Fall Special!! 426 New Hemi Legend Stroker Shortblock! $4399 NO CORE! - Cherokee SRT8 Forum
Power Ported Performance
post #1 of 23 (permalink) Old 10-16-2012, 03:37 PM Thread Starter
Power Ported LLC has been the late model HEMI industry leader and innovator since the release of the 2005 SRT-8. The first to market with a running 426 stroker shortblock option, we were also the first to deliver CNC ported cylinder heads and tunable custom camshaft grinds. We have customers globally and delivery the best products at the most competitive prices.
These shortblocks with Power Ported Heads and cams easily can make well over 500 HP naturally aspirated and much higher with forced induction and optional lower compression pistons. Most customers with forced induction are realizing HP ranges from 600 to 1000 plus (specific part combos required).
The short block assembly is one of the most critical procedures in any engine build.
No one understands that better than Power Ported Performance.
In an industry where close is good enough, PPP takes a different approach. We believe the best method is a solid foundation. If the block and short block assembly is done right, then bolt on power upgrades can be comfortably added in the future. As your desire for performance increases, the money can be spent on the upgrade and not on the short block again.
All of our builds start with bare 6.1 blocks from Mopar. This is the same block that is running in excess of 1000+hp in other vehicles across the country. The crank is micropolished using a 15 micron belt, cleaned and checked. With all of our blocks being align honed, the bearing bores for the crank are perfectly straight and sized to match the crank journal diameters. The align honing is a step that the majority of industry chooses to skip due to added costs.
All of the bearings are remeasured for thickness and matched to each journal/bore combination to achieve perfect clearance. No plastigage is used, due to inaccurate reading.
No short cuts are taken due to the rod being the second highly stressed part in the engine (behind the valve spring). Each rod is inspected, re-torqued for repeatability, and sized for exact clearance.
Whether you choose a shelf stock or custom piston, we can provide it. Each piston is remeasured, pin fitted and inspected. The cylinders are torque plate honed to fit each piston. Each piston ring is file-fitted to the cylinder it is going in for an exact ring gap to minimize leakage.
The assembly is done one at a time using dedicated tooling and inspected after each step. The same dedication goes into a street engine as goes into our race only engines. It is possible to throw the parts together and run for a while, just as you can drive on a bent rim if you put enough weights on it, but we choose to do it right the first time for maximum horsepower and durability.
Power Ported LLC shortblocks come standard with Durabond camshaft bearings and Cleavite Main and Rod Bearings.
The pistons offer excellent skirt wear and minimal noise or rock. The valve pockets are radiused for detonation resistance and increased flow around the valves. Skirt coatings for lower friction, reduced noise, and superior life.
While our shortblocks may cost less than the competition, you get more for less as we deliver excellence, use durable industry respected and recognized parts and we stand behind every single shortblock that goes out the door.
420 to 426 cubic inch Stroker shortblock: 10.3 to 1 Compression
(additional piston compression options available)
- PROFESSIONALLY ASSEMBLED SHORTBLOCK
- CALLIES 4.050" 4340 FORGED STEEL CRANKSHAFT
- CALLIES FORGED STEEL H-BEAM CONNECTING RODS
- MAHLE FORGED FLAT TOP PISTONS
- MAHLE PLASMA MOLY RING SET
- CLEVITE/ACL MAIN & ROD BEARINGS
- DURABOND CAMSHAFT BEARINGS
- DIGITALLY BALANCED WITHIN 1/2 GRAM
We offer too many late model hemi upgrades to list. Contact us with any questions for the parts you need from top brand manufacturers at the most competitive prices.
We welcome the opportunity to serve your customer needs.
Please let us know if there is anything else we can do to earn your valued business.
Call or PM Julian@PowerPorted for more info.
859.907.6630
Julian@PowerPorted is offline
post #2 of 23 (permalink) Old 10-17-2012, 02:16 PM Thread Starter
bump for hump day
post #3 of 23 (permalink) Old 10-17-2012, 03:48 PM
LASRT's Avatar
Very good deal. Good luck with sale.
LASRT is offline
The Following User Says Thank You to LASRT For This Useful Post:
Julian@PowerPorted (10-18-2012)
post #4 of 23 (permalink) Old 10-18-2012, 11:53 AM Thread Starter
A good deal indeed... thx bud....
post #5 of 23 (permalink) Old 10-19-2012, 02:26 PM Thread Starter
TGIF everyone!!! bump...
post #6 of 23 (permalink) Old 10-22-2012, 12:24 PM Thread Starter
Happy Monday... bump
post #7 of 23 (permalink) Old 10-23-2012, 02:19 PM Thread Starter
bump for tuesday
post #8 of 23 (permalink) Old 10-24-2012, 12:44 PM Thread Starter
Hump day bump
post #9 of 23 (permalink) Old 10-25-2012, 03:12 PM Thread Starter
Bump BUMP bump
post #10 of 23 (permalink) Old 10-26-2012, 02:49 PM Thread Starter
Happy Friday Hemi Lovers! Bump
Needed:6.1 Hemi core, can be from any SRT BuilderBill WK1 General Performance Discussion 16 05-29-2007 12:11 PM
