Lowered jeep - Page 2 - Cherokee SRT8 Forum
post #11 of 65 (permalink) Old 06-02-2012, 05:33 PM
MIKE SRT8's Avatar
Love that video, the Jeep looks superb!
MIKE SRT8 is online now
post #12 of 65 (permalink) Old 06-02-2012, 05:37 PM
cmn1's Avatar
Did you just cut the springs like the other guy did?
cmn1 is offline
post #13 of 65 (permalink) Old 06-02-2012, 06:46 PM Thread Starter
KINGMONKEY's Avatar
The camber like stated by (adgate2) The springs are easy to make,Now I know what the delay is in releasing the aftermarket springs.If you go to lower than 2" in the rear adgate2 says 1.25" I hope he is wrong about the rears.If the camber will not adjust the inside of the rear tires will be chewed / \.I got spooked and stopped on the front springs so I only did the rears.I will know more monday.I could have done an airbag system (been there done that!!) But the ride is way different and cant be stiff .It's either up in the air or down on the ground or the ride is to soft.I had the spring shop who doesn't mess around cut (1) ring,Grind and spiral it back to the OEM position it looks exactly the same minus a ring.The Sport and Race dial works perfectly Zero difference in ride.Because it's Saturday.On monday I have to go to the alignment shop that can do custom work if the camber has to be modified.This Jeep has alot of weird details even with the exhaust valves have delayed a aftermarket exhaust.PS the Jeep I believe it will level out once the rear camber is adjusted so I may leave the front alone.There is a difference now of less that a 1/2" front to the back
NEVER ENOUGH
KINGMONKEY is offline
post #14 of 65 (permalink) Old 06-02-2012, 11:58 PM
Ahhh, looks ridiculous! As mentioned, that video is sick and sounds so nasty!!
2008 Jeep SRT-8 Red Rock 2.4 Whipple SOLD
2013 Ford Raptor Super Crew 6.2 SOLD
BOYCHIKS is offline
post #15 of 65 (permalink) Old 06-03-2012, 03:31 AM
Darn..A good wicked Jeep SRT8 2012, I've ever seen..Kudos..Magnifique..!!
Great Sound on the exhaust note..lovin it.!
Azmi886 is offline
post #16 of 65 (permalink) Old 06-03-2012, 10:43 AM Thread Starter
KINGMONKEY's Avatar
Chris at LPM a vendor on the site has the fix
Chris@LPM
Adj rear hard pan bar
Chris@LPM]We will also be introducing Upper and Lower Adj Control Arms (single and dual) this week. 450.00 for the single and 600.00 for the dual plus shipping.
Adj Pan Bar
Upper and Lower Rear Control Arms
Originally Posted by KINGMONKEY
Originally Posted by Chris@LPM
K,
We sell the adj pan hard bar for the Jeeps to help recenter the rear end. 199.00 pluse shipping.
Thanks
Chris
Chris
Thanks for reading that post and the answer I will let you know on monday .The shop may have it.If not I will get it
Jeff
[/QUOTE]
post #17 of 65 (permalink) Old 06-05-2012, 08:22 AM
Well, it is Tuesday. Updates?
Noah B.
2012 Wk2 SRT8 Mineral Gray
Debadged, Rebadged, Billet Technology catch installed at 900 miles, BWoody CAI installed at 1500 miles, Borla ATAK exhaust installed at 5650 miles, Fastman 85mm Throttle Body installed at 8950 miles
Need4spdnb is offline
post #18 of 65 (permalink) Old 06-05-2012, 10:44 AM Thread Starter
KINGMONKEY's Avatar
They are doing the front as we speak they got the camber in the rear 0.5.Now the front is being dropped 3/4" that may make the camber go off again
post #19 of 65 (permalink) Old 06-05-2012, 11:52 AM
Gibby's Avatar
Sweet. 3/4 of an inch should be perfect!
2015 SRT Grand Cherokee
2004 Ford F150 SVT Lightning
2013 BMW 550i M-Sport
Gibby is offline
post #20 of 65 (permalink) Old 06-05-2012, 01:40 PM
Stimeybob's Avatar
The video the great, the wheels look perfect on it, 3/4 on the front will be just right...
07 GC SRT8
DiabloSport Predator, Volant CAI, Proxes STII 275/315, Stoptech, Eibach Pro Kit
Stimeybob is offline
lowered jeep ? chime in brianm WK1 SRT8 General Discussion 25 02-25-2013 01:16 PM
Post pix of ur Jeep if its lowered. Blackest08 Pics & Video Showoff Section 43 04-14-2011 02:13 PM
**Jeep NA Record Lowered 11.150 @ 121.06 ** junior666 Track Talk 45 01-19-2011 06:43 PM
**Lowered Jeep Even More!!** junior666 Pics & Video Showoff Section 27 04-02-2010 02:37 AM
Lowered Jeep Pics... Harrison@Stage6 Pics & Video Showoff Section 44 10-06-2008 10:36 PM
