LC1 Issues - Cherokee SRT8 Forum
post #1 of 31 (permalink) Old 11-19-2012, 05:55 PM Thread Starter
rconner's Avatar
LC1 Issues
I have been working on getting the LC1 installed all day. I cannot locate a good twelve volt switched wire. I have found a couple that read 12 volts but they are not enough to heat up the sensor. I even spliced it into the cigarette lighter?? What gives? Does anybody know where to find a wiring schematic for the WK2? Or where I should hook up the 12v wire. Thanks
rconner is offline
post #2 of 31 (permalink) Old 11-19-2012, 06:15 PM
Mongoose9400's Avatar
In for answers
Zac
SOLD 2007 Silver Jeep SRT8
Mongoose9400 is offline
post #3 of 31 (permalink) Old 11-19-2012, 06:34 PM
Knuckles's Avatar
Thats weird.... I have mine connected to the Cig lighter with a 5 amp fuse and don't see why it should be any different on the WK2 as I have a WK1. Have you tried a constant 12 volt source just to see if the LC1 works at all?
Knuckles
Knuckles is offline
post #4 of 31 (permalink) Old 11-19-2012, 06:46 PM Thread Starter
rconner's Avatar
Thats funny you ask, I hooked it up to the cig lighter in the center console, 12v all the time, and same thing. Just a flashing light.... I am so pissed right now. I spent all day fuc@#$% with this thing, the jeep is still on jack stands, dash torn apart, hands scraped up, mind blown, LC1 not working, wine not kicking in yet, can't take it much longer................
LC1 gets warm not hot..
rconner is offline
post #5 of 31 (permalink) Old 11-19-2012, 06:49 PM
Do you have the install guide? Page 20/21 shows some troubleshooting tips.
post #6 of 31 (permalink) Old 11-19-2012, 06:52 PM
Page 8 shows a specific first time start up procedure of the sensor. Did you follow that?
post #7 of 31 (permalink) Old 11-19-2012, 06:58 PM
DemonPerformance's Avatar
Hey Rob, sorry I missed your call earlier, I see you've run into more of a wiring headache, I'll give you a buzz in the morning, also give innovate a shout, they're still open for a lil bit since they're out in Cali!
Skip Demon Performance
1-888-312-3666
DemonPerformance is online now
post #8 of 31 (permalink) Old 11-19-2012, 06:58 PM Thread Starter
rconner's Avatar
Originally Posted by mongoose9400 View Post
do you have the install guide? Page 20/21 shows some troubleshooting tips.
yep.............
rconner is offline
post #9 of 31 (permalink) Old 11-19-2012, 06:59 PM Thread Starter
rconner's Avatar
page 8 shows a specific first time start up procedure of the sensor. Did you follow that?
yup..............Did that so many time and it was so cold out that after unhooking the sensor from the lc1 so many times the little clip that holds the to together decided to break off.... So now when I finally get it right I will have to tape the two together so they will not vibrate apart...
It was so much easier on my WK1.............
rconner is offline
post #10 of 31 (permalink) Old 11-19-2012, 07:05 PM Thread Starter
rconner's Avatar
Thanks skip, I have talked to them a couple of times. They told me to use the cig lighter. tried that and no go. I have been using my multimeter, with a sharp point on the pos to double check 12v. I have tried four different 12 volt sources with no luck. Each time spicing into my new 2012 jeep wiring harness!!!! Gotta love putting electrical tape on such a nice harness! Hopefully tomorrow I will figure something out. I have to work tomorrow afternoon so lets hope I figure out something early.
I thought I was going to hook u guys up with a easy install of the LC1. The first wire I found was super easy to get to, had a 12 volt signal, looked to be at least 12 gauge. Who knows maybe I screwed something else up...
BTW, innovate said not to hook it up the the ignition?
rconner is offline
having some issues 2quic4u WK1 Troubleshooting / Problems Discussion / Dealer Service 2 07-15-2012 08:11 PM
Serious 4wd issues here...HELP?!! SRT8ScoTT WK1 Troubleshooting / Problems Discussion / Dealer Service 6 05-08-2012 03:39 PM
TPMS issues and replacement issues brianm WK1 Troubleshooting / Problems Discussion / Dealer Service 2 12-14-2010 06:18 AM
LED Issues, HELP! SoonToBeSRT WK1 Troubleshooting / Problems Discussion / Dealer Service 3 08-11-2009 03:16 PM
HID issues. Matt McKenzie WK1 Troubleshooting / Problems Discussion / Dealer Service 53 11-19-2008 05:56 AM
