Coolant spray - Cherokee SRT8 Forum
post #1 of 8 (permalink) Old 12-10-2012, 06:25 AM Thread Starter
Coolant spray
Does anybody else have this problem. There is coolant spray all over the passenger side of my engine bay.
barish93 is offline
post #2 of 8 (permalink) Old 12-10-2012, 06:41 AM
nyjoed's Avatar
Prolly the radiator cap. Remove it when it cools down and turn it upside down. U will see the 2 tabs that crab the neck of the radiator. Take a pair of pump pliers and bend them down about half way so when I tighten it it grabs tighter. Also if u installed a new Tstat check around the water neck to make sure there's no leaking around it. If so the gasket can either be pinched or went bad OR the bolts aren't tight enough but don't over tighten them eiter!!
72mm FOGLIGHT TWIN TURBO
nyjoed is offline
post #3 of 8 (permalink) Old 12-10-2012, 06:42 AM
roadboy's Avatar
Did you just change your thermostat? Check the upper rad hose. It is a common failure. If you changed your thermostat, your radiator cap may need to be changed. Do a search,the part number has been mentioned afew times. I'm on my phone or I would put up a link.
11.79@113
Electric exhaust cuts outs
roadboy is offline
post #4 of 8 (permalink) Old 12-10-2012, 07:04 AM
kmartel's Avatar
Or just replace the rad cap with a Stant or Gates brand locking unit. Solved my issues right quick and for less than $20.
2010 Inferno Red
BT catch can, JET 180 TSTAT, Eibach Springs, MOPAR CAI, Borla S, Full 20% TINT, NT05 275/315 combo, Satin plasti-dipped wheels, Black Ops FG Venom hood, Shorty antenna, rear fog harnesses, escort 9500ix , CF wrapped chrome, dual pillar pod with aeroforce interceptor gauges
BOOST to come....
kmartel is offline
post #5 of 8 (permalink) Old 12-10-2012, 07:16 AM Thread Starter
I haven't changed the thermostat yet. Was planning on doing it soon. I did some reading on some other treads and I think the new locking radiator cap should solve it. Thanks for all the input and help.
barish93 is offline
post #6 of 8 (permalink) Old 12-10-2012, 07:29 AM
Rose City GC SRT8's Avatar
Use a Stant 18# radiator cap. Lots of old threads on this subject.
DAVE - Steel Blue '07, Mopar exhaust, Volant CAI, DCX depot CMR tune, Jet T-stat, BWoody springs and links, aftermarket camber-compensating upper control arms
Rose City GC SRT8 is offline
post #7 of 8 (permalink) Old 12-10-2012, 09:17 AM
mustbf8's Avatar
This is a good fix for a WK1...this is in the WK2 section. Which do you have?
Craig 08 GCSRT8-- Eibach's, BT Catch Can, Custom Whipple Setup, Shorty Antenna, 180tstat, other appearance goodies by BT and carbon fiber accents... Jerseyboy Tuned with a custom wrapped Alcantara steering wheel
11.9 @ 116
SRTBEAST
2013 Modern Street Hemi Shootout Stock Points Champion
mustbf8 is offline
post #8 of 8 (permalink) Old 12-10-2012, 09:25 AM Thread Starter
Wk2
barish93 is offline
coolant spray nyjoed WK1 Troubleshooting / Problems Discussion / Dealer Service 26 07-10-2012 08:09 PM
YAY!!! My coolant spray is gone. hawkman996 WK1 SRT8 General Discussion 17 08-08-2011 01:44 PM
Coolant Spray Fix Sheri'SRT8 WK1 Troubleshooting / Problems Discussion / Dealer Service 8 11-04-2008 10:17 AM
UD Pulley/No coolant spray gculver WK1 General Performance Discussion 7 09-27-2008 09:34 PM
Coolant spray.... again!! Tex_SRT8 WK1 Troubleshooting / Problems Discussion / Dealer Service 17 12-28-2007 08:05 AM
