how to get hids in high beam to work??? - Page 2 - Cherokee SRT8 Forum
post #11 of 16 (permalink) Old 12-05-2011, 08:45 PM Thread Starter
SRTat3U's Avatar
Yeah I drive for intervals of 20 seconds sometimes more on dark roads near my house only life is dears lol I need the scan tool to do that also with the reverse side mirrors go down
SRTat3U is offline
post #12 of 16 (permalink) Old 01-15-2013, 02:42 PM
One, two, GIT SUM!!
gitrdun's Avatar
Has anyone found a fix for Canadian jeeps with the drl? Is there a fuse somewhere for drl that you can yank out?
gitrdun is offline
post #13 of 16 (permalink) Old 01-15-2013, 04:25 PM
No fuse that i have found .I use 2 relay harnesses to trigger each ballast with one I ran into problem and used the newer slim Can-bus ballast . The retro fit source has a new Mopar relay harness I want to try but haven't got a chance yet
Canadian SRT8 is offline
post #14 of 16 (permalink) Old 01-15-2013, 09:57 PM
One, two, GIT SUM!!
gitrdun's Avatar
I will figure this out. And let my fellow Canadians know how to do it
gitrdun is offline
The Following User Says Thank You to gitrdun For This Useful Post:
roadboy (01-15-2013)
post #15 of 16 (permalink) Old 01-27-2013, 08:31 PM
One, two, GIT SUM!!
gitrdun's Avatar
Ok so I got it figured out on how to get it to work, I wired in a whole damn circuit for the high beams and put Mariettes on the stock wiring. Used a piaa light switch for inside the cabs and relays under the hood.
gitrdun is offline
post #16 of 16 (permalink) Old 01-28-2013, 08:35 AM
Bradleyl22's Avatar
i have hids in low, fog and high beam. all i did what run 3 relay harness for the hids. then ran another relay between the lows and highs so the highs did not operate untill the lows came on. so by doing this i have no drl. i try'd everything to make it work right that was the only way it'd work for me.
Sent from AutoGuide.com App
Bradleyl22 is offline
Best High Beam bulbs for use W/ HIDs Murfman WK1 Lighting Discussion 11 04-04-2009 07:29 PM
9005 High beam bulb for '08 maansy WK1 Lighting Discussion 8 01-23-2009 03:52 AM
HID's/High Beam Issues XenonDepot WK1 Lighting Discussion 7 12-16-2008 06:25 PM
HID and Auto High Beam Question RMRSRT WK1 SRT8 General Discussion 12 03-04-2008 02:01 PM
