How To: Key Fob Refurb 2008-2010 - Cherokee SRT8 Forum
Tech Tips - DIY - How-To Member created and Member approved! From modifications to maintenance, find the step-by-step info you need here. (Only Moderators can post)
 1Likes
  • 1 Post By SpoolinUp
post #1 of 1 (permalink) Old 09-16-2013, 01:08 PM Thread Starter
Just put new outer shells/buttons on my fobs so I figured I'd make a quick How-To while I was at it.
Parts/Tools:
Small Flathead
Superglue
3x 4" Zip Ties
Vice, alligator clip, or similar
Pencil Eraser or Mr Clean Magic Eraser
1. Go to eBay and search "Fobik" or find the member "extra-partss". Locate the shell with the same options that your current fob has.
2. Remove the backup key via the little slider on the bottom of he fob. Now pop off the back small cover with a flathead screwdriver and remove the battery. Next, pry the case apart with the small flathead. Mine was glued together so I ended up partially destroying the case. Oh well, all you need is the circuit board.
3. My fob kit came with the contactors, the small circular pieces on the buttons that make the button actually work. I opted to use the factory ones because they will probably be more reliable. Carefully pull them off the old buttons and place them on the new buttons. They will want to fall off so sit the buttons face down inside the front case.
4. Clean the contacts with the Pencil Eraser or Magic Eraser.
5. Put the circuit board onto the buttons and get the super glue and zip ties. Put superglue on the pegs that connect the halves and along the inner lip of the fob all the way around. Be careful not to get any on the outer lip or it may turn a gross white color.
6. Zip tie as seen below and place in vice. Optionally use an alligator clip or small chip clip. Leave for 15 minutes or so.
7. Insert battery, put the small cover back on and put the key back in, you're done.
Final thoughts:
Looks good but the edge of the black button closest to the Panic button is a little red. Who knows if they are all like this or not. Either way it's way better then my beat stock one.
More photos.
Slicko likes this.
-Matt
Procharged 08 BB SRT-8
SpoolinUp is offline
The Following User Says Thank You to SpoolinUp For This Useful Post:
TSINND (10-02-2013)
Closed Thread
2010 Key Fob...Works sometimes! QuickOne WK1 Troubleshooting / Problems Discussion / Dealer Service 212 03-20-2017 07:43 AM
HELP! Key-fob doesn't work / Key-fob stuck in ignition / Won't start PhilT3 WK1 Troubleshooting / Problems Discussion / Dealer Service 13 05-01-2015 08:54 AM
2010 srt 8 remote key fob issue Kazim7 WK2 SRT8 General Discussion 9 06-27-2012 09:11 AM
Installing a 2008+GC Key Fob on a 2006 GC?? DainBramaged206 WK1 Interior/Exterior Visual Modifications 3 08-08-2010 10:15 PM
