Procharger and extreme cold - Page 2 - Cherokee SRT8 Forum
post #11 of 20 (permalink) Old 12-24-2012, 06:50 PM
hoseclamp's Avatar
Pro charger has kits in Alaska, they don't care of climate as long as you let it warm up. Do not do a heat blanket, uneven heat can expand one Section of the housing over another, including internals, and you will run into clearance issues. Just make sure you have fresh lube for the winter and let it idle. That's why I went pro charger too, vortech wouldn't back the winter climates, pro charger will.
Soldmt srt8, I have a d1sc kit for sale, r1 slotted/drilled cryo'd rotors and ceramic pads, and a snow performance stg III. Pm if interested.
'13 F450, '12 s550, '13 e550 soft top, '13 glk250 BT, '14 GL350 ordered, and a bunch of other stuff.
hoseclamp is offline
The Following 2 Users Say Thank You to hoseclamp For This Useful Post:
AROD (12-24-2012), Tim H Calgary (12-24-2012)
post #12 of 20 (permalink) Old 12-24-2012, 07:36 PM
AROD's Avatar
The heat pad was intended for the pans and reservoirs.. Ie - fluids. just to speed up the warming process. - suggested as I haven't seen one of these rigs with a conventional block heater before.
AROD is offline
post #13 of 20 (permalink) Old 12-24-2012, 07:55 PM Thread Starter
Tim H Calgary's Avatar
Cool. I am a little paranoid. Appreciate the info fellas
Tim H Calgary is offline
post #14 of 20 (permalink) Old 12-24-2012, 08:53 PM
hoseclamp's Avatar
I understood completely, absolutely, it's the tolerances being so tight, warm up the bottom half, will the assembly clear as it rotates. It may not.
post #15 of 20 (permalink) Old 12-24-2012, 08:54 PM
hoseclamp's Avatar
Also Tim which cam do you have, I want to slide one in without doing springs and rods.
post #16 of 20 (permalink) Old 12-24-2012, 08:57 PM
DemonPerformance's Avatar
Yea just let it warm up to operating temp before going nuts with it...it's only about 6 ounces of oil that needs to warm up too.
As far as his cam goes, he's got one of the PWR cams with the valvetrain components to go with it Mike. Let me know what you decide on doing and I'll send em up your way bud!
Skip » Demon Performance
1-888-312-3666
DemonPerformance is offline
post #17 of 20 (permalink) Old 12-24-2012, 09:56 PM Thread Starter
Hoseclamp here is my cam spec 217/223 555/555 114LSA 111ICL. I told Andy I was planning on going FI down the road so its a bit of a hybrid (FI plans were accelerated lol). Loved the sound and the power increase was very noticeable. As Skip said I also did springs, retainers and rods at the recommendation of him and Andy.
On unrelated note: Them some big halibut in your avatar
post #18 of 20 (permalink) Old 12-25-2012, 12:14 AM
LAFNGA5's Avatar
this thread needs more cow bell
10's Best Be Coming
LAFNGA5 is offline
The Following User Says Thank You to LAFNGA5 For This Useful Post:
Tim H Calgary (12-25-2012)
post #19 of 20 (permalink) Old 12-25-2012, 09:20 AM
hoseclamp's Avatar
lol!!! Guess what, i got a fever, and the only prescription, is more cow bell!!!
post #20 of 20 (permalink) Old 12-25-2012, 06:39 PM
HEMI TME's Avatar
We've had a couple 20 deg. days and I remote start it to warm up.
So far all good. I think this is where the Maggie has the advantage
to warm up quick.
2009 Modern Blue
SOLD
06 Flat Graphite wrap, 142,000 mile daily driver!
Forged 6.1, VREDS
ET.....10.61
mph..130.98
60ft..1.61
76mm CompTurbo
Special thanks to ebay
[/COLOR]DaToonA ain't Frikn around.....
HEMI TME is offline
The new Procharger system is now being advertised on Procharger website!!! Knuckles WK1 Engine Performance/Superchargers/Turbos/Nitrous 142 12-08-2011 08:14 PM
Extreme temperatures (hot/cold) scrapiron7 Off-Topic Discussion 8 08-25-2011 09:30 PM
Extreme Detail ajharman Pics & Video Showoff Section 8 03-17-2008 08:31 AM
Testing performance in extreme cold... skoobz2001 WK1 SRT8 General Discussion 13 01-30-2008 08:32 AM
