HELP!!!!P2138 code :-( - Cherokee SRT8 Forum
post #1 of 37 (permalink) Old 11-21-2012, 02:45 PM Thread Starter
RED_ROCK_SRT's Avatar
My buddies rig had his ceck engine light on i belive and this code came up
,"P2138 throttle/ pedal position sensor switch d/e voltage".
Wtf is that everytime he wot hos rigg it bogs at high rpms we tried switching his t/b with another one off of my buddies rigg and same thing can anyone chime me in on this any input guys thanxxx!!
RED_ROCK_SRT is offline
post #2 of 37 (permalink) Old 11-21-2012, 03:03 PM
hotrodcalvert's Avatar
sensor underneath the pedal may be faulty, its a cheap fix, start with the easy stuff first and go from there
Colby
The "Silver Bullet" ---- 2006 Jeep SRT8 - Gone but definitely not forgotten
hotrodcalvert is offline
post #3 of 37 (permalink) Old 11-21-2012, 03:15 PM Thread Starter
Ok tnx i will try that i will post back in a bit thatnxx bro!!
post #4 of 37 (permalink) Old 11-21-2012, 03:54 PM
I had same problem
Easy fix for me... I had exact same problem and symptoms, ended up being water and corrosion at the connector to the ecu... cleaned up contacts plugged back in and no more issues... hope this helps
07 Steel Blue JGCSRT8 * K&N CAI * BT CC * Spectre Racing Upper Rad Hose * R1 Concepts Prem D&S Rotors W Stop Techs * HF Cats * Borla S * Nitto 420's * Paramount HIGH Performance, High Torque TC By Builder BILL * Magic Performed by Kaila with a Spell from Grand Master Wizard JerseyBoy!!!! PB ?? 12.244 @ 109.44
SwassAC is offline
post #5 of 37 (permalink) Old 11-21-2012, 05:42 PM Thread Starter
Found the problem T/b is bad :-( now we need a used t/b !
post #6 of 37 (permalink) Old 11-26-2012, 07:11 PM Thread Starter
[QUOTE=SwassAC;964631]Easy fix for me... I had exact same problem and symptoms, ended up being water and corrosion at the connector to the ecu... cleaned up contacts plugged back in and no more issues...
We swaped pedal sensors and now ot just dnt go he wot it and it seems like hes just cruisin it lol like hes not even on the gas and a new code came up p2127 throttle position sensor cuircit e low input we cleaned out plug from ecu amd same thing we goin crazy over here lol any input will help thanxx guys
post #7 of 37 (permalink) Old 11-26-2012, 08:32 PM
He needs to recalibrate the TB. Give me a few and I'll see if I can find a link to how to do it.
Harrison@Stage6 is offline
The Following User Says Thank You to Harrison@Stage6 For This Useful Post:
RED_ROCK_SRT (11-26-2012)
post #8 of 37 (permalink) Old 11-26-2012, 08:34 PM Thread Starter
Perfect thanxx bro im sitting by my phone lol we tried everything from re flashing his rigg to disconnecting battery to checking ecu cleaning out all the plugs and no luck so yea thanxx for everything guys!!!
post #9 of 37 (permalink) Old 11-26-2012, 08:36 PM
Here you go...... try this.
1. Turn the key in On position, do not start the engine.
2. Depress accelerator pedal and hold it fully depressed for 5 sec.
3. Turn the key in OFF position, while keeping pedal depressed. Do not remove the key.
4. Take your foot from the pedal, leave the key in for 2 minutes.
5. Remove the key.
This should reset Drive-by-wire (Accelerator+Throttle) adaptives.
post #10 of 37 (permalink) Old 11-26-2012, 08:52 PM Thread Starter
Nope same thing we are thinking of taking it to the dealer ship but we doin everything we can not to but if anything comes up ill keep everyone posted thanxx
Code -__- Amoose25 WK1 Troubleshooting / Problems Discussion / Dealer Service 10 09-07-2012 11:48 AM
P2138 code... flashing ETC light pimpski25 WK1 Troubleshooting / Problems Discussion / Dealer Service 2 12-19-2011 11:19 AM
CEL is on with new code oman srt8 WK1 Troubleshooting / Problems Discussion / Dealer Service 5 01-31-2009 04:03 AM
Need help with code Power Ported Performance WK1 General Performance Discussion 9 06-01-2008 04:56 AM
Jeep SRT 8 colour code / paint code bbigman2000 WK1 Troubleshooting / Problems Discussion / Dealer Service 10 04-22-2008 09:29 AM
