WK1 Program keys DIY - Cherokee SRT8 Forum
Tech Tips - DIY - How-To Member created and Member approved! From modifications to maintenance, find the step-by-step info you need here. (Only Moderators can post)
 1Likes
  • 1 Post By MeanHemiSRT
post #1 of 1 (permalink) Old 11-23-2013, 07:40 AM Thread Starter
MeanHemiSRT's Avatar
1 ). Insert one of the preprogrammed keys into the ignition cylinder of the Jeep Grand Cherokee. Turn the key to start the vehicle for three to five seconds before turning it off. Remove the preprogrammed key from the ignition cylinder.
2 ). Insert the other preprogrammed key into the Jeep Grand Cherokee's ignition cylinder. Turn the ignition to the "On" position, listen for a chime to sound and watch for the vehicle's lights to flash. When you hear the confirmation chime and see the lights flash, turn the preprogrammed key to the "Off" position and remove it from the ignition cylinder.
3 ). Insert a new, unprogrammed key into the ignition cylinder of your Jeep Grand Cherokee. Turn the ignition to start your vehicle within one minute of inserting the key in the ignition cylinder. Listen for the confirmation chime and watch for the vehicle's lights to flash. Turn the key to the "On" position again and wait three seconds before turning off the ignition and removing the newly programmed key from the ignition cylinder.
TX-SRT likes this.
2008 SRT8 Brilliant Black/ Volant intake/Modern Muscle 87mm TB/180 Tstat/ Borla S/Toooned/ BT Catch Can,SS braided lines/ 6000k Hids / Black Alcoas/ 275.315 NT05/ bwoody 1.3 springs/ Stage 6 shocks/bwoody endlinks/ 15% tint/ led tail lights/ full led interior/ exterior trim color matched/ carbon fiber spoiler/ carbon fiber half covers.
MeanHemiSRT is offline
The Following 2 Users Say Thank You to MeanHemiSRT For This Useful Post:
HoustonJGCSRT8 (11-23-2013), JeepFreak12 (11-27-2013)
Closed Thread
DIY: Spare tire setup (WK1) Jasonlmarsh Tech Tips - DIY - How-To 0 11-06-2013 01:16 PM
DIY: Install a WK1 Fore Fuel System LAFNGA5 Tech Tips - DIY - How-To 0 07-09-2013 05:16 PM
DIY: WK1 LC-1 to Trinity Install Mikla Tech Tips - DIY - How-To 0 04-27-2013 07:45 PM
How To: WK1 DIY Spring swap gspfunk Tech Tips - DIY - How-To 0 10-08-2012 01:12 AM
DIY (WK1): A/C & Heater Actuator Gear SRT8Girl12 Tech Tips - DIY - How-To 0 06-06-2012 11:03 AM
