Fox Body Mustang Brake Question - Cherokee SRT8 Forum
Other Vehicle Makes & Models Discussion This section is for the discussion of all non Chrysler Corporation vehicle makes and models.
post #1 of 6 (permalink) Old 11-27-2012, 07:01 PM Thread Starter
2012srt's Avatar
I know I have read many of you were/are mustang enthusiests as well. I have an 89 mustang gt that i swapped the rear from drum to disc brakes. The rear brakes seem to constantly be dragging. I have googled to try and find if anyone else had the same issue. I bought new booster new master cylinder and the brakes seem to work fine. except they constantly drag on the rear. I have and adjustable proportioning valve in place. I believe that i need a residual pressure valve to stop this? anyone have any knowledge on this issue? I have asked on the mustang forum but the people/site sponsors dont give out knowledge for the do it yourself guy.
2012srt is offline
post #2 of 6 (permalink) Old 11-28-2012, 03:03 AM
BurgundySRT's Avatar
What year/model mustang did you get the rear disc setup from? I have a '93 Cobra that already came with disc brakes, but once it hit 10's in the 1/4 I put '03 brakes on all four corners, and for some reason they were dragging in the rear as well. I had to remove the power brake pump and put a manual one in and it unlocked the rears.
BurgundySRT is offline
The Following User Says Thank You to BurgundySRT For This Useful Post:
2012srt (11-28-2012)
post #3 of 6 (permalink) Old 11-28-2012, 05:32 AM Thread Starter
2012srt's Avatar
I believe they are the 93 cobra rear disc.. But its been 3 years since i purchased everything and a year and a half since I installed. I don't drive it much and they don't drag to badly but Im thinking of putting a blower on it and want to fix all of the small issues first
2012srt is offline
post #4 of 6 (permalink) Old 11-28-2012, 08:01 AM
Premium Whore (Lifetime)
StangSlayerMA's Avatar
When you converted the rears to disc, did you change out the master cylinder to a 93 cobra unit? The stock master cylinder is setup for drum rears, and has a smaller overall bore, as well as a smaller outlet to the rear brakes.
93 Cobra:
http://www.latemodelrestoration.com/...aster-Cylinder
Standard master cylinder:
http://www.latemodelrestoration.com/...er-For-23L-50L
StangSlayerMA is offline
The Following User Says Thank You to StangSlayerMA For This Useful Post:
post #5 of 6 (permalink) Old 11-28-2012, 12:54 PM Thread Starter
2012srt's Avatar
Yes cobra brake booster and master cylinder
2012srt is offline
post #6 of 6 (permalink) Old 11-28-2012, 02:06 PM
That's odd man that you have any dragging on a stock '93 setup. Like I said I had to switch to a manual pump, but that was because I put on parts that were 2 generations later. Stangslayer makes the valid point, but if you have all that then it doesn't make sense besides maybe the system wasn't bled enough, or the calipers are just shot and not opening up all the way.
Valve Body compatability question SANTEEN WK1 Suspension / Driveline Discussion 2 10-30-2012 08:51 AM
removing throttle body question roadboy WK1 Intake/ Exhaust Discussion 5 08-13-2011 02:58 PM
Throttle Body Question GotStroke? WK1 Intake/ Exhaust Discussion 12 09-21-2007 09:33 AM
Question for you Mustang guy's Shooter_t1 Other Vehicle Makes & Models Discussion 25 03-17-2007 12:38 AM
Question about body kit dondula WK1 SRT8 General Discussion 4 06-18-2006 07:19 PM
