Just built and installed my 426... now I have traction problems...... lets talk - Cherokee SRT8 Forum
Track Talk Share your track tales and timeslips here. Check out the Cherokee SRT8 Timeslip Database.
post #1 of 43 (permalink) Old 01-24-2013, 01:43 PM Thread Starter
Hi guys,
I just completed a 426 build for my jeep. It's a mild setup on the spec sheet but is causing some significant traction issues on the street. It spins all four from a low speed roll and completely fries them from a dig. It seems to do better leaving the traction control on which is the opposite of what I used to do with the little boy cam only setup. When the jeep spins the tires in first it usually short shifts into second and may even throw the p700 code if you leave the traction control off. It has been pretty cool lately and I know it will hook better when the weather is good but I wanted some input from others. This is the first time I've "confused" the tcm by spinning the wheels. I'm sure it would do much better with some drag radials on the rear but I really just wanted to hear what other jeeps with massive torque are doing for traction and how the tcm and transmissions are working with this hp level keeping the drivetrain mostly stock.
On a side note, I'm also debating on either installing blue top solenoids or getting the mopar tcm first. I want to keep the car "stock like" when easing around in it and am a bit worried about excessively harse downshifts with the blue tops.
MadTunes Racing is offline
post #2 of 43 (permalink) Old 01-24-2013, 01:50 PM
WIPLASH's Avatar
Get the BB stageII valve body instead of the Bluetops.
I'm gettting frustrated
with modding
WIPLASH is offline
post #3 of 43 (permalink) Old 01-24-2013, 01:50 PM
Premium Reformed Member
tugboatchad's Avatar
I've heard that Paramounts TCM and valve body play nice together on a stock trans and it won't shift until it hits its shift point. Might be worth contacting Bill. His TCM with my D1 Procharger still caused short shifting but it was like at 5900 or better rather than 4000 ish. As for the massive 426 torque you are experiencing I can't comment on that from lack of stroker experience.
Sent from AutoGuide.com App
tugboatchad is offline
post #4 of 43 (permalink) Old 01-24-2013, 01:52 PM
Cotton Picker's Avatar
Congrats on the new 426 ! Now order a SHR transmission and call it a day. Demon has a smoking group buy on them now.
CP
Cotton Picker is offline
The Following User Says Thank You to Cotton Picker For This Useful Post:
AussieSRT@TTC (01-29-2013)
post #5 of 43 (permalink) Old 01-24-2013, 02:01 PM
bcm0018's Avatar
If your on a stock trans get blue tops or preferably a BB vavle body. I say the VB cause if you need a new trans he will subtract the initial cost off the new trans. The jeeps tend to short shift into second with lots of tire spin, its pretty common. Also mine roasts the tires on the street as well. If you have a mild build you may not need a TCM. The TCM is used to raise shiftpoints and if you have a mild build you may not need the extra rpm
09 SRT8GC HHP built stroker 604/555 - 10.753 PB
bcm0018 is offline
post #6 of 43 (permalink) Old 01-24-2013, 02:05 PM Thread Starter
I'll probably eventually upgrade the entire trans but I'm not planning that for a while if I can help it. Doesn't the bb valve body have blue tops in it? I'm probably going to pass on the valve body for now as I'd rather spend that money once if I end up needing the entire trans done. How harsh is the downshift when just easing along and coming to a stop with blue tops installed? Will it tick off a wife?
Thanks for the replys.
Oh and tug: I'm running nitto 420s. What tires are you running and how does it hook in the summer from a dig on the street?
post #7 of 43 (permalink) Old 01-24-2013, 02:06 PM
Re: Just built and installed my 426... now I have traction problems...... lets talk
First congrats on the new motor & get used to the lack of traction now, hehe.
Second this ^^^ Plus if you ever do decide to get of of the Paramount TCM's in the future everything will play excellent together.
J&D's SRT's is offline
post #8 of 43 (permalink) Old 01-24-2013, 02:09 PM Thread Starter
good to know on the valve body credit ... Hmm Any comments on down shifting off throttle, regular driving? with the blue tops installed/ or the vb installed
post #9 of 43 (permalink) Old 01-24-2013, 02:16 PM
In the summer I was on a bad OEM 6.1L (torn ring land), I was pissed and needed a relief so I left my buddies Harley shop and went home to get the Jeep to blow off some steam and return to the shop. I laid 100'+ of rubber in the alley on new Crapyear's in about 88* of sunny weather on blacktop, in 2nd gear! Lol!
The Following User Says Thank You to tugboatchad For This Useful Post:
Regency (01-24-2013)
post #10 of 43 (permalink) Old 01-24-2013, 02:21 PM
DemonPerformance's Avatar
Do you have an LSD btw? Most of the guys that responded to this thread have LSD's in the rear...that also helps with the traction issues...right now if you don't then you're peg legged so that doesn't help you much.
Skip Demon Performance
1-888-312-3666
DemonPerformance is offline
The Following User Says Thank You to DemonPerformance For This Useful Post:
viking757 (01-24-2013)
Lets talk Supercharger.. RECDOG WK2 SRT8 Engine Performance/Superchargers/Turbos/Nitrous 16 12-13-2011 11:36 AM
Lets Talk Nitrous...... 1INSANESRT8 WK1 Engine Performance/Superchargers/Turbos/Nitrous 26 09-15-2011 12:08 PM
Lets talk cams!!!!! BLOWN HEMI WK1 Engine Performance/Superchargers/Turbos/Nitrous 0 02-23-2011 03:56 PM
Lets talk about girls. kokanee13 Off-Topic Discussion 29 06-26-2009 01:03 PM
Lets talk about the fix to the Eibachs! OneBadJeep WK1 SRT8 General Discussion 11 10-29-2008 09:57 AM
