how to get hids in high beam to work??? - Cherokee SRT8 Forum
post #1 of 16 (permalink) Old 12-02-2011, 07:14 PM Thread Starter
SRTat3U's Avatar
Smile how to get hids in high beam to work???
so i have ordered hids for my high beams i live on a dark road now with lots of deers who like to play so i tried to put them in with resistors and nothing and tried without and nothing. I read on another forum that guys put a relay for them to work but i have a relay on the low beams do i need to run 2 seperate relays ?
SRTat3U is offline
post #2 of 16 (permalink) Old 12-02-2011, 07:32 PM
Not sure on the US models but with DRL in Canada they have a real issue to make them work . I have to use a canbus ballast to make my Highs work with a regular ballast and relay it shut the truck down and refused to let it start up . Unplugged it and all was fine . If you don't have DRl's it might work without any issues but don't quote me on that Many have tried and had problems .
Canadian SRT8 is offline
The Following User Says Thank You to Canadian SRT8 For This Useful Post:
SRTat3U (12-02-2011)
post #3 of 16 (permalink) Old 12-02-2011, 07:36 PM Thread Starter
SRTat3U's Avatar
hmm i didn't think it was gonna be a headache like this thanks for the input ill keep fishing around for info thanks
SRTat3U is offline
post #4 of 16 (permalink) Old 12-02-2011, 08:21 PM
m4xm1l10n's Avatar
Simple , hook it up using a relay just like your low beam .
07 JEEP SRT8 _ SOLD
Tuned By Johan
12.13 @ 110 N/A Cam & Headers
6.90 @ 101 & 10.93 @ 122 Boosted @ 9lbs
m4xm1l10n is offline
The Following User Says Thank You to m4xm1l10n For This Useful Post:
post #5 of 16 (permalink) Old 12-02-2011, 08:34 PM Thread Starter
SRTat3U's Avatar
oook will try tomorrow thanks
should i also use resistors ?
SRTat3U is offline
post #6 of 16 (permalink) Old 12-02-2011, 08:45 PM
m4xm1l10n's Avatar
I have no resistors on either low or fogs on mine for over 2 yrs with no issues .
post #7 of 16 (permalink) Old 12-02-2011, 09:05 PM
He's trying to do Highs they are way different then Low's and Fogs
post #8 of 16 (permalink) Old 12-02-2011, 09:52 PM
Jeep Trick's Avatar
Hids are really not good for highs, especially if you use them momentarily
Second they dont work very well on the Jeep, I installed them but had problems and just removed them. Maybe just better off switching the bulb out for something better
Jeep Trick is offline
The Following User Says Thank You to Jeep Trick For This Useful Post:
post #9 of 16 (permalink) Old 12-02-2011, 10:37 PM Thread Starter
SRTat3U's Avatar
Yeah most likely 10 seconds when road is dark if another driver is coming on other side take em off but I think I might go ahead and do some yellow piaa bulbs or something
SRTat3U is offline
post #10 of 16 (permalink) Old 12-05-2011, 09:30 PM
meeper's Avatar
no reason to run HID high beams, you turn them off and on so much that they don't have time to warm up fully and its not good to turn HIDs on and off a lot. my HID fogs stay on with high beams now thanks to local dealer
meeper is offline
Best High Beam bulbs for use W/ HIDs Murfman WK1 Lighting Discussion 11 04-04-2009 08:29 PM
9005 High beam bulb for '08 maansy WK1 Lighting Discussion 8 01-23-2009 04:52 AM
HID's/High Beam Issues XenonDepot WK1 Lighting Discussion 7 12-16-2008 07:25 PM
HID and Auto High Beam Question RMRSRT WK1 SRT8 General Discussion 12 03-04-2008 03:01 PM
