DIY: A/C & Heater Actuator Gear - Page 3 - Cherokee SRT8 Forum
post #21 of 55 (permalink) Old 06-07-2012, 06:50 AM
CHUCKTOWNSRT8's Avatar
Originally Posted by Jeep Trick View Post
Did you ever check your freon level? Mine was blowing cold on the driver side normal on the other with everything set to the coldest. As soon as we topped it off it worked fine again.
My mechanic didn't even charge me for it.
To me it just a cheap thing to eliminate before getting into it deeper
Yeah, I'm having a freon leak issue and that might be my problem. Think I may have found it with some dye, but I'm out of town till the 23rd, so I won't know until I get back.
[SIGPIC][/SIGPIC]
CHUCKTOWNSRT8 is offline
post #22 of 55 (permalink) Old 06-07-2012, 09:09 AM Thread Starter
SRT8Girl12's Avatar
I will check it. Where is there a fast place to go besides the dealer? And the only reason why I don't think it's that is because the driver and passenger side air is SO different. My driver side is pretty damn cold, passenger side, not at all. But I will do it, especially if it saves me from tearing into my dash.
2009 Jeep SRT8 Brilliant Black - Sold
SRT8Girl12 is offline
post #23 of 55 (permalink) Old 06-07-2012, 10:15 AM
Jeep Trick's Avatar
Thats what mine was doing, nice and cold on the driver side and felt like just the fan was on for the passengers. Remember that everything is controlled by something. It probably programed to shift the cold air to the drive if its not performing well.
If you ever get a bad alternator and drive it till the battery goes dead its really interesting how the car will automatically eliminate unnecessary functions until it will eventually just die. It will do everything to keep the car on the road until it just cant run because it doesn't have enough electrical power.
I would highly recommend you find a good reputable mechanic, preferably one that is familiar with high performance vehicles. AVOID THE DEALER LIKE THE PLAGUE! I do most all the work on my Jeep but there are just somethings that are beyond what I'm equipt to do. I don't have a car lift or an engine hoist or the space. So I do what I can and let him take care of the rest. My mechanic has even lent me tools sometime when I needed them. He is well know and highly respected and very fair in fact some times I think he doesn't charge enough lol. The last thing you want is to be in a pinch and under pressure have to decide where to take it. Better to have that figured out before.
Jeep Trick is offline
post #24 of 55 (permalink) Old 06-07-2012, 10:41 AM Thread Starter
SRT8Girl12's Avatar
Interesting. Well, I will go do that today if I can find someone who knows what the hell they are doing. Maybe I will go to the dealer this once. I am leaving for the desert tomorrow and was planning on not taking my Jeep because of the A/C, but if this would help, I want to take it!
post #25 of 55 (permalink) Old 06-07-2012, 12:17 PM
Knuckles's Avatar
Nice write up Tamara!
Knuckles
Knuckles is offline
post #26 of 55 (permalink) Old 06-07-2012, 12:29 PM
You can charge your A/C with a few tools from autozone. Just buy the kit with the hose attached
post #27 of 55 (permalink) Old 06-07-2012, 05:28 PM
TBone5660's Avatar
Subscribing because I have the same problem. The driver side is cold but the pass and rear air are much warmer. I was quoted around $1200 by the dealership to replace the blend air doors/actuators. I took it in for a second quote at my local auto AC/Heat shop and they said anywhere from $200-600 depending on if the dash needed to come out. I have read that there is another way of replacing these blend air doors/actuators but it requires cutting into things and I don't like that idea. The only reason why I haven't had the AC shop to do the work is because I hate the idea of my dang dash being pulled out! My Jeep is SOLID with no rattles or squeaks and I want it to stay that way, but I will need to have it done soon because it is already getting into the high 90's here in North East TX and a good AC is a must.
TBone5660 is offline
post #28 of 55 (permalink) Old 06-07-2012, 06:51 PM
ASLEEPER's Avatar
Send a message via MSN to ASLEEPER
Great write up Tamara. I had this done under warranty by my dealer. It was interesting to see the pics as to what they did. They did mention that it took some work to get the thing back in properly. Now I know what to do if it fails again.
'09 Brilliant Black, all options, dual Kicker Sub, ambient interior lighting kit, cabin filter, Escort 9500ix w/Stealth mirror cord, Blendmount mirror mount & ZR4 Shifters, Mopar PDA holder, Weathertech Mats w/SRT Logos, Mopar CAI, BT Catch Can w/underhood dress up kit, Jeep rear cargo tray, HID fogs w/functioning rear fogs, shorty 8" black antenna, 6.1 Hemi Badges (fenders), SRT8 badges (doors), Intune & Johan Tune
ASLEEPER is offline
post #29 of 55 (permalink) Old 06-07-2012, 07:00 PM
cmn1's Avatar
You know there is a DIY section that is just waiting for threads like this. Post it in here.
http://www.cherokeesrt8.com/forums/f...play.php?f=134
cmn1 is offline
post #30 of 55 (permalink) Old 06-07-2012, 07:12 PM
Administrator
Rambit's Avatar
Captured - DIY (WK1): A/C & Heater Actuator Gear
Thanks Tamara!!! VERY well done.
Bernie
WK2 SRT8 Owners - Please post in the
thread!
2005 300C SRT8 - #72 of 252 (excl. 11 pilots) - #10 of 35 Canadian SRT8's built
2008 Harley Davidson FLSTF Fatboy - Vance & Hines Big Shots STGD with FuelPak tune.
2008 Jeep GC SRT8 - Custom Build/Custom Delivered by SRT - 1 of 1 in Canada
2012 JK Rubicon U - 2 1/2" lift, flares, Fox Shoks, Mickey Thompson Baha MTZ P3 35's, JW Speaker LED 8700 Evolution J Headlights etc...
Rambit is offline
Transfer Case actuator motor Painlord WK1 Troubleshooting / Problems Discussion / Dealer Service 6 12-11-2014 10:41 AM
Bypass actuator in magnacharger maansy WK1 Engine Performance/Superchargers/Turbos/Nitrous 20 05-21-2011 09:04 AM
Moved: Weird sound when upshifting gear to gear (CMR TUNE)?? RadarJAMMER WK1 Troubleshooting / Problems Discussion / Dealer Service 20 11-05-2010 09:56 AM
Big Issue!! Throttle Actuator. PLEASE HELP! (Moved) jhriss WK1 Troubleshooting / Problems Discussion / Dealer Service 45 03-27-2010 11:59 AM
What is the PROBLEM !! 3rd actuator motor in 3 months? Razorecko WK1 Troubleshooting / Problems Discussion / Dealer Service 6 07-20-2007 09:47 AM
