Replacement Tire Data (All in one) - Cherokee SRT8 Forum
Sponsored by:Discount Tire
post #1 of 24 (permalink) Old 09-05-2012, 04:22 PM Thread Starter
srt8gofast's Avatar
Today's research data after reading many, many threads on replacement tires. Topics include diameter deltas wrt T-case issues. I'm in the market after my GY wear issue... I thought I'd share what I collected today.
Avoid side wear issues...BE SURE TO SET ALIGNMENT CAMBER DOWN TO -0.125 to -0.25 range (per jim383)
STOCK RIM SIZE = Front 9.0, Rear 10.0 (some tires below are outside of this spec)
Question: anybody have issues with rubbing on wider sizes on OE suspension, if so, what model?
Question: any reason to be concerned with buying tires outside of manufacture's rim width specs?
I learned that not all brands are available in OE and/or larger sizes.
Enjoy...
[Transferred from XLS, some formatting and table alignment not showing up pretty]
http://www.nittotire.com/Tire/nt420s#size
NITTO 420S (all season, non-directional)
OE SIZES Diameter Width Tread CIR
255/45R20 29.13 9.88 11 91.514594
285/40R20 28.94 11.38 10.7 90.91769139
DIA DIFF: 0.19
CIR DIFF: 0.006565308
CIR DIFF (%): 0.66%
UTQG (420)
BIG SIZES Diameter Width Tread CIR
275/40R20 **NOT AVAIL IN SIZE** #VALUE!
315/35R20 **NOT AVAIL IN SIZE** #VALUE!
DIA DIFF: #VALUE!
CIR DIFF: #VALUE!
CIR DIFF (%):#VALUE!
http://toyotires.com/tires/pattern/p...l-season-tires
Toyo Proxes STII (all season, directional)
255/45R20 29 9.9 10 91.10618695
285/40R20*** **NOT AVAIL IN SIZE**
CIR DIFF: #VALUE!
UTQG (420)
275/40R20 28.7 10.7 11 90.16370916
315/35R20 28.6 12.2 11 89.84954989
note: approved rim width 10.5-12.5!
DIA DIFF: 0.10
CIR DIFF: 0.003496503
CIR DIFF (%): 0.35%
http://www.nittotire.com/Tire/motivo#size
NITTO MOTIVO (all season)
255/45R20 29.29 10.08 10 92.01724882
285/40R20 **NOT AVAIL IN SIZE** #VALUE!
DIA DIFF: #VALUE!
CIR DIFF: #VALUE!
CIR DIFF (%): #VALUE!
UTQG (560)
275/40R20 28.78 10.83 10 90.41503657
315/35R20 28.54 12.52 10 89.66105433
DIA DIFF: 0.24
CIR DIFF: 0.00840925
CIR DIFF (%): 0.84%
NITTO NT05 (summer/track tire)
255/45R20 29.06 10.08 7.2 91.29468251
DIA DIFF: #VALUE!
CIR DIFF: #VALUE!
UTQG (200)
275/40R20 28.62 10.79 7.2 89.91238175
315/35R20 28.62 12.4 7.2 89.91238175
DIA DIFF: 0.00
CIR DIFF: 0
CIR DIFF (%): 0.00%
http://atturo.com/pdf/Atturo-AZ800-Sizes-Specs.pdf
ATTURO
255/45R20 29.1 10 11.2 91.42034622
DIA DIFF: #VALUE!
CIR DIFF: #VALUE!
UTQG (420)
275/40R20 28.7 10.9 11.3 90.16370916
315/35R20 28.7 12.5 11.3 90.16370916
note: approved rim width 10.5-11.5
DIA DIFF: 0.00
CIR DIFF: 0
CIR DIFF (%): 0.00%
Can't find official DILENTE website??? …only tire vendors??? Anybody have an official URL to confirm DL4000 specs below?
DILENTE DL4000
255/45R20 **NOT AVAIL IN SIZE** #VALUE!
DIA DIFF: #VALUE!
CIR DIFF: #VALUE!
UTQG (580)
Damn GYs seperated...found a new tire for us to use!!!
Delinte Tires
275/40R20 29 11.4 ? 91.10618695
315/35R20 29 13 ? 91.10618695
DIA DIFF: 0.00
CIR DIFF: 0
CIR DIFF (%): 0.00%
http://www.conti-online.com/generato...tasheet_en.pdf
Continental Extreme Contact DWS (all season)
255/45R20 29 10 10 91.10618695
DIA DIFF: #VALUE!
CIR DIFF: #VALUE!
UTQG (540)
275/40R20 28.7 10.9 10 90.16370916
315/35R20 28.7 12.6 10 90.16370916
DIA DIFF: 0.00
CIR DIFF: 0
CIR DIFF (%): 0.00%
http://www.vredestein.com/car-tyres/search/size
VREDs (Ultrac SUV Sessenta model??)
DIA DIFF: #VALUE!
CIR DIFF: #VALUE!
UTQG (280)
275/40R20 ? ? ? #VALUE!
315/35R20 ? ? ? #VALUE!
DIA DIFF: #VALUE!
CIR DIFF: #VALUE!
http://www.goodyear.com/en-US/tires/eagle-rsa-emt
GY Eagle RSA EMT (all season)
255/45R20 29.1 10 11 91.42034622
285/40R20 29 11.4 12 91.10618695
DIA DIFF: 0.10
CIR DIFF: 0.003448276
CIR DIFF (%): 0.34%
UTQG (260)
http://www.nittotire.com/tire/invo#size
NITTO INVO's (street tire)
255/45R20 29.02 10.12 10.0 91.16901881
DIA DIFF: #VALUE!
CIR DIFF: #VALUE!
UTQG (260)
BIGGER SIZES Diameter Width Tread CIR
275/40R20 28.62 10.94 10.0 89.91238175
315/35R20 28.62 12.40 10.0 89.91238175
DIA DIFF: 0.00
CIR DIFF: 0
CIR DIFF (%): 0.00%
http://www.bridgestonetire.com/tire/dueler-hp-sport (show all sizes link)
Bridgestones Dueler H/P Sport (Summer Tire)
255/45R20 29.1 ? 11 91.42034622
DIA DIFF: #VALUE!
CIR DIFF: #VALUE!
UTQG (300)
275/40R20 Y speed 28.7 ? 11 90.16370916
315/35R20 Y speed 28.7 ? 12 90.16370916
DIA DIFF: 0.00
CIR DIFF: 0
CIR DIFF (%): 0.00%
2010 BLACK Jeep SRT/8/
All Option Groups | Mopar CAI | JET 180 Tstat | Trinity | Johan Toon | BT Catch Can | BT Underhood Kit and TB cover | R1 D/S + StopTech pads | Nitto Motivo 275/315
srt8gofast is offline
The Following User Says Thank You to srt8gofast For This Useful Post:
Mikla (09-08-2012)
post #2 of 24 (permalink) Old 09-05-2012, 05:06 PM
rickrad's Avatar
Nice job compiling the specs on the various tires for stock sizes as well as the 275/40, 315/35 combo many end up going with. I currently have the Nitto 420s. No issues with t-case with over 20k miles on the tires. I want the Motivos before winter as the 420s are not good at all in snow and tread getting low by then. Motivos have more of a difference in diameter, almost a quarter inch. The biggest problem as I see it, is there is no traceable source for the often quoted allowable 3% value between fronts and rears. That number allows for quite a difference in circumference. Searching the chat sessions I found an exchange(I posted it in my thread) with an SRT engineer and a couple of forum members that did not lend any support that this is a valid acceptable tolerance. So we really do not know how much difference is acceptable before having possible transfer case problems.
rickrad is offline
post #3 of 24 (permalink) Old 09-05-2012, 07:32 PM Thread Starter
srt8gofast's Avatar
rickrad,
Thanks. I did see your post and noted the absence of any official position made by Chrysler/Jeep. Today I sent a question off to the guys at http://www.wkjeeps.com/wk_srt8.htm to see if they have anything semi-official on the topic. I expect not. I didn't see anything in the WK TSBs they have on that site either. Looking at the Motivos compared to your 420s, the diameter percentages (delta of 0.0018 between the models) for front/back are very close to each other and in theory you shouldn't have issue or concern; and still under 1% front/back diameter difference. It would be good to hear something official though to be sure.
Did I see in your thread that you had side tire wear issues? (can't recall if that was you or not) If so, did you make the recommended camber adjustments? Did the adjustment work? If not you, I apologize, I must have read a thousand posts today in this forum topic alone.
The big thing that I'd like to understand is when going to the larger 275/40R20-315/35R20 size pairings, do people have issues with the additional width not "fitting" or rubbing in any way? (OE suspension)
Also, has ANYBODY heard of T-case issues in going to the larger sizes assuming they maintain the properly paired size, same tread front/back, etc. (275/40R20 & 315/35R20)
And has anybody experienced issues with the dealership when showing up with non-OE sizes?
I'm still well within my 5yr/100K powertrain warranty and I don't want to put myself into a corner I can't get out of if I do have a problem. I'm really leaning toward the 420s only because of the OE size availability, but it would be nice to feel confident with the larger sizes and model varieties as well.
My need: daily-driver for local commutes; not a track guy; want the tire to grab when I stand on it; would like reasonable tire life; no more stupid tire separation! Yes, I know this is a lot to ask for.
Thanks for any additional data others can provide!! Also, any feedback on:
Question: any reason to be concerned with buying tires outside of the tire manufacture's rim width specs? [rear rims being 10 inches and some tires spec'd min rim @ 10.5, data below...]
post #4 of 24 (permalink) Old 09-05-2012, 07:44 PM
rickrad's Avatar
From everything I have read, no issues with rubbing on the stock jeep. I think a few have had minor issues on lowered ones. I too asked the question about rim size given the width of the 315/35 tires on the rear. Many have used those on the 10 inch rims so yes it will work. I think the Contis may be the widest or the Atturos. Whether it looks weird or compromises handling/stability I cant answer but would like to know myself.
rickrad is offline
The Following User Says Thank You to rickrad For This Useful Post:
srt8gofast (09-05-2012)
post #5 of 24 (permalink) Old 09-05-2012, 07:54 PM Thread Starter
srt8gofast's Avatar
Originally Posted by rickrad View Post
...I want the Motivos before winter as the 420s are not good at all in snow and tread getting low by then. Motivos have more of a difference in diameter, almost a quarter inch...
Are there any happy Motivo customers out there? Any feedback or gory details from them?
post #6 of 24 (permalink) Old 09-05-2012, 08:46 PM
rickrad's Avatar
Pretty new tire...The reviews I have read have been very good. I may be the first here to have them on an SRT8 Jeep. There are things I dont like about the DWS, Toyos, and the Atturos I would not even consider. Not going the ultra cheap route here. Still want to be sure that its not too big a difference on the Motivos. I calculated revs per mile and its a difference of 6 between front and rear tires.
rickrad is offline
post #7 of 24 (permalink) Old 09-11-2012, 09:03 PM
Can you update the list to include the Bridgestone 275/315 combo? I have been rocking them for about a year and love them. I suspect rubbing on stock suspension components, but upgraded to the Bwoody end links. I actually had to put the stock end link back on the drivers side, and the Bwoody on the passenger side. ( I have a thread about this).
The Bridgestones friggin' rock on wet roads. I was cruising back from MI to VA a few weeks back and had torrential downpours from DC to Richmond. It was by far the heaviest rains I have ever driven the Jeep in. I was cruising at 80 MPH hitting pools of water with reckless abandon, and only a slight wheel jerk in the deepest of pooling spots.
Not to mention, these are runflats with a decent ride. Obviously, not as good of a ride as a non-runflat tire, but WAY better than the crapyears.
Downside: $$$$$
MadeInDetroit is offline
post #8 of 24 (permalink) Old 09-13-2012, 01:39 PM Thread Starter
srt8gofast's Avatar
Thanks for the input! What specific Bridgestone model are referring to? Will do... I'll update my numbers and get them into the original post soon. Thanks!
OTHERS: what other size combos other than stock sizes and 275/315 combo have folks used without issue. I noted a couple threads with some using a combo with higher sidewall values with the hopes to "protect" the wheels a bit more. I'd like to confirm these sizes are indeed available across the different brands. Thanks for your input... I'll keep the original post up to date with all the data in single location.
post #9 of 24 (permalink) Old 09-13-2012, 05:52 PM
rickrad's Avatar
I think the larger aspect ratios some are going with are more for looks...fill out the wheel well a bit. Doubt its going to offer anymore protection from wheel rake. I do know the Toyos are one brand that has this available...45 fronts 40 rears and maybe also 50 and 45. I don't think in general most brands offer these sizes that will work with our jeeps.
rickrad is offline
post #10 of 24 (permalink) Old 09-13-2012, 09:12 PM
Bridgestone Dueler H/P Sport RFT
UTQG: 300 AA
Speed Rating:110Y
Load Range: XL
Data logging???? stratssrt8 WK1 Tuning/CMR/Dyno/DataLogging/Gauges 1 10-30-2010 02:32 AM
Tire Replacement Options?? Mango WK1 Wheels & Tires Discussion 55 02-11-2009 06:13 PM
Traction Control Issue After Tire Replacement Zeus WK1 Troubleshooting / Problems Discussion / Dealer Service 13 09-04-2008 08:37 PM
Best replacement tire for GC SRT8 (poll) Please akatheproducer WK1 SRT8 General Discussion 46 02-18-2008 09:06 PM
Notice re tire replacement program RedGTS WK1 SRT8 General Discussion 5 11-10-2006 03:03 PM
