How To: Trinity Vent Mount - Cherokee SRT8 Forum
post #1 of 9 (permalink) Old 12-29-2014, 08:38 AM Thread Starter
HemiRamOn22s's Avatar
I've seen alot of other installs with the Trinity and i just dont like seeing wires running everywhere. So i decided to do a vent mount on the right side of the steering wheel and run the wires through the vent to clean up the install. Well here is how you do it...
1.) To start you will need a richter style vent mount. You can pick them up for around $10.00 similar to this one: http://www.igrip.us/1534
2.) You will want to grab ahold of the dash with your hands on top of the dash where the half circle from the bezel meets the dash and pull the bezel towards you. Its just held in with a few clips and comes off really easy.
3.) Once you have the bezel off you will want to remove the vertical fins from the left vent. It pops out pretty easy with a flathead screwdriver working from the top.
4.) After that is out use a dremel to cut a hole in the side of the vent big enough to fit the trinity OBD2 adapter through.
5.) Then feed the wires from the outside throught the hole you cut and then throught the horizontal fins on the vent. I also ran the cable for my AFR gauge through this hole as i have a wideband hooked up to my trinity.
6.) Once the wire are run, install the richter mount on the back of the trinity, plug the wires into the trinity and then install then vent mount onto the vent and adjust it to your preference.
7.) Remove the lower dash cover under the steering column by pulling down on the cover and it pops right off. Route the wires down into the dash between the heater vent and dash gauges and reinstall the bezel onto the dash.
8.) Run the OBD2 wire over to the connector on the bottom left side of the dash and secure any loose wires with zip ties so they wont get caught in the steering linkage. Re-install the lower dash cover.
Done! Only takes about 30 minutes from start to finish.
Murdered SBM 07 Jeep Grand Cherokee SRT8
Matthews Performance
Toona Tuned
Littleboy+4-Bwoody-HHP Stage 2 Heads & Intake Manifold-90mm TB-SLP U/D-SW LTs & Cats-Solo Exhaust
Trinity-BT CC-180 Tstat-Eibachs-Nitto NT05s-DC Customs-Tint-Tinted Tails-DRTs D/S Rotors-GS6 Pads
RIP Jay2g1
IG: MattyJDE
HemiRamOn22s is offline
The Following User Says Thank You to HemiRamOn22s For This Useful Post:
Ivoidwarranties (01-05-2015)
post #2 of 9 (permalink) Old 12-29-2014, 08:53 AM
bxcharger's Avatar
Pictures aren't showing up on my iPhone, anyone else with the issue?
Procharger D1, 17% OD pulley, Thitek 6.1 ported heads, Kooks Headers, Fore Fuel Rails, Custom BOV pipe w/Big Red, Corsa Exhaust, Ported intake manifold, 87MM TB, 180T-Stat, Lowered on Eibachs, Bwoody sway links and Panhard bar, Aadcco front and rear sway bars, JBA upper control arms, QA1 shocks, Full Infinity Kappa perfect set up with Kenwood, Carbon fiber Stryker hood, Carbon Fiber rear Spoiler, Carbon Fiber interior, 11" headrest monitors, 22" Chrome wrapped in 275/315 Vreds
bxcharger is online now
post #3 of 9 (permalink) Old 12-29-2014, 08:58 AM Thread Starter
It should work now i was in the middle of moving them around on my photobucket
post #4 of 9 (permalink) Old 01-04-2015, 05:58 AM
cmn1's Avatar
Thanks for the addition to the How To/ DIY section.
How To: Trinity Vent Mount (WK1)
cmn1 is offline
The Following User Says Thank You to cmn1 For This Useful Post:
HemiRamOn22s (01-04-2015)
post #5 of 9 (permalink) Old 01-04-2015, 07:12 AM
Daily Driver..........
gerd35's Avatar
great write up!
is it easy to remove the trinity off the mount? or do you have to remove the whole mount from the vent?
2007 Silver GCSRT8 / 426 / Inertia Port and Polish Intake / Kooks LT Headers / Arrington 85mm TB / 4" Bwoody CAI / Magnaflow Catback / Bwoody Endlinks / Rear Addco / Eibach Pro Kit / QA1's / Jet 180 / Paramount Trans / ATI Flexplate / Dominator TC / R1 D|S Rotors + Hawk pads / Nitto 420s / Zex 100 N20 / LED Interior / HID Lows and Fogs / Tuned by Diablotoona
YOU TUBE :
PB: 11.72@114.88 with stock motor
gerd35 is offline
post #6 of 9 (permalink) Old 01-04-2015, 07:41 AM
6Point1HEMI's Avatar
Great write-up gonna look into this, thanks.
'10 SRT8/AAD Catch Can/Mopar CAI/TLS LED FOGS/LED Taillights/Solo Exhaust/JOHAN TUNED
6Point1HEMI is offline
post #7 of 9 (permalink) Old 01-04-2015, 09:27 PM Thread Starter
Originally Posted by gerd35 View Post
great write up!
if you leave slack in the cables you can slide it right off the richter mount. The mount itself you need a flathead screwdriver to pry up on the clips to slide it back off. Once its on there its pretty secure. honestly you can pop the bezel off the dash in about 3 seconds if its that big of a deal.
gerd35 (01-05-2015)
post #8 of 9 (permalink) Old 01-05-2015, 07:18 AM
LAUNCH
Ivoidwarranties's Avatar
Thanks for the post Matt! I bought this mount right before Christmas with this in mind. I'm not sure I left enough slack in the AFR cable to make it to the other side of the dash but maybe I could just get a 3.5mm extension cable if I have to.
Great post Buddy!
Ivoidwarranties is offline
post #9 of 9 (permalink) Old 01-05-2015, 07:21 AM Thread Starter
Great post Buddy!
The cable i had ran all the way from the vent to the A-pillar with some slack.
Interesting Trinity mount wink WK1 Tuning/CMR/Dyno/DataLogging/Gauges 30 03-13-2016 09:02 PM
Who has pictures of their Trinity mount? srt8gofast WK1 Tuning/CMR/Dyno/DataLogging/Gauges 32 07-14-2013 07:32 PM
how to mount your Trinity Ezituper WK1 Tuning/CMR/Dyno/DataLogging/Gauges 6 03-09-2011 04:57 PM
