Bwoody Washer Tank Fix WK2 - Cherokee SRT8 Forum
post #1 of 80 (permalink) Old 05-27-2012, 08:29 PM Thread Starter
Mongoose9400's Avatar
Had some time today to figure out a better washer tank solution. I've seen this coolant tank at the auto parts store before and figured I could make it work with some modding.
http://www.oreillyauto.com/site/c/de...nk+-+universal
I bent the mounting tabs to the side some to make it fit. Used a hole saw, 1", and drilled a new port for the low fluid sensor. Then I drilled a new hole (27/64th) for the factory pump. Low fluid sensor is on the backside next to the driver headlight. Washer pump in located on the bottom of the tank. I used a couple zip ties just in case to hold the factory pump in place. But, the fitment is snug and takes some effort to pull the pump out. I thought about using an epoxy to mount the pump, but i want to keep it easily removable. Otherwise a new pump is around $80. You can't see the zip ties on the underside, so no one will know
The rest is pretty simple. Mark the location for the bracket and drill two small pilot holes for the mounting screws. Then screw the bracket in place. I used the factory washer pump wiring as it reaches the pump with a little extra length to spare. I used the bwoody harness with the low fluid sensor connector to reach the new location. The factory doesn't have enough length. Then just plug the washer lines back into the pump. Labeled "F" and "R" Front and Rear. The front line is the hard plastic, the rear is the flexible line.
The coolant tank as a nipple top and bottom that need to be plugged. I just used some of the supplied hose in the kit and bent it over on itself and zip tied it for now. The lower port isn't really seen. I'll figure something out for the top port to make it look cleaner. Transfer the factory washer cap over to the new tank. It fits, but is slightly larger then the supplied cap. It seems to stay on though. I used a zip tie for now to attach the cap to the bracket incase it falls off. I will make a cable for it later.
Here are the installed pics. Needs a couple finishing touches, but it works like OEM again. Simple to do, took me about an hour to figure it out. All the work can be done from the engine bay assuming your connections can be reached. I left mine easy to get to from when I first installed the bwoody.
Let me know what you guys think. I think it looks better than the bwoody setup. Now I got the bwoody, factory washer function, larger capacity, and better looks. Win Win in my book.
Zac
SOLD 2007 Silver Jeep SRT8
Mongoose9400 is offline
Need4spdnb (06-07-2012)
post #2 of 80 (permalink) Old 05-27-2012, 09:56 PM
Speed Junkie
Brooksie's Avatar
Damn Zac where you find the energy after your trip?
Looks like a great fix good job!
2016 GC SRT Granite
2014 GC SRT Brilliant Black-Sold
2012 GCSRT8 Brilliant Black-Sold
Brooksie is offline
post #3 of 80 (permalink) Old 05-28-2012, 12:33 AM
YKPizzaGuy's Avatar
Send a message via MSN to YKPizzaGuy
Great job man. I might need you to put the parts together and ship them to me again
Wise men learn more from fools than a fool learns from the wise
LOL my mod list got to long to be in my Signature
MOD KING
YKPizzaGuy is offline
post #4 of 80 (permalink) Old 05-28-2012, 01:02 AM
Nice job Zac. You're turning into quite the pioneer with the WK2. Just one suggestion, maybe paint the holder & tank black. It would blend in nicely IMO. You could leave a half inch strip unpainted to see the fluid level.
J&D's SRT's is offline
post #5 of 80 (permalink) Old 05-28-2012, 06:37 AM Thread Starter
Thanks guys.
Found the energy because I wanted it done. The supplied setup works, but not as well as the factory. The supplied pump doesn't have enough a$$ to spray the windshield well at highway speeds. It may spray 40% of the W/S. For comparison while parked and washing the W/S the supplied pump covers 75% of the W/S, the factory pump covers 110% of the W/S and then some.
I thought about painting it black, but passed on it for now. I only had a couple hours to work on it so I wanted it in and working. Later down the road I can pull it out and paint it.
post #6 of 80 (permalink) Old 05-28-2012, 09:11 AM
Looks awesome Zac. I wish I had your time to tinker.
You are right, the supplied Bwoody tank does "work", but the water pressure coming out is weak. I didn't think it would be a big deal, but when you never wash your car and the windshield is full of bugs and crap, having windshield fluid sprayed all over does make a difference.
As always, thanks for your detailed write up and pics, it is appreciated.
Noah B.
2012 Wk2 SRT8 Mineral Gray
Debadged, Rebadged, Billet Technology catch installed at 900 miles, BWoody CAI installed at 1500 miles, Borla ATAK exhaust installed at 5650 miles, Fastman 85mm Throttle Body installed at 8950 miles
Need4spdnb is offline
post #7 of 80 (permalink) Old 05-28-2012, 09:21 AM Thread Starter
My trip home with all the bug carnage is what really showed the ineffectiveness of the bwoody setup. I just couldn't clean the bug splatters from my w/s no matter how much i tried. Every fuel stop I had to manually clean the w/s.
post #8 of 80 (permalink) Old 05-28-2012, 12:29 PM Thread Starter
Cut the nipple off and used a cheap harbor freight soldering iron type plastic welder to close the hole up. About $15 for the welder. Used some picture frame wire and a couple crimp sleeves to attach the washer cap. Used a stick on wire tie anchor on the backside of the tank.
ImageUploadedByAutoguide1338226161.497877.jpg   ImageUploadedByAutoguide1338226173.298262.jpg
post #9 of 80 (permalink) Old 05-31-2012, 11:14 AM
cheaperdude's Avatar
Send a message via MSN to cheaperdude
I tried to contact someone in Bwoody about a possible fix in the near future as to where we can get the same performance from both CAI and washer fluid tank, have not heard anything yet, anyone hear anything?
cheaperdude is offline
post #10 of 80 (permalink) Old 05-31-2012, 11:19 AM Thread Starter
Someone recently mentioned that they may work on a fix. I know I voiced my opinion to them over the phone a few months back. I had some other ideas in the works, but I think I'm happy with this solution. It looks clean and works like OEM.
I should snap a pic from further away. It's tucked away and you don't see it at all unless your right up in the engine bay.
Tags
bwoody, washer tank, windshield
Modified Washer bottle w/ BWoody CAI steveSRT WK2 SRT8 Intake/Exhaust Discussion 10 05-07-2012 12:43 AM
Washer Jet Relocation Relwarc WK1 Interior/Exterior Visual Modifications 17 02-23-2012 06:21 PM
HOW TO: Washer Jet Relocation Relwarc Tech Tips - DIY - How-To 2 03-16-2011 09:32 PM
HOW TO: Washer Jet Relocation Relwarc Tech Tips - DIY - How-To 1 03-16-2011 09:32 PM
Rear Washer BILLSHOE WK1 SRT8 General Discussion 8 07-23-2007 10:13 PM
