Innovate MTX-L Issues - Cherokee SRT8 Forum
post #1 of 4 (permalink) Old 05-21-2012, 08:30 PM Thread Starter
Texas SRT8's Avatar
After I hit the track, my MTX-L threw a E8 code. I believe this means the O2 sesnsor is defective? Is it common for AFR O2 sensors to go bad so soon? I've had it for less than a year. I turned off the jeep, turned it back on, and the E8 went away. It has been reading AFR normally since.
Also, after the E8, I can no longer read AFR on my DS Trinity. I tried resetting the analog input and unplugging/plugging the audio jack but still no AFR. I'm guessing the audio jack cable has become defective. Can I still salvage it by switching from analog input 1 to 2 or do I need a whole new cable?
Texas SRT8 is offline
post #2 of 4 (permalink) Old 05-21-2012, 08:37 PM
Is the sensor in at angle in the pipe? Moisture will kill it if it can't burn off. I don't think you can kill the wire though. Try switching the analogs doesn't hurt and won't cost anything to try. I've heard the AEM having issues but not the innovate
A.V.GCSRT8 is online now
The Following User Says Thank You to A.V.GCSRT8 For This Useful Post:
Texas SRT8 (05-23-2012)
post #3 of 4 (permalink) Old 05-21-2012, 10:48 PM
HoustonHemi's Avatar
Double check your wiring and grounding. Also it may just come back on after a pwer cycle. Those codes were fairly common when I had Innovate stuff.
2008 SBM SRT8
It's got a cop motor, a 440 cubic inch plant.
Texas HouseofHemi.
HoustonHemi is offline
The Following User Says Thank You to HoustonHemi For This Useful Post:
post #4 of 4 (permalink) Old 05-23-2012, 06:53 AM Thread Starter
Texas SRT8's Avatar
Sesnor is placed between the 9 o'clock and 12 o'clock part of the midpipe.
Innovate, Innovate or nonvate duke50 WK1 Tuning/CMR/Dyno/DataLogging/Gauges 15 09-22-2011 06:18 PM
Innovate MTX-L Installed!! CentralTexHemi WK1 Tuning/CMR/Dyno/DataLogging/Gauges 13 02-17-2011 05:12 PM
TPMS issues and replacement issues brianm WK1 Troubleshooting / Problems Discussion / Dealer Service 2 12-14-2010 05:18 AM
Innovate A/f Meter.... veyronSRT8@TTCreations WK1 SRT8 General Discussion 6 07-22-2008 04:19 PM
