2008 JGC SRT8 Projector HID passenger side faces down and doesn't move - Cherokee SRT8 Forum
post #1 of 5 (permalink) Old 11-17-2012, 02:32 PM Thread Starter
2008 JGC SRT8 Projector HID passenger side faces down and doesn't move, however the bulb works. When I start the vehicle the drivers side Projector HID adjusts. The passenger side does not move. Is this a likely ballast issue?
Thanks.
2008 Grand Cherokee SRT8
1973 Camaro; 383ci SBC 525hp-NA/700hp-N2O, A3/TCI Super Street Fighter, 3200rpm stall/TCI Competition, 12bolt 4 Series/4.10s/Strange Racing axles/C clip elims., 10 point cage, 325/50/15 ET Streets, coil overs all 4 corners
Rascal is offline
post #2 of 5 (permalink) Old 11-24-2012, 10:03 AM
DCSpecial's Avatar
It could be the self-leveling motor failed, or the housing itself broke where the projector is attached to it (seen it happen, housing is actually somewhat brittle).
Ballast just fires the bulb, as far as I know.
DCSpecial is offline
post #3 of 5 (permalink) Old 11-24-2012, 10:39 AM Thread Starter
Thanks. Sounds like I'll need a whole new headlamp if the housing is broken. Is the leveling motor serviceable/replaceable?
Rascal is offline
post #4 of 5 (permalink) Old 11-26-2012, 10:30 PM
DCSpecial's Avatar
The leveling motor is replaceable. Now, if you can purchase that piece by itself I don't really know. I just know I have removed them and installed them on headlights I've built.
post #5 of 5 (permalink) Old 11-30-2012, 12:43 AM
RED_ROCK_SRT's Avatar
I had that happen to me the passenger side would move when i would start my rigg.... But figured it out when i took my rigg to the local 1/4 mile i took my eadlight off to get more air in there i took off the harnest but didnt realize wen i pulled light off the smallest plug next to the actuall head light projector had came lose i just snaped it in and it worked check that all of your plugs are snapped in correctly
RED_ROCK_SRT is offline
HELP passenger headlight wont move up or down:( RED_ROCK_SRT WK1 Lighting Discussion 1 11-10-2012 08:09 PM
Is Bank 2 passenger side? BIGTACO WK1 Troubleshooting / Problems Discussion / Dealer Service 5 09-05-2011 03:38 PM
passenger side cat cracked!! nyc srt8 al WK1 Troubleshooting / Problems Discussion / Dealer Service 2 09-14-2010 01:17 AM
Need new passenger side mirror. landsteam WK1 SRT8 General Discussion 1 03-23-2010 05:10 PM
