CTS-V Rear Brake Pads Squeal Like Pigs! - Cherokee SRT8 Forum
post #1 of 5 (permalink) Old 12-16-2010, 09:14 AM Thread Starter
When i got my truck about a year ago the rear breakes made a lot of noise. At about 4k i replaced them with CTS-V rears and the problem went away.
It's back. Now the rears when coming to a slow stop don't squeak.....they squeal as if the truck has straight up track brakes on it.
I don't get it. Why after 7k of driving on these pads did they get so freakin loud?
any suggestions? Thanks.
15 Audi S4
10 BMW X5M
09 GTR
07 911 Turbo
Rez90 is offline
post #2 of 5 (permalink) Old 12-16-2010, 09:16 AM
squigmang's Avatar
did you try re-bedding them? Sometimes it helps
squigmang is offline
post #3 of 5 (permalink) Old 12-16-2010, 09:20 AM Thread Starter
how does one re-bed pads?
Thanks.
Rez90 is offline
post #4 of 5 (permalink) Old 12-16-2010, 09:24 AM
kmitch80's Avatar
actually, did you bed them in to begin with?? did you have the rotors turned when you replaced the pads? if not then the new pads would be pointless. i know alot of guys including myself are having issues with squeeling brakes, with oem pads and aftermarket pads. I'm starting to wonder if its the pads or the rotors. the rotors seem to wear really unevenly.
PWR 426
kmitch80 is offline
post #5 of 5 (permalink) Old 12-16-2010, 09:33 AM
rmon's Avatar
I had exactly the same experience after replacing my rear pads. I swapped for the CTS-V pads at about 9k. They were much better for a while now with 20k they definitely squeel but only when cold. One or two stops and they quiet right down but the cold stops are like nails on a chalk board. I'm going to try R1's next time I'm due for brakes.
Rich
Vortech V3, Paramount transmission, and TCM, Dominator convertor, Stage 6 fuel hat, Inertia cam, StainlessWorks LTH, Wavetrac LSD, Modified Magnaflow Cat Back, Modern Muscle ported intake, Arrington 85mm TB, Tuned by Mike at OST
PB 11.56@118.3
street tune, full weight, all season tires, 93 octane
PB 11.17@122.3
Weld 17"wheels, timing and VP110 added, subwoofer left at home
rmon is online now
CTS-V rear, which front pads? 1MEANGT WK1 Brake Discussion 12 04-22-2010 03:32 PM
CTS-V FRONT brake pads? 06blackbeast WK1 Brake Discussion 18 01-08-2010 05:55 PM
Squeal with CTS-V rear pads? DK77 WK1 Brake Discussion 14 11-22-2009 01:04 PM
CTS-V 2009 Brake Pads MaSaFi WK1 Brake Discussion 2 10-08-2009 02:51 PM
Cure for brake squeal? Ceramic pads on rears OEMs on the Front JJJ93z WK1 SRT8 General Discussion 6 02-21-2009 07:54 AM
