Hey, was just wondeing about getting some direction on this. I bought the Xenon Extreeeeeeeme HID kit a few months back and have been running them without any problems. Last nigth I had driver side healight just go out while I was driving, I clicked my lights off and then back on and the driver side stayed off. I figure I would try to check the wiring at home, so I drove on. About 2 blocks from my house it ignited, I pulled in (it was dark) and with a flash light check for loose connection. I wiggled the wires but the light stayed on.
This morning I was driving to work and had the lights on. About 5 min into driving in goes out again. I get to work, go inside and realize I forgot my laptop... Go back inot the car turn the lights on and they both ignite and stay on for my 20min drive back home. Were also fine for my drive back to work (again)!
Sorry for the long description but my question is did anybody ahve similar problems? What could it be? I assume it is not the bulb because it is intermittent... I wiggled allt he wires leading to the headlight and checked all the OEM and the kit connections, they are fine. All fuses are fine and plugged in (obviously or the lights wouldn't work). Should I wait until it does it again and use an ohm meter to see if the actual bulb is getting juice? What shold be the Volts/Amps?
Thanks
Thanks
