What To Do When Your Car Breaks Down; Advice From AAA - Cherokee SRT8 Forum
Cherokee SRT8 News This section contains news relating to the Jeep Grand Cherokee SRT8 as well as site news. Only administrators may START threads in this section.
post #1 of 1 (permalink) Old 08-18-2011, 02:15 PM Thread Starter
Moderator
It's easy to panic when you're stranded by the side of the road after your car breaks down or you're late for an early morning meeting and it just won't start. Helping you keep your cool and stay safe, AAA has some advice for stranded motorists.
In a case where your car just won't start, the problem may lie with the battery. It could be that it's discharged or there's a poor connection. Open the hood and check out the battery to see if it's securely mounted in place and see if the cable clamps are connected to the battery. Cable clamps that are loose or corroded may be the problem. Clean the corrosion from the battery terminals and cable clamps and make sure the clamps are secured tight. If that doesn't work, check to see if your car is fully in park and that there's enough fuel in the vehicle. If all else fails, it's time to call in a road service provider.
If you ever find yourself experiencing car problems while driving, your first priority is pulling off to a safe location. This should be away from the flow of traffic, and you should stay in your car while waiting for roadside assistance. Once you're safe, you can call your road service provider. Take a look around and take note of your surroundings, landmarks and signs anything that will help roadside assistance find your location. There are even certain smartphone apps (such as AAA TripTik Mobile and AAA Roadside) that will send your GPS location right to your roadside assistance provider.
More: What To Do When Your Car Breaks Down; Advice From AAA on AutoGuide.com
AutoGuide.com is offline
Breaks sqeaking jbSRT8 WK1 Brake Discussion 10 05-09-2010 03:59 PM
Sqealing Breaks..... Rez90 WK1 SRT8 General Discussion 7 03-31-2010 08:09 PM
breaks/tires mikem WK1 Troubleshooting / Problems Discussion / Dealer Service 0 11-09-2009 09:02 AM
PPP breaks its own record. Power Ported Performance WK1 General Performance Discussion 9 08-13-2007 02:21 PM
squeaky breaks sleary117 WK1 Brake Discussion 3 07-20-2007 07:19 AM
