Wideband help - Page 3 - Cherokee SRT8 Forum
post #21 of 26 (permalink) Old 11-21-2012, 10:50 AM
Knuckles's Avatar
Originally Posted by chevydillan View Post
Just using the drivers side. Are all the innovate gauges basically the same? Do they just differ in looks?
Cool!!! Yeah same thing on did as well.... The wideband gauges basically look the smae except that you can change the face or bezel on them....
Knuckles
Knuckles is offline
post #22 of 26 (permalink) Old 12-06-2012, 11:55 PM Thread Starter
chevydillan's Avatar
Help
Ok, installed the LC-1 with an Innovate G3 gauge tonight. I also wired in the Digi-key wire for the Trinity.
I have a few questions now. Should the digi-key wire and the gauge signal wire both be on the same analog output from the LC-1? I used the brown wire and tied both the gauge and digi-key into that, was that correct? It looks like there is some confusion as to which color analog out wire to use, yellow or brown. The instructions that came with the gauge said to use brown. Now my problem,the gauge comes on and does a dial sweep but just sits at zero after that, never reads anything but zero. I dont have Trinity set up yet so I cant see if thats working. Anybody have any ideas?
DO I need to connect the LC-1 to the computer? Do I need to have that terminator plug in the serial in port?
chevydillan is offline
post #23 of 26 (permalink) Old 12-08-2012, 01:27 PM Thread Starter
I got the Trinity hooked in and made a gauge for the AFRs. It appears to working just fine, although very lean. The G3 gauge does not work still. I have the Trinity and the G3 hooked to the same brown wire off the LC-1 and wondering if thats the issue? I dont have a serial to usb adapter to hook the laptop to LC-1 so i cant check on that untill the cable gets here(ebay).
Im seeing very lean readings on the Trinity, like 14-15 and even much higher like to 17 just cruising and 13.5 to 14.5 WOT.
post #24 of 26 (permalink) Old 12-08-2012, 01:31 PM
I got the LC-1 with the auto timer, has turbo timer, voltage gauge and AFR digital gauge. $200
Jack_Toepfer is online now
post #25 of 26 (permalink) Old 12-08-2012, 01:32 PM
kmitch80's Avatar
sounds like normal afr for daily driving to me. I get 14-16 under normal throttle. then about 12 at WOT. but remember the trinity gauge is not as accurate as the actual afr gauge
Sent from my DROID BIONIC using AutoGuide.Com Free App
PWR 426
kmitch80 is offline
post #26 of 26 (permalink) Old 12-08-2012, 02:15 PM Thread Starter
*Paging Knuckles*
Do you have your gauge and trinity on different analog outputs from the LC-1? Is it ok to tie them together?
Kooks long tubes . Catted mids . Magnaflow Catback . FTI 3200 Stall . DR Stage 2 Heads . Comp Cam 230/222 573/566 on 112 . PnP Intake, TB . Speed Logix Catch Can . LC-1 . Trinity . Green Brembo's
Anybody put a wideband a/f on a wk2 yet? rconner WK2 SRT8 Tuning/CMR/Dyno/DataLogging/Gauges 3 03-01-2012 08:11 PM
Did I get the right wideband for what I want J&D's SRT's WK1 Tuning/CMR/Dyno/DataLogging/Gauges 5 08-16-2011 05:26 PM
Wideband.....Anyone??? KidItsRandall WK1 Interior/Exterior Visual Modifications 27 05-25-2010 03:00 PM
Help With Wideband Please............. 060gon WK1 Troubleshooting / Problems Discussion / Dealer Service 12 01-26-2010 07:08 PM
Oh Boy.... My New Toy! :-) LC-1/XD-16 Wideband Harrison@Stage6 WK1 Tuning/CMR/Dyno/DataLogging/Gauges 39 12-02-2009 05:53 AM
