) Old 12-11-2012, 06:29 PM
sully83699's Avatar
digging on an older thread but a guy at my college says hes got a 800 hp cummins that will beat my jeep. What quarter mile times do you think they are looking at at that power if hes not BS'n me and cost?
0-60 sec 4.27 sec
1/4 mi. 12.23 sec at 110 mph
and getting faster!!!
sully83699 is offline
post #19 of 62 (permalink) Old 12-11-2012, 06:42 PM
Contributing Member
PITTZ's Avatar
He better have a built tranny with that kind of HP or he can't do much with it.
Team Winter Build
PITTZ is offline
post #20 of 62 (permalink) Old 12-11-2012, 06:48 PM
Hate to be the barer of bad news but if he does have 800hp he will in fact smoke your ass. On top of 800hp, he's making probably 1500-1700rwtq too. I used to be into diesels before I bought my Jeep. They can be flat out nasty and sleepy.
Harrison@Stage6 is offline
The Following User Says Thank You to Harrison@Stage6 For This Useful Post:
crosshair (12-16-2012)
Ironman Competition...who's done one? 01saleen77 Off-Topic Discussion 6 06-02-2012 05:45 PM
New Competition-ML63 WS6TA Other Vehicle Makes & Models Discussion 12 11-20-2011 08:46 PM
New Competition / 0-60 in 4.4 blackstallion WK1 General Performance Discussion 17 11-06-2008 07:07 PM
The Competition for 2009 Blown7 WK1 SRT8 General Discussion 34 12-22-2007 01:59 PM
