Factory Alarm will not Stop - Cherokee SRT8 Forum
post #1 of 7 (permalink) Old 01-06-2013, 01:15 AM Thread Starter
meeper's Avatar
Question Factory Alarm will not Stop
remote started my jeep, unlocked it and sat down went to put in the key and alarm started going off and would not stop, had to disconnect battery, hooked it back up and still going off, pulled horn relay so that will shut up, what causes this??? WTF molar
meeper is offline
post #2 of 7 (permalink) Old 01-06-2013, 07:33 AM
LASRT's Avatar
Bad battery???
Adam salsbury - 2010 srt8, pwr camshaft installed at stage 6 running 12.6's
LASRT is offline
post #3 of 7 (permalink) Old 01-06-2013, 07:52 AM
I had somewhat of the same problem .Turned out to be the rear hatch micro switch wasn't working cleaned it bent it so it made contact still making it go off . So I just pulled the connector off till I get a new one or replace it with a pin switch
Canadian SRT8 is offline
post #4 of 7 (permalink) Old 01-06-2013, 01:33 PM Thread Starter
meeper's Avatar
Neither of those make sense to me, hmmmmm thing runs fine battery is great, alarm just going off for nothing
meeper is offline
post #5 of 7 (permalink) Old 01-06-2013, 03:15 PM
LASRT's Avatar
Has to be a switch still engaged then.
LASRT is offline
post #6 of 7 (permalink) Old 01-06-2013, 03:46 PM Thread Starter
meeper's Avatar
yeah but when the alarm goes off you can hit unlock and it stops, this does not stop but the doors do unlock so i know the fob is working
meeper is offline
post #7 of 7 (permalink) Old 01-06-2013, 05:37 PM
LASRT's Avatar
Those sensors should be overridden by the key in the ignition if not then I would say something is stuck or sensor going bad.
LASRT is offline
adjusting the factory alarm rha600 WK1 Audio/Video/Nav/UConnect/Electronics 4 07-03-2010 02:08 PM
Eibach rear bump stop fix. Bump stop fix for dummies needed. Learo2000GT WK1 Suspension / Driveline Discussion 4 03-04-2010 05:46 PM
New Factory Alarm Units AZDEUCE WK1 Audio/Video/Nav/UConnect/Electronics 7 12-11-2009 05:59 PM
Factory alarm - passive? zappmann WK1 SRT8 General Discussion 2 11-11-2008 08:52 PM
HID's and the factory alarm??? hound WK1 Lighting Discussion 7 11-05-2006 05:48 AM
