Anyone use these Front Map LED's? - Cherokee SRT8 Forum
post #1 of 3 (permalink) Old 02-25-2013, 07:28 AM Thread Starter
HOSTIL's Avatar
Hey guys, wondering if anyone has replaced their front map bulbs with these 24 LED flat panel lights? Just curious as to how you mounted them behind the lense? I took the outer chrome piece out but left the inner one in. Did you just shove everything back in, snap the lense in and just let the panel float around in there? My concern is if the LED's are resting aginst the clear lense that it may melt the plastic. Plus its hard to keep them perfectly centered.
[IMG][/IMG]
HOSTIL is offline
post #2 of 3 (permalink) Old 02-25-2013, 10:24 AM
DCSpecial's Avatar
Use double sided tape to hold them up to the socket adapter.
DCSpecial is offline
post #3 of 3 (permalink) Old 02-25-2013, 12:04 PM Thread Starter
HOSTIL's Avatar
Thanks Dan.....I will give that a try.
HOSTIL is offline
led's nyjoed WK1 Lighting Discussion 5 01-14-2010 05:51 PM
???hid's Or Led's??? nyjoed WK1 Lighting Discussion 9 01-04-2010 06:31 PM
The SICKEST front turn LED's on the PLANET!!! YoungMedic23 WK1 Interior/Exterior Visual Modifications 148 12-27-2009 02:17 PM
Interior LED's bslagle3 WK1 Lighting Discussion 21 12-24-2008 11:04 AM
LED's!!! LED's!!! LED's!!! One of a kind look!!! YoungMedic23 WK1 Lighting Discussion 56 09-21-2008 03:27 AM
