Some Procharger D1SC testing with BIG RED Valve!!! - Page 8 - Cherokee SRT8 Forum
post #71 of 83 (permalink) Old 01-21-2013, 09:40 AM
Premium Reformed Member
tugboatchad's Avatar
Originally Posted by mfedorov View Post
I was about to text you so thanks a lot for reaching out! Your support has been outstanding as usual! It's a consistent 12PSI and no vacuum leaks.
I think the heads are so free flowing that 3.2 pulley is not enough. I think this belt should even be good for 2.8 pulley, but 3.0 for sure.
PM me a price on that coated 3.2 please shipped to 98198? I'm thinking 12 psi would be good for break in on my new engine. Lol!
Skip, the new pulley you sent me is in the Jeep at Troy's, can you check invoices and tell me which one you sent? Thanks in advance if so!
tugboatchad is offline
post #72 of 83 (permalink) Old 01-21-2013, 09:57 AM
DemonPerformance's Avatar
Hey Chad, the pulley that came with your kit was a 3.6, the pulley that was sent later was a 3.5 pulley after doing some searching.
As far as the pulleys go, the 6 rib pulleys are $89 bucks+sh and the coating service is a $90 service to have done by Carbinite, you'll need to run HD belts with the coated pulleys though, either the Gates FleetRunner HD (if right size is avail) or a GoodYear Gatorback
Skip » Demon Performance
1-888-312-3666
DemonPerformance is online now
The Following User Says Thank You to DemonPerformance For This Useful Post:
tugboatchad (01-21-2013)
post #73 of 83 (permalink) Old 01-21-2013, 10:06 AM
Skip. I will take a 2.8, let's make it more interesting
mfedorov is offline
post #74 of 83 (permalink) Old 01-21-2013, 10:18 AM
Hey Max, shoot Chad a price for you 3.2 then, he may take that off your hands since he just asked about it...shoot him a number, at least it will offset the cost of the newer setup.
post #75 of 83 (permalink) Old 01-21-2013, 10:23 AM
Smallest pulley for a non offset is a 3" btw Max...
post #76 of 83 (permalink) Old 01-21-2013, 11:01 AM
Where do I get 2.8? Any ideas?
mfedorov is offline
post #77 of 83 (permalink) Old 01-21-2013, 11:22 AM
That 3.2 coated is just what I need to bring the beast out of a long overdue hibernation, coma....
post #78 of 83 (permalink) Old 01-24-2013, 09:09 AM
Put the beast on the AWD dynojet dyno last night. Got 602 whp at 10PSI. Another 5PSI would help
mfedorov is offline
post #79 of 83 (permalink) Old 01-24-2013, 09:37 AM
Were you using the coated 3.2" pulley on this? 602 HP off 10psi isn't too shabby!
Sent from AutoGuide.com App
post #80 of 83 (permalink) Old 01-24-2013, 09:49 AM
Chad, I was using 3.2 coated pulley. On street it does 12PSI, but on the dyno it wouldn't hold above 10PSI
mfedorov is offline
How to Properly adjust the boost bypass valve on a Procharger autenb WK1 Engine Performance/Superchargers/Turbos/Nitrous 53 08-19-2015 02:54 PM
My D1SC / Stock Internals Build autenb WK1 Engine Performance/Superchargers/Turbos/Nitrous 105 01-03-2015 02:00 AM
Procharger D1SC + K&N Filter Fitment Issues autenb WK1 Engine Performance/Superchargers/Turbos/Nitrous 13 10-03-2012 02:00 PM
The new Procharger system is now being advertised on Procharger website!!! Knuckles WK1 Engine Performance/Superchargers/Turbos/Nitrous 142 12-08-2011 08:14 PM
