DIY: A/C & Heater Actuator Gear - Page 4 - Cherokee SRT8 Forum
post #31 of 55 (permalink) Old 06-07-2012, 10:18 PM Thread Starter
SRT8Girl12's Avatar
I tried posting it in there, it said I didn't have access.
Thanks Bernie!
2009 Jeep SRT8 Brilliant Black - Sold
SRT8Girl12 is offline
post #32 of 55 (permalink) Old 06-08-2012, 06:46 AM
cmn1's Avatar
Thanks Bernie!
You have to post it in the review section. http://www.cherokeesrt8.com/forums/f...play.php?f=134
cmn1 is offline
The Following User Says Thank You to cmn1 For This Useful Post:
Rambit (06-08-2012)
post #33 of 55 (permalink) Old 06-08-2012, 06:58 AM
Administrator
Rambit's Avatar
Thanks Bernie!
Yep Chad's right!
Bernie
WK2 SRT8 Owners - Please post in the
thread!
2005 300C SRT8 - #72 of 252 (excl. 11 pilots) - #10 of 35 Canadian SRT8's built
2008 Harley Davidson FLSTF Fatboy - Vance & Hines Big Shots STGD with FuelPak tune.
2008 Jeep GC SRT8 - Custom Build/Custom Delivered by SRT - 1 of 1 in Canada
2012 JK Rubicon U - 2 1/2" lift, flares, Fox Shoks, Mickey Thompson Baha MTZ P3 35's, JW Speaker LED 8700 Evolution J Headlights etc...
Rambit is offline
post #34 of 55 (permalink) Old 06-08-2012, 09:17 AM Thread Starter
SRT8Girl12's Avatar
Well geez, sorry!
post #35 of 55 (permalink) Old 06-08-2012, 09:20 AM
cmn1's Avatar
You are off the hook this time. Almost as bad as those that don't use the search function. LOL
cmn1 is offline
post #36 of 55 (permalink) Old 06-08-2012, 09:31 AM Thread Starter
SRT8Girl12's Avatar
Hahahahaha! No no, definitely not even in the same ball park as people who don't search.
By the way, what's a catch can? Should I buy one?
post #37 of 55 (permalink) Old 12-21-2012, 07:43 AM
Mike05V's Avatar
Awesome write up. I knew mine was going out so picked up the gear about a month ago. Finally put it in yesterday. Very easy but like it says above you have to play with the Recirc button to get the gears to line up.
Mike05V is offline
The Following User Says Thank You to Mike05V For This Useful Post:
SRT8Girl12 (12-21-2012)
post #38 of 55 (permalink) Old 12-21-2012, 08:12 AM
Tim H Calgary's Avatar
Hmm I found that piece in my glovebox... throw it on the list . Thanks Tamara!
Tim H Calgary is offline
post #39 of 55 (permalink) Old 12-24-2012, 09:24 AM
to those that have made this repair, can you tell me how much the actuator moves once its fixed? i just repaired mine, i was able to get it back togeather without having to turn the recirc on and off, to make it line up.
once its fixed though and you operate the recirc switch the gear only moves like half a turn, it seems like when it is installed the gear is in the center position, than when you activate the recirc it only moves the last little bit on that gear.so basicially the gear is two times longer than is needed. Or another way of putting it, some of the teeth on the entire length of that gear never get used.
is this what everyone elses system operates like? thanks and merry christmas
some stuff, and some other stuff
"knowledge is knowing a tomato is a fruit, wisdom is knowing to not put them in a fruit salad"
kennzz05 is offline
post #40 of 55 (permalink) Old 12-24-2012, 01:58 PM
cmn1's Avatar
I believe that is why you have to push the button so you sync the gears properly, sounds like you are off a couple of tooths.
cmn1 is offline
Transfer Case actuator motor Painlord WK1 Troubleshooting / Problems Discussion / Dealer Service 6 12-11-2014 10:41 AM
Bypass actuator in magnacharger maansy WK1 Engine Performance/Superchargers/Turbos/Nitrous 20 05-21-2011 09:04 AM
Moved: Weird sound when upshifting gear to gear (CMR TUNE)?? RadarJAMMER WK1 Troubleshooting / Problems Discussion / Dealer Service 20 11-05-2010 09:56 AM
Big Issue!! Throttle Actuator. PLEASE HELP! (Moved) jhriss WK1 Troubleshooting / Problems Discussion / Dealer Service 45 03-27-2010 11:59 AM
What is the PROBLEM !! 3rd actuator motor in 3 months? Razorecko WK1 Troubleshooting / Problems Discussion / Dealer Service 6 07-20-2007 09:47 AM
