Procharger D1SC 10-11 Psi Dyno Results 600whp - Cherokee SRT8 Forum
post #1 of 69 (permalink) Old 01-27-2013, 08:45 PM Thread Starter
held 10-11 psi in 3rd gear.
AWD
93 octane only
any idea why power drops so much? belts slip, crank pulley slip?
mfedorov is offline
The Following User Says Thank You to mfedorov For This Useful Post:
Knuckles (01-27-2013)
post #2 of 69 (permalink) Old 01-27-2013, 08:48 PM
Rufjatt's Avatar
Send a message via Yahoo to Rufjatt
Wow nice man! i just posted this video in one of my thread, was trying to see who's jeep it was.
2010... 393 PWR/ F1D Procharger/ PWR cam/ Mean street heads/ Ported intake to 90mm TB/ ARH/ Torque Converter/ Cutouts/ BB trans/ F&R Wavetrac/ BC Coils/ BB TCM/ Challengerhood/ Borla S/ 180tstat/ BT goodies/ Vreds/ R1 breaks/ Passport 9500ci.......BLOODIED
Rufjatt is offline
post #3 of 69 (permalink) Old 01-27-2013, 08:55 PM
nyjoed's Avatar
Pretty nice man!!!
Sent from AutoGuide.com App
72mm FOGLIGHT TWIN TURBO
nyjoed is offline
post #4 of 69 (permalink) Old 01-27-2013, 08:56 PM
Marylandm3's Avatar
Niceee!!!!!!
Jason
2009 Silver Jeep Srt-8
DTP Racing
RIP RoKDoG
Marylandm3 is offline
post #5 of 69 (permalink) Old 01-27-2013, 09:25 PM
Knuckles's Avatar
AWD
93 octane only
SRT8 Jeep 600whp procharged PSI PROformance dyno - YouTube
Nice bro!!! One sick Jeep you got there!!! Yeah something looks off on it and it could be belt slippage.... You see any signs of black rubber in the engine bay? What pulley you running now on the blower? Still the 3.2" or did you go to a 3.0? What does your AFR and look like in this run?
Knuckles
Knuckles is offline
post #6 of 69 (permalink) Old 01-27-2013, 10:32 PM
If it held 10-11 psi, then I wouldn't think belt slip, unless you were expecting more boost.
If it is an 11lb pulley setup for your motor combo, then you're just making the boost you're supposed to. Get a graph with boost reference and see if it climbs and falls or if it climbs and holds steady.
With centri blowers you'll see more boost with rpm, but realistically your graph looks normal-ish. Your torque plateaus before your HP peaks, which implies that you were still making power with RPM gain. Should it make power past 5500 rpm? That depends on the rest of the setup, I have no idea what cam you're running.
If the boost fell off, that would explain it, but steady 10-11 psi doesn't mean that it fell off at 5500rpm. If you were making 11psi at 5500 and 10psi at 6000, that still doesn't explain the 50jp loss.
Jack_Toepfer is offline
HEMI TME (02-07-2013)
post #7 of 69 (permalink) Old 01-28-2013, 03:38 AM
kopbait's Avatar
Location: from: Bloomville,Ohio Stationed: Honolulu, Hawaii
nice run, graph does look funky and 600 seems low for 11 psi...
maybe your jeep is pulling timing do to kr*?
what is your fuel pressure sitting at?
if it where me i would invest in some methanol injection for some added safety
GC SRT8- vortech w/ my own air/air IC,SHR trans,3200 stall,ati flexplate,methanol injection, tial BOV, tooona tune and BLACKED THE **** OUT !!!!
kopbait is offline
post #8 of 69 (permalink) Old 01-28-2013, 08:34 AM
10JGCSRT8's Avatar
Nice numbers bro!!
- DEMON PERFORMANCE CUSTOM 88MM TURBO & 419
9.30 @ 150!-
Brian
2014 Ford Raptor SCrew
10JGCSRT8 is offline
post #9 of 69 (permalink) Old 01-28-2013, 08:35 AM
DemonPerformance's Avatar
Hey Max, earlier you said you were making about 12-13 psi on the street right?
Skip Demon Performance
1-888-312-3666
DemonPerformance is offline
post #10 of 69 (permalink) Old 01-28-2013, 08:42 AM Thread Starter
Yes, about 12PSI on non-coated pulley and regular NAPA belt from what I could tell. But those were street runs and it was much warmer if that makes a difference.
I wonder if it's crank pulley slipping...
mfedorov is offline
Procharger install complete / Dyno results! jeffstar WK1 Engine Performance/Superchargers/Turbos/Nitrous 25 01-02-2017 07:11 PM
Some Procharger D1SC testing with BIG RED Valve!!! Knuckles WK1 Engine Performance/Superchargers/Turbos/Nitrous 82 01-24-2013 12:25 PM
Procharger D1SC + K&N Filter Fitment Issues autenb WK1 Engine Performance/Superchargers/Turbos/Nitrous 13 10-03-2012 02:00 PM
