Basic Fuel Pump Upgrade, Drop-In 255lph Pump Replacement Kit - Cherokee SRT8 Forum
post #1 of 26 (permalink) Old 01-17-2013, 02:21 PM Thread Starter
HighHorseman's Avatar
Thumbs up Basic Fuel Pump Upgrade, Drop-In 255lph Pump Replacement Kit
We've had several requests for this kit over the past month so we just added it to our huge inventory.
Jeep SRT-8 Factory Fuel Pump Upgrade Kit
This kit replaces the factory fuel pump with the larger 255lph pump for more fuel volume. It can be used in place of a boost-a-pump on blown Jeeps or for strokers and nitrous Jeeps requiring more fuel behind them as well.
HighHorseman is offline
post #2 of 26 (permalink) Old 01-17-2013, 07:02 PM
cliffjrm's Avatar
The 255 the only option? Wondering why not the larger 405 and if that's an upgrade option, which will work with this kit...
Thanks!
cliffjrm is offline
post #3 of 26 (permalink) Old 01-18-2013, 09:24 AM Thread Starter
I have the first kit for the shop due in here next week. I've actually avoided this kit for the past couple of years but with customers requesting it I'm going back and seeing what we can do with it. One of the supercharger manufacturers has used this kit for the past two years in place of the boost a pump. When I get the kit in here I'm going to take a look at it and see if we can get the larger Aeromotive 340lph and Walbro 405lph pumps to fit inplace of the GSS342 pump that the kits use now.
post #4 of 26 (permalink) Old 01-18-2013, 10:05 AM
The Wally 405 pump should fit HHP. It's barely bigger than the 255. Glad you guys are coming out with this. It's great for stroker guys too. There may need to be a little dremel work to get it to fit. Good luck HHP. Hope you guys can get the 405 in there!
2007 Jeep GCSRT Turbo 8.30@167
2015 Hellcat Charger 770rwhp no times yet
Harrison@Stage6 is offline
post #5 of 26 (permalink) Old 01-23-2013, 04:57 PM Thread Starter
Thanks Mr Balls.
post #6 of 26 (permalink) Old 01-24-2013, 05:44 PM
cliffjrm's Avatar
What whp does the 255 pump max out at and would this upgrade kit be enoght to support a 440 stroker? Thanks!
cliffjrm is offline
post #7 of 26 (permalink) Old 01-29-2013, 04:05 PM
Yes, it will support most 440 stroker builds... Been doing it for several years, but I am at its limit and needed to add a BAP to mine to support the power mine is making. Should be fine for up to 600 whp (on fuel,) but if you plan to make more than that, you should think about the larger pump. E85 and you need to go larger.
-Eric- '06 GCSRT8 Inferno Red- N/A Jeep record holder and original wheelie king!
, All Motor, 1.38 60'. Best 60' 1.358, Best MPH 130.94 on 7 cylinders!
No more games... big changes under way!
retro-king is offline
post #8 of 26 (permalink) Old 01-29-2013, 04:30 PM
Re: Basic Fuel Pump Upgrade, Drop-In 255lph Pump Replacement Kit
Just swap it out for a 400 Eric and you'll be good to go. I wouldn't mess with a BAP.
Sent from my SAMSUNG-SGH-I747 using AutoGuide.Com Free App
post #9 of 26 (permalink) Old 01-29-2013, 05:00 PM
That's the plan for what I am about to do, but the BAP has been on there for over a year. I use it more to keep the voltage consistent to the pump.
post #10 of 26 (permalink) Old 01-29-2013, 07:22 PM
Untouchable's Avatar
I have a triple pump fuel hat complete with pumps if anyone interested
8.90@157.59
Untouchable is offline
The Following User Says Thank You to Untouchable For This Useful Post:
tugboatchad (01-29-2013)
Tags
255lph, fuel, jeep, pump, replacement
Water Pump Replacement jvenetto WK1 Troubleshooting / Problems Discussion / Dealer Service 36 01-09-2014 08:00 PM
Jeep at the dealer for a water pump...they change the pump and remove my JET 180 Stat Rez90 WK1 Troubleshooting / Problems Discussion / Dealer Service 20 12-06-2011 11:58 PM
Walbro GSS340 255LPH In Tank Fuel Pump icebergSRT8 WK1 General Performance Discussion 8 02-14-2011 10:33 PM
WATER PUMP replacement lbaronio WK1 Troubleshooting / Problems Discussion / Dealer Service 6 01-16-2010 03:50 PM
