HELP!!!!P2138 code :-( - Page 2 - Cherokee SRT8 Forum
post #11 of 37 (permalink) Old 11-26-2012, 09:42 PM
Hmmmmmm...... damn. Somehow the TB and pedal aren't talking, which could in turn lead to a dangerous situation. You'd hate for it to goof up at WOT. I'd definitely take it to the dealer and let them do what they need to do. I'm sure it's a learning thing that may need to be done with a StarScan. Bite the bullet and let them figure it out. I hate drive by wire. It can be such bullshit sometimes.
Harrison@Stage6 is offline
post #12 of 37 (permalink) Old 11-26-2012, 10:08 PM
DrSheldonCooper's Avatar
did you ever try to replace the throttle position sensor?
did you check to see if the wiring to the TPS are damaged?
try doing a TPS sweep with a volt meter.
DrSheldonCooper is offline
post #13 of 37 (permalink) Old 11-26-2012, 10:25 PM Thread Starter
RED_ROCK_SRT's Avatar
T/p sensor is the one behind the gas pedal right??i it is we did i swaped it out with mine we swaped out t/bs and aame thing we checked all wiring make sure no corrosion and nothing :-(
RED_ROCK_SRT is offline
post #14 of 37 (permalink) Old 11-26-2012, 10:35 PM
no, the sensor right behind the pedal is the pedal position sensor.
the throttle position sensor is on the throttle body. since these are drive by wire, and what controls the actual throttle is a motor, it's most likely built within the motor. probably pretty pricey (if it is in fact that)
but harrison could be right. could just be something stupid like a re-learn.
post #15 of 37 (permalink) Old 11-26-2012, 10:41 PM Thread Starter
Well we swapped out t/b aswell with the sensor attached to it and it worked for like 3 days and then it started doin the same thing again and that little red bolt stays on we reflashed it nothing we erased codes nothing re programed t/b nothing swapped out gas pedal sensor nothing we ran out of ideas so i guess our last option is dealer ship
post #16 of 37 (permalink) Old 11-27-2012, 05:16 AM
Is it tuned or stock?
post #17 of 37 (permalink) Old 11-27-2012, 09:50 AM Thread Starter
Its tuned it has a v3 ,cam,ported mannifol,mmmmm and thats it
post #18 of 37 (permalink) Old 11-27-2012, 02:58 PM Thread Starter
Its the pcm accoding to dealer guys :-(
780$ with labor and everything
post #19 of 37 (permalink) Old 11-27-2012, 03:40 PM
Mike@Diablosport's Avatar
it runs, drives, flashes, reports VIN and calid, but...its bad?
Hmmm....
Mike@Diablosport is offline
The Following User Says Thank You to Mike@Diablosport For This Useful Post:
Jack_Toepfer (11-27-2012)
post #20 of 37 (permalink) Old 11-27-2012, 03:48 PM
Check all connections to the PCM and swap batteries while its disconnected.
I agree with Mike.
Jack_Toepfer is offline
Code -__- Amoose25 WK1 Troubleshooting / Problems Discussion / Dealer Service 10 09-07-2012 11:48 AM
P2138 code... flashing ETC light pimpski25 WK1 Troubleshooting / Problems Discussion / Dealer Service 2 12-19-2011 11:19 AM
CEL is on with new code oman srt8 WK1 Troubleshooting / Problems Discussion / Dealer Service 5 01-31-2009 04:03 AM
Need help with code Power Ported Performance WK1 General Performance Discussion 9 06-01-2008 04:56 AM
Jeep SRT 8 colour code / paint code bbigman2000 WK1 Troubleshooting / Problems Discussion / Dealer Service 10 04-22-2008 09:29 AM
