Wideband help - Page 2 - Cherokee SRT8 Forum
post #11 of 26 (permalink) Old 11-20-2012, 02:31 PM
Untouchable's Avatar
I have mine running without a gauge
That being said, I was in the same boat and bought an innovate gauge. You can run both if u want.
Shoot me a pm if anyone is interested in it
8.90@157.59
Untouchable is offline
The Following User Says Thank You to Untouchable For This Useful Post:
Knuckles (11-20-2012)
post #12 of 26 (permalink) Old 11-20-2012, 02:41 PM
LAFNGA5's Avatar
exact same setup im running right now (trinity with digi key 2.5mm cable and innovate lc-1) only issue i had was instructions had the yellow/brown wire for which sensor use labeled wrong so it was a narrowband until i undid the input wire from brown to yellow.
easy setup and great overall, i use the lc-1 xd-16 in my car with not 1 problem
10's Best Be Coming
LAFNGA5 is offline
post #13 of 26 (permalink) Old 11-20-2012, 02:42 PM
meeper's Avatar
I went with the MTXL gauge because didnt want to watch a huge trinity screen all the time to monitor AFR. i can still log the AFR using the digikey cable as well... best of both worlds
meeper is offline
post #14 of 26 (permalink) Old 11-20-2012, 03:12 PM
Knuckles's Avatar
Yup my exact thought... I hate the AFR jumping around all the time on the trinity... Thats why I have both a gauge and the trinity for AFR....
Knuckles
Knuckles is offline
post #15 of 26 (permalink) Old 11-20-2012, 03:13 PM
Knuckles's Avatar
You only running the driver side wideband or are you running the passensger as well bro?
Knuckles is offline
post #16 of 26 (permalink) Old 11-20-2012, 03:15 PM
meeper's Avatar
whatever my MTXL says is what the Trinity says. the MTXL is a digital AFR so it jumps around very fast except when under WOT. very accurate piece of equipment.
i heard its best to run AFR on the drivers side with these things
meeper is offline
post #17 of 26 (permalink) Old 11-20-2012, 03:21 PM
Knuckles's Avatar
Yeah welll aware the MTX-L is a digital gauge, and I know you can adjust the sample rate of what is outputted from the LC-1. I just like the bigger gauge thats all and like confirmation that my AFR is correct just in case the one wired to the Trinity doe snot look right to me. I know you can also make the gauge you add to your layout on the Trinty bigger if you like... After all whats a 200.00 gauge compared to what I could lose if I have thousands of dollars invested in my Jeep when going ForceInduction... Just my 2 cents bro...
Knuckles is offline
post #18 of 26 (permalink) Old 11-20-2012, 04:45 PM
rconner's Avatar
Just got done installing my LC1. As of now my trinity does not have the tables to show the air fuel ration on the screen, diablo is working on that as we speak. BTW I have a WK2. When I bought my LC1 it was only 10 dollars more to add the gauge. I am not sure of the part number. I plan on just using the trinity as my gauge until I put on some kind of forced injection, then I will mount the gauge. Call skip at demon, he will hook you up with the right gauge.
LAFNGAS@TTC, you stated that the yellow and the brown wires were labeled incorrectly. I used the brown wire to hook it up to the trinity... So that is wrong?
rconner is offline
post #19 of 26 (permalink) Old 11-20-2012, 05:29 PM
Knuckles's Avatar
Depends on when you bought your LC1 as the older ones use the Brown wire for the wideband... Technically you can use the other wire, but you would have to connect your LC1 to a computer and change the function of that other output on the Innovate software. So instead of doing that people should just choose the one that is identified as the wideband wire...
MTX-L: Uses the Analog 1 (Yellow wire) to simulate a wideband
XD-16/LC1 kit: Uses Analog 2 ( Brown wire) to simulate a wideband.
Knuckles is offline
rconner (11-20-2012)
post #20 of 26 (permalink) Old 11-21-2012, 09:16 AM Thread Starter
chevydillan's Avatar
Just using the drivers side. Are all the innovate gauges basically the same? Do they just differ in looks?
chevydillan is offline
Anybody put a wideband a/f on a wk2 yet? rconner WK2 SRT8 Tuning/CMR/Dyno/DataLogging/Gauges 3 03-01-2012 08:11 PM
Did I get the right wideband for what I want J&D's SRT's WK1 Tuning/CMR/Dyno/DataLogging/Gauges 5 08-16-2011 05:26 PM
Wideband.....Anyone??? KidItsRandall WK1 Interior/Exterior Visual Modifications 27 05-25-2010 03:00 PM
Help With Wideband Please............. 060gon WK1 Troubleshooting / Problems Discussion / Dealer Service 12 01-26-2010 07:08 PM
Oh Boy.... My New Toy! :-) LC-1/XD-16 Wideband Harrison@Stage6 WK1 Tuning/CMR/Dyno/DataLogging/Gauges 39 12-02-2009 05:53 AM
