Installing front LED turn signals - Page 3 - Cherokee SRT8 Forum
post #21 of 30 (permalink) Old 11-28-2012, 09:56 AM Thread Starter
RBugnitz's Avatar
BUMP...
So anyone able to snap a quick pic of thier "resistors" wired into LED turn/park signals??? Been wanting to do this mod for while now but been putting off. Want a nice picture to look at to make installation smoother. PLEASE! PLEASE!! PLEASE!!! post a pic for a friend in need. :-(
RBugnitz is offline
post #22 of 30 (permalink) Old 11-28-2012, 10:01 AM
CHUCKTOWNSRT8's Avatar
I'll try to snap one for you in a few
[SIGPIC][/SIGPIC]
CHUCKTOWNSRT8 is offline
post #23 of 30 (permalink) Old 11-28-2012, 11:54 AM
DCSpecial's Avatar
I agree with using weatherproof connections and heat shrink. I always toss the quick taps that come with resistors in the garbage. For that matter I always wireloom the resistor wires for added protection.
On 06-08s I've needed to use 1.5ohm of resistance and 3 ohm on 09-10 with OEM HIDs. That's with the switchbacks I use.
DCSpecial is offline
post #24 of 30 (permalink) Old 11-28-2012, 12:35 PM
nyhockeyref93's Avatar
Holy shit that's bright, I already have problems with blinding everyone on the road. I even get cops to shine their spotlight in my face because my HID's are so bright. Good thing is I can spot a cop a mile away with my lights bouncing off their reflectors on their cars.
Can some one post more pics of these turned on ? And are these switchbacks? And what are switchbacks, don't know much about lights lol
2007 Silver Jeep SRT8...that's all you need to know
nyhockeyref93 is offline
post #25 of 30 (permalink) Old 11-28-2012, 12:49 PM
DCSpecial's Avatar
I always use switchbacks. They are white with the running lights on but switch to amber with the turn signal.
Here's a pic I have test firing to make sure I had it installed in the socket correctly (they are polarity sensitive):
post #26 of 30 (permalink) Old 11-28-2012, 12:58 PM Thread Starter
RBugnitz's Avatar
Thanks for the quick feed back.... Is there anyway you can get a pic of the wiring witht eh resistors wired in to make lights flash. When i intstall my 3157 LED bulbs the turn on... but they dont flash correctly. They Stay on highest flash and do not flicker. Im hoping the resistor will fix issue. Not sure if i bought correct one. I got a load resistor 3 ohm 50w. I think i may have ordered wrong part. Seeing a pi would help me identify the correct resistor needed. Sorry not very good with electical... Thanks again though brotha!
RBugnitz is offline
post #27 of 30 (permalink) Old 11-28-2012, 01:00 PM
DCSpecial's Avatar
I don't have any pics of the wiring. You tie it into the turn signal wire (can test with a test light to see what wire it is) and then I run the other end to chassis ground.
If the 3ohm doesn't take care of it, try 1.5ohms. Which would be two 3ohm resistors wired in parallel. If you wired them in series that would be 6ohm.
post #28 of 30 (permalink) Old 01-15-2013, 02:53 PM Thread Starter
RBugnitz's Avatar
BUMP.....
Any one willing to post pics of wiring config(resistors mainly hooked up) for the LED Turn/Parking bulbs on '07? Would like to get these installed ASAP!!!!
Please help a brotha out!!! :-(
RBugnitz is offline
post #29 of 30 (permalink) Old 01-15-2013, 03:04 PM
DCSpecial's Avatar
Tap to the turn signal wire with one end......other end to chassis ground. Pretty simple. Test light will tell you what wire is the turn signal wire.
post #30 of 30 (permalink) Old 01-16-2013, 06:19 PM
HEMI TME's Avatar
Radio shack just had 4.7's but I paralleled em and gets me a faster flash that looks cool.
Thanks all ya's
2009 Modern Blue
SOLD
06 Flat Graphite wrap, 142,000 mile daily driver!
Forged 6.1, VREDS
ET.....10.61
mph..130.98
60ft..1.61
76mm CompTurbo
Special thanks to ebay
[/COLOR]DaToonA ain't Frikn around.....
HEMI TME is offline
another thread on LED front turn signals... jvs0302 WK1 SRT8 General Discussion 5 08-24-2012 02:02 PM
LED turn signals dsalogia WK1 SRT8 General Discussion 1 03-19-2009 07:56 AM
'07 Active turn signals theblur WK1 SRT8 General Discussion 18 12-09-2008 01:53 PM
Replaced Turn Signals to chrome squigmang WK1 Interior/Exterior Visual Modifications 18 03-07-2008 04:49 PM
