Procharger D1SC 10-11 Psi Dyno Results 600whp - Page 2 - Cherokee SRT8 Forum
post #11 of 69 (permalink) Old 01-28-2013, 09:17 AM
Premium Reformed Member
tugboatchad's Avatar
You don't want that crank pulley slipping, that's really bad. Nice video, I think I've watched it 5 times now!
Sent from AutoGuide.com App
tugboatchad is offline
post #12 of 69 (permalink) Old 01-28-2013, 09:35 AM Thread Starter
if you look carefully in the video you can see the belt rubber dust all over the SC bracket. no timing was pulled. also if you look at the video (part with the boost gauge) you can see boost start dropping toward the end of the pull.
in reality this was more of a base pull to see where we stand and also to make sure that the tune was good enough to continue messing with the car and testing things. on the first pull the car started to go a bit lean so luckily the tuner at PSI knew the system and was able to make few quick fueling adjustments to the Johan tune.
mfedorov is offline
The Following User Says Thank You to mfedorov For This Useful Post:
Knuckles (01-28-2013)
post #13 of 69 (permalink) Old 01-28-2013, 10:25 AM
Knuckles's Avatar
If the belt is slipping then I would pulley up to a 3.4 or even a 3.5 man....
Knuckles
Knuckles is offline
post #14 of 69 (permalink) Old 01-28-2013, 10:27 AM
Knuckles's Avatar
Yes, about 12PSI on non-coated pulley and regular NAPA belt from what I could tell. But those were street runs and it was much warmer if that makes a difference.
I wonder if it's crank pulley slipping...
Is your Crank pulley pinned??? Maybe the shop forgot to do it when they installed the 17% OD pulley..... No? Just a thought man...
Knuckles is offline
post #15 of 69 (permalink) Old 02-01-2013, 06:18 PM
Max, where are you with your boost progress? Any new developments?
post #16 of 69 (permalink) Old 02-01-2013, 08:49 PM Thread Starter
Some progress.
Got 3.0 non coated pulley and 108 3/4 Napa HD belt as well as a cobra adapter to move intake and use much bigger filter, possibly green filter used for GT-R setup.
Ah, and need to pin my crank pulley.
mfedorov is offline
post #17 of 69 (permalink) Old 02-01-2013, 09:16 PM
Some progress.
What?!! Pin before running again ASAP! Lol! Very interested in that cobra head you are rigging up. Keep up the good work, you are our boosted forged Procharger pioneer.
No pressure!
post #18 of 69 (permalink) Old 02-01-2013, 09:33 PM
Knuckles's Avatar
Some progress.
Pin that crank ASAP and do not get on the Jeep until you have it done or else you will damage that crank on your block.... Pin it first and then if you feel you need more Psi then go to the 3.0" pulley....
Knuckles is offline
tugboatchad (02-01-2013)
post #19 of 69 (permalink) Old 02-01-2013, 09:42 PM
Completely agree! A right angle air drill is what I used on mine and didn't have to remove a thing. I used a right angle Dewalt cordless drill on my buddies Magnacharger snail blazer install.
post #20 of 69 (permalink) Old 02-01-2013, 10:05 PM
Knuckles's Avatar
Yup!!! Could be worse bro.....
Knuckles is offline
Procharger install complete / Dyno results! jeffstar WK1 Engine Performance/Superchargers/Turbos/Nitrous 25 01-02-2017 07:11 PM
Some Procharger D1SC testing with BIG RED Valve!!! Knuckles WK1 Engine Performance/Superchargers/Turbos/Nitrous 82 01-24-2013 12:25 PM
Procharger D1SC + K&N Filter Fitment Issues autenb WK1 Engine Performance/Superchargers/Turbos/Nitrous 13 10-03-2012 02:00 PM
