Bridgestone Duellers 275/315 - odd wear - Cherokee SRT8 Forum
Sponsored by:Discount Tire
post #1 of 9 (permalink) Old 07-18-2012, 11:29 AM Thread Starter
I installed 275/315 Bridgestone Duellers on the Jeep 10,000 miles ago and I love them so far. However, I've developed an odd wear pattern on the outsides. The outer tread blocks have a slight "sawtooth" wear to them if you're looking at the face of the wheel. At certain speeds it makes a noise like a wheel bearing slowly going out.
I took the Jeep in to have the alignment checked and it was in-spec. They tweaked one side by about .05 degrees to get them absolutely perfect.
Is anyone else having this problem?
'08 Jeep SRT8 - Predator tune, Mopar CAI & Exhaust, R1 rotors, catch can, 275/315 Duellers, BWoody end links
'86 BMW E30 w/ NA built '95 M3 motor
Beej is offline
post #2 of 9 (permalink) Old 07-18-2012, 04:01 PM
I have maybe 3000km on mine all good so far . Quiet and ride smooth .
Canadian SRT8 is offline
post #3 of 9 (permalink) Old 07-18-2012, 11:54 PM
WIPLASH's Avatar
possibly under inflated?
I'm gettting frustrated
with modding
WIPLASH is offline
post #4 of 9 (permalink) Old 07-19-2012, 11:18 AM Thread Starter
If anything, I probably over-inflate them. I usually run about 38 psi.
Beej is offline
post #5 of 9 (permalink) Old 11-20-2012, 03:07 PM Thread Starter
Just an update:
-8,000 miles ago I took it to Firestone to have the alignment checked. It was nearly spot-on. They made slight adjustments to one wheel.
-5,000 miles ago the noise still persisted, and I had the dealer rotate the wheels and the odd wear balanced out but still made noise.
-Today the odd wear is evident again and it is still making noise!
Anyone else having a similar experience?
Beej is offline
post #6 of 9 (permalink) Old 11-20-2012, 03:15 PM
Marathon Man
TonySRT8's Avatar
Sorry, I ran the dueller's for 4 summers and didn't have any wear issues. I had the runflat version, are yours runflats or the regular ones?
Beast has been sold.
'07 GCSRT8 Black, Daily Driver, 41K Miles, Loaded minus rear DVD
PB 11.17@118 with 1.57 60' uncorrected
Vortech, Snow Meth, Paramount Drivetrain, MHP TCM, Wavetrac, Stage 6 Fuel System, Borla S, QA1 Shocks, 5K HIDs, BWoody Springs, NT05's, R1 Brakes, Medic CF Hood, Stillens.
TonySRT8 is offline
post #7 of 9 (permalink) Old 11-20-2012, 03:19 PM Thread Starter
I have the regular version.
Beej is offline
post #8 of 9 (permalink) Old 11-20-2012, 03:37 PM Thread Starter
Maybe this helps. They said the machine isn't 100% accurate and they use it to get it close and then do it manually.
Beej is offline
post #9 of 9 (permalink) Old 11-20-2012, 03:44 PM
jim383's Avatar
The toe should be -.125 both sides and the stock camber is -.75 but like i said in pm i set mine at -.125 to elemanate the inner rib tire wear. I have heard that saw tooth pattern can be caused by hi speed cornering or to much toe either way in or out.
http://www.barsomtire.com/alignment/index.html
2015 JEEP CHEROKEE LIMITED
jim383 is offline
Brake Pad Wear MichaelSRT8 WK1 Brake Discussion 1 12-17-2010 02:34 PM
Bridgestone duellers rub? rocket06 WK1 Wheels & Tires Discussion 9 01-31-2009 08:51 AM
Duellers PICS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!! ajharman Pics & Video Showoff Section 39 08-17-2008 08:57 PM
Duellers as I type... ajharman Pics & Video Showoff Section 8 08-13-2008 01:09 PM
My Bridgestone duellers rubbin' Bwoody Links ?!? Razorecko WK1 SRT8 General Discussion 35 07-18-2008 03:16 PM
