8K HID's installed - Totally amazed at results - Page 3 - Cherokee SRT8 Forum
post #21 of 31 (permalink) Old 01-17-2013, 11:39 AM
drastik211's Avatar
Re: 8K HID's installed - Totally amazed at results
I just bought a H10 kit for my fogs and the plugs are different than the original harness .... The original bulbs say H10 so I'm sure I ordered the right kit. I found that I could use spare wire to connect the 2 incorrect plugs and the fogs with the hids connected turn on an off just fine by using the pull knob in the cab. Anyone else run into this? I really don't want to just splice these connectors together...
Sent from my HTC6435LVW using AutoGuide.Com Free App
2012 JGCSRT: 22"Reps, 93oct Trinity canned tune, Borla S-type AB Exhaust, BWoody Long CAI, 5% Tint, Catch Can, Murdered Tails
SOLD 2006 JCGSRT8 13.29@103.4: Johan Tuned, Stainless Works non-catted Headers, Corsa catback, K&N Cold Air Intake, Jet180*t-stat, Catch Can, 5%Tint, 275/315s, Murdered, 8000k HIDs in Lows & Fogs, 8000k 60Leds parking lights
drastik211 is offline
post #22 of 31 (permalink) Old 01-17-2013, 11:39 AM
Silver & Satin
Regency's Avatar
I would return it and get the right ones
Marcus C.
2007 Silver SRT
76MM Turbo-Quad Retrofit-Chrome Delete-Tint-Satin Black 22"s-Toyo Proxes STII-Solo Exhaust-RM 1.7"-Painted Roof Rails-Trinity-9500ix-Pioneer HU-Alpine Door Speakers-Diamond Audio 12"s-Billet Tech Underhood Kit-6K Highs/Lows/Fogs-Billet Tech Door Locks-TLS LED Tails-LED Rear Fogs-Cree 6K Reverse Lights-Billet Tech Catch Can-Dynamat-R1 Drilled Rotors-Stoptech Brake Pads-Tinted Tails
-Johan Tune-Mopar Rear Lip-Colormatched Venom Hood
Regency is offline
post #23 of 31 (permalink) Old 01-17-2013, 11:53 AM
drastik211's Avatar
Which ones are the right ones if I ordered H10s and they don't match?
post #24 of 31 (permalink) Old 01-17-2013, 12:26 PM
Silver & Satin
Regency's Avatar
9145 is for the fogs
9006 is for the low beams
Regency is offline
post #25 of 31 (permalink) Old 01-17-2013, 12:54 PM
drastik211's Avatar
Aren't H10/9145 the same bulb and harness? Pretty sure they were
post #26 of 31 (permalink) Old 01-17-2013, 02:34 PM
Mongoose9400's Avatar
Usually when you get an HID kit you'll have the HID bulb with 2 wire pairs held together with a rubber grommet. 2 of the wires are for the actual HID light bulb and have the Amp connectors on the ends. The other wire pair will have two connectors, one on each end. Normally one end will be a 9006 connector that connects into the ballast, the other end plugs into the OEM wire harness. In this case it should have an H10/9145 connector. Sometimes that adapter is needed as most HID kits use 9006 and Amp connectors.
In some cases, like the low beams already being 9006 the OEM harness can plug directly into the ballast (or relay harness depending on your install preference) Most HID kits are all plug and play.
I'll see what pictures I can find to help explain this if you need extra help.
Zac
SOLD 2007 Silver Jeep SRT8
Mongoose9400 is offline
drastik211 (01-17-2013)
post #27 of 31 (permalink) Old 01-17-2013, 03:01 PM
Here is a pic from one of my installs:
Plug 1: OEM Wiring Harness
Plug 2-3: Is an adapter harness normally connected to the HID bulb by the rubber grommet.
Plug 4-5: Is a relay harness to switch power from the battery instead of through the factory wiring harness
Plug 6: HID Ballast input
Plug 7: HID Ballast output to HID light bulb
Examples: (Assuming the HID kit is using a 9006 plug at points 4,5,6. Which they normally do)
For the low beams using a 9006 factory style bulb and connector. You could plug 1 into 6 and get power to the HID system. This draws power from the factory wiring harness. I don't recommend this.
For the low beams using a 9006 factory style bulb and connector. You could plug 1 into 4 and 5 into 6 and get power to the HID system. This draws power from the battery using the relay harness. Note, the two ring terminals of the relay need to be connected to + and - respectively to work.
For a foglight setup, it'll connect similar as the above examples. You may need something to connect the factory harness at point 1 into point 4 or 6 (depending if you use a relay harness or not) Most kits supply that harness from point 2-3 attached to the HID bulb in the kit. Otherwise, using a relay harness you can cut plug 1 off and plug 4 off and hardwire.
Good luck! HIDs are usually a very simple install.
post #28 of 31 (permalink) Old 01-17-2013, 03:03 PM
Send a message via AIM to phillysrt
haha i get flashed everyday...if people werent idiots then they would realize that if the high beams are on then the fogs go off... i hear ya though, makes the car look so much better
Dominic From Philly
2014 SRT Deep Cherry Red
2010 SRT8 Silver (Retired
phillysrt is offline
post #29 of 31 (permalink) Old 01-17-2013, 03:41 PM
Chans_Srt-8's Avatar
HIDs looking good man. ima have to get me the same pair. thanks for the heads up on the brand.
CHAN
Stock 09 Jeep SRT8
will do mods in the future.
Chans_Srt-8 is offline
post #30 of 31 (permalink) Old 01-17-2013, 08:22 PM
drastik211's Avatar
I got them in. Somehow the connectors on one set were reversed and the actual pins in the harness wouldn't fit. I just pulled out the pins and re-seated them correctly in the harness. Bingo! thanks for the helps guys.
btw... @hotrodcalvert those look BA!
P&P reverse HID's installed for testing Taillight Solutions WK1 Lighting Discussion 28 06-20-2010 11:52 PM
Has Anyone Installed HID's high beams?? aplatero1984 WK1 SRT8 General Discussion 18 05-28-2008 09:13 AM
HID's Installed - More Pics MARK16 WK1 Lighting Discussion 13 01-31-2008 09:21 PM
HID's INSTALLED!! WOOOH!! Mango WK1 Lighting Discussion 42 05-21-2007 11:08 PM
Picture of HID's installed. GodfatherSRT8 Pics & Video Showoff Section 20 01-13-2007 12:19 PM
