Jeep GC SRT8 Specifications - Cherokee SRT8 Forum
post #1 of 12 (permalink) Old 02-11-2006, 09:41 PM Thread Starter
Administrator
Rambit's Avatar
Here are the specs for the Jeep GC SRT8 as copied from a pdf file:
Jeep® Brand Product Information 13
2006 J E E P® G R A N D C H E R O K E E S R T 8
SPECIFICATIONS
GENERAL INFORMATION
Body Style __________________________________________________ _____Four-door sport-utility vehicle
Construction __________________________________________________ ______________ Steel Uniframe®
Assembly Plant ________________________________________ Jefferson Avenue North, Detroit, USA, and
Magna Steyr Assembly Plant in Graz, Austria
EPA Vehicle Class __________________________________________________ _____ Multi-purpose vehicle
2006 MY Introduction __________________________________________________ ____________ Fall 2005
ENGINE: 6.1-LITER, HEMI® V-8
Availability __________________________________________________ ______ Std.—Grand Cherokee SRT8
Type and Description ____________________________________________ 90-degree V-type, liquid-cooled
Displacement __________________________________________________ _____ 370 cu. in. (6059 cu. cm)
Bore x Stroke __________________________________________________ _____4.06 x 3.58 (103.0 x 90.9)
Valve System _______________________________________ Pushrod-operated overhead valves, 16 valves,
eight conventional hydraulic lifters, all with roller followers
Fuel Injection _______________________________________ Sequential, multi-port, electronic, returnless
Construction _________________________Deep-skirt cast-iron block with cross-bolted main bearing caps,
aluminum alloy heads with hemispherical combustion chambers
Compression Ratio __________________________________________________ _________________ 10.3:1
Power (estimated SAE net) ______________________________ 420 bhp (313 kW) @ 6,200 rpm, (69 bhp/L)
Torque (estimated SAE net) ____________________________________ 420 lb.-ft. (569 N•m) @ 4,800 rpm
Max. Engine Speed _____________________________________________6,400 rpm (electronically limited)
Fuel Requirement ____________________________________ Premium 91 octane (R+M)/2—recommended
Oil Capacity __________________________________________________ ___________________ 7 qt. (6.6L)
Coolant Capacity __________________________________________________ ___________ 14 qt. (13.25L)
Emission Controls ______________________________ Dual close-coupled three-way catalytic converters,
quad heated oxygen sensors and internal engine features
Max. Gross Trailer Weight __________________________________________________ ________3,500 lbs.
EPA Fuel Economy mpg (City/Hwy) __________________________________________________ _____ N/A
Jeep® Brand Product Information 14
TRANSMISSION: W5A580 FIVE-SPEED AUTOMATIC
Description _______________ Adaptive electronic control, Performance-tuned AutoStick® driver-interactive
manual control and electronically modulated torque converter clutch
Gear Ratios
1st __________________________________________________ ____________________________ 3.59
2nd __________________________________________________ _____________________________2.19
3rd __________________________________________________ ____________________________ 1.41
4th __________________________________________________ ____________________________ 1.00
5th __________________________________________________ ____________________________ 0.83
Reverse __________________________________________________ ________________________ 3.14
Final Drive Ratio __________________________________________________ ____________________ 3.73
Overall Top Gear __________________________________________________ ____________________ 3.10
ELECTRICAL SYSTEM
Alternator __________________________________________________ ______________________160-amp
Battery __________________________________________________ H7 Case, 730 CCA, maintenance-free
TRANSFER CASE: MD146 SRT
Availability __________________________________________________ _____________________ Standard
Type __________________________________________________ _______________________ Single-speed
Operating Mode __________________________________________________ __ Electronic on-demand 4x4
Low-Range Ratio __________________________________________________ ___________________None
Center Differential Type _________________________ Electronically controlled clutch pack torque transfer
Torque Split, Front/Rear __________________________________________________ ______ Fully variable
FRONT AXLES
Differential Type __________________________________________________ _____________ Conventional
Ring Gear Diameter __________________________________________________ ________7.9 in. (200 mm)
Axle Ratios __________________________________________________ _______________________ 3.73:1
REAR AXLES
Ring Gear Diameter __________________________________________________ _______ 8.9 in. (226 mm)
Jeep® Brand Product Information 15
DIMENSIONS AND CAPACITIES
Wheelbase __________________________________________________ ___________________109.5 (2781)
Track, Front __________________________________________________ __________________ 63.3 (1608)
Track, Rear __________________________________________________ ___________________ 62.1 (1577)
Overall Length __________________________________________________ _____________ 195.1 (4953.3)
Overall Width (width at mirrors) __________________________________________________ _ 84.3 (2138.7)
Body Width __________________________________________________ _________________ 73.3 (1861.8)
Overall Height __________________________________________________ _______________ 66.7 (1694.2)
Load Floor Height __________________________________________________ _____________ 31.1 (789.9)
Sill Step Height __________________________________________________ _______________ 20.1 (511.5)
Ground Clearance
Chassis (fuel tank) __________________________________________________ ___________ 8.5 (215.9)
Front axle __________________________________________________ __________________ 7.5 (190.5)
Rear axle __________________________________________________ __________________ 7.0 (177.8)
Approach Angle __________________________________________________ ____________________ 15.8°
Ramp Breakover Angle __________________________________________________ _______________ 9.7°
Departure Angle __________________________________________________ ___________________ 19.7°
Curb Weight (estimated) _________________________ 4WD Limited: 4,788 lbs. (2171 kg) with 6.1L engine
Weight Distribution, F/R __________________________________________________ ________ 4WD 55/45
Payload (includes occupants and cargo) 4WD 6.1L engine __________________________1,050 lbs. (476 kg)
Frontal Area __________________________________________________ _______ 30.3 sq. ft. (2.82 sq. m)
Drag Coefficient __________________________________________________ ____________________ 0.39
Aero __________________________________________________ _______ 11.7 (Cd x Cross Sectional Area)
Fuel Tank Capacity __________________________________________________ _________20.5 gal. (77.6L)
Jeep® Brand Product Information 16
ACCOMMODATIONS
Seating Capacity, Front/Second __________________________________________________ ________ 2/3
Front Seat
Head room __________________________________________________ ________________ 39.7 (1008)
Leg room __________________________________________________ __________________41.7 (1058)
Shoulder room __________________________________________________ ______________ 59.1 (1502)
Hip room __________________________________________________ __________________ 57.6 (1451)
Seat travel __________________________________________________ _________________ 10.6 (270)
SAE volume __________________________________________________ ______58.02 cu. ft. (1.6 cu. m)
Rear Seat
Head room __________________________________________________ _________________ 39.3 (999)
Leg room __________________________________________________ __________________ 35.5 (901)
Shoulder room __________________________________________________ _____________ 58.5 (1584)
Hip room __________________________________________________ ________________ 45.8 (1163.7)
Knee clearance __________________________________________________ _____________ 1.44 (36.6)
Couple __________________________________________________ ___________________ 33.0 (838.2)
SAE volume __________________________________________________ ______50.84 cu. ft. (1.4 cu. m)
Cargo Volume
Behind rear seat __________________________________________________ __ 34.5 cu. ft. (1.14 cu. m)
Behind front-row seats with rear seats folded _____________________________67.4 cu. ft. (2.00 cu. m)
BODY
Layout _____________________________________________Longi tudinal front engine, transfer case with
Electronic on-demand four-wheel drive
Construction __________________________________________________ ______________Steel Uniframe
SUSPENSION
Front ____________________________________ Short/long independent (SLA), coil springs, gas-charged,
monotube coil over shock absorbers, upper and lower
control arms (“A” arms), stabilizer bar
Rear __________________________________________________ __ Live axle, link coil with track bar, gascharged
monotube shock absorbers, stabilizer bar
STEERING
Type __________________________________________________ ________________Power rack and pinion
Overall Ratio _______________________________________________ 15.8:1—on center, 13.9:1—at full lock
Turning Diameter (curb-to-curb)(a) ______________________________________________ 37.1 ft. (11.3 m)
Steering Turns (lock-to-lock) __________________________________________________ __________ 2.85
(a) Turning diameter is measured at the outside of the tires at curb height. Turning diameters and steering wheel turns,
lock-to-lock may differ with optional tires and wheels.
Another tire size or band may also be used.
Jeep® Brand Product Information 17
BRAKES
Front
Size and type ____________________________ 14.2 x 1.25 (360 x 32.0) vented disc with 1.73 (44 mm)
Four-piston brembo fixed caliper and four channel ABS
Swept area __________________________________________________ ______351 sq. in. (2261 sq. cm)
Rear
Size and type __________________________________13.8 x 1.1 (350 x 28) disc with 1.26/1.10 (32/28)
Four-piston fixed brembo caliper and four channel ABS
Swept area __________________________________________________ _____ 316 sq. in. (2036 sq. cm)
Power Assist Type ________________________________________Single-rate, tandem diaphragm vacuum
TIRES(a)
Front—Standard
Size and type __________________________________________________ _____________ 255/45-W20
Mfr. and model __________________________________________________ _____ Goodyear Eagle RSA
All-season/run-flat
Revs per mile __________________________________________________ _____________________ 721
Rear—Standard
Size and type __________________________________________________ _____________ 285/40-W20
All-season/run-flat
WHEELS
Front—Standard
Type and material ________________________________________Forged/Machined—aluminum wheels
Size __________________________________________________ ________________________ 20" x 9"
Rear—Standard
Size __________________________________________________ _______________________ 20" x 10"
SPECIFICATIONS
Rambit
Rambit is offline
post #2 of 12 (permalink) Old 02-11-2006, 09:53 PM
HEMEEE's Avatar
Re: Jeep GC SRT8 Specifications
Excellent Rambit...
That sure does cover everything now doesn't it!
Linda:
07 300C SRT8- 06 Z51 Vette- 48 Chev 5-window- 55 Chev Nomad
HEMEEE is offline
post #3 of 12 (permalink) Old 02-11-2006, 10:04 PM Thread Starter
Administrator
Rambit's Avatar
Originally Posted by HEMEEE
Excellent Rambit...
Gotta get my post count up here while I have a chance. How about some more smiles? I need one that's sad.
Rambit
WK2 SRT8 Owners - Please post in the
thread!
2005 300C SRT8 - #72 of 252 (excl. 11 pilots) - #10 of 35 Canadian SRT8's built
2008 Harley Davidson FLSTF Fatboy - Vance & Hines Big Shots STGD with FuelPak tune.
2008 Jeep GC SRT8 - Custom Build/Custom Delivered by SRT - 1 of 1 in Canada
2012 JK Rubicon U - 2 1/2" lift, flares, Fox Shoks, Mickey Thompson Baha MTZ P3 35's, JW Speaker LED 8700 Evolution J Headlights etc...
Rambit is offline
post #4 of 12 (permalink) Old 02-11-2006, 10:20 PM
HEMEEE's Avatar
Rambit
There's this one... but I know you prefer this one
You don't need sad ones, you need happy ones!
So there!
HEMEEE is offline
post #5 of 12 (permalink) Old 02-11-2006, 10:23 PM Thread Starter
Administrator
Rambit's Avatar
So there!
That's the one I want, the waving one...where are they?
Picture this - round guy with blue face waving
Rambit
Rambit is offline
post #6 of 12 (permalink) Old 02-11-2006, 10:26 PM
HEMEEE's Avatar
Rambit
I "borrowed" it from 300C
HEMEEE is offline
post #7 of 12 (permalink) Old 02-11-2006, 10:28 PM Thread Starter
Administrator
Rambit's Avatar
I'll have to do the same then. Either that or get happy fast. I now have 10 posts, but who's counting...tied with you. That is unless you post again...hehe.
Rambit
Rambit is offline
post #8 of 12 (permalink) Old 02-11-2006, 10:33 PM
HEMEEE's Avatar
Rambit
Nope, you win!
Oops... sorry, guess not!!
HEMEEE is offline
post #9 of 12 (permalink) Old 02-16-2006, 01:13 PM
Hey, that spec sheet said 420bhp instead of the 415 everyone else is saying...
My Toys -
1995 GMC Suburban 7.4L S/C
2004 Dodge SRT-4 2.4L T/C
carazyguy is offline
post #10 of 12 (permalink) Old 02-16-2006, 02:04 PM
Sur Askdalotte
ResumeSpeed's Avatar
420 is the revised number that Jeep issued a few months after the original preliminary specs came out.
ResumeSpeed is offline
Call it a hellion... HEMEEE Cherokee SRT8 News 29 06-20-2013 10:28 PM
Pricing on Jeep Grand Cherokee SRT8 Announced ekool Cherokee SRT8 News 16 11-23-2011 10:15 AM
Fire-Breathing 4x4 - Australia HEMEEE WK1 SRT8 General Discussion 1 02-11-2006 04:59 PM
