turning up boost and going to the track next month - Page 4 - Cherokee SRT8 Forum
post #31 of 140 (permalink) Old 12-06-2012, 06:56 PM
Untouchable's Avatar
How much lighter are the f10s
8.90@157.59
Untouchable is offline
post #32 of 140 (permalink) Old 12-06-2012, 07:17 PM
RIP Chuck G.
junior666's Avatar
24.8 pounds each, and you can ship 2 directly to weld craft to save some shipping cost.
junior666 is offline
post #33 of 140 (permalink) Old 12-06-2012, 08:21 PM
Has anybody done this yet Chris & how well do they hold up? Any balancing problems?
J&D's SRT's is offline
post #34 of 140 (permalink) Old 12-06-2012, 08:26 PM
RIP Chuck G.
junior666's Avatar
Not to my knowledge but I do know a few Corbett guy who have sent wheels to be
widened by weldcraft with no issues.
The Following User Says Thank You to junior666 For This Useful Post:
J&D's SRT's (12-06-2012)
post #35 of 140 (permalink) Old 12-07-2012, 07:09 AM
Muellge's Avatar
Thought about widening. Might just keep all four the same and pick a tire that will work. I know I get a little less width in the rear than if I had a true 10 inch rim, but with my luck I'd end up with slightly differing tire heights from front to rear and then whoopsiedoodle, the t/c is cooked.
Five Door League...
Muellge is offline
post #36 of 140 (permalink) Old 12-07-2012, 08:28 AM
SrtJake's Avatar
I run 18x9.5 all around with 305/45/18 nt05r rubber. Had to use a 3/16" spacer up front for caliper clearance. Used extended grade 8 studs and hubcentric spacer. This combo works well for me!!
Whipple Powered..10.90..125.04..1.49 60'
SrtJake is offline
post #37 of 140 (permalink) Old 12-08-2012, 11:09 AM Thread Starter
TTJames's Avatar
I located my turbo build sheet and found out that I have twin Garrett GTX30R turbos and from what I have found I think these are 57mm turbos. Does this sound correct and is this s good set up? From what I have read I would say yes but I would like your opinions. ty
by
, on Flickr
TTJames is offline
post #38 of 140 (permalink) Old 12-08-2012, 02:38 PM
How many cubes? Still a 6.1?
If your boost isn't falling off at redline and your IATs are manageable, then they are working just fine for you. Similar to what I have, though I don't know how well they will work for me yet.
Jack_Toepfer is offline
post #39 of 140 (permalink) Old 12-08-2012, 04:18 PM
LASRT's Avatar
Sounds about correct. Most kits here are 60 something mm
LASRT is offline
post #40 of 140 (permalink) Old 12-08-2012, 05:32 PM
Muellge's Avatar
seems like plent of boosty. Each one is rated for a little over 600 hp, so you should be good to go. Size and spool speed are relative, and not sure if trim type or ball bearing or other alternatives make a difference on that turbo. I know the ball bearing upgrade on the Precision is about $900 but you get what you pay for.
Muellge is offline
Supercharged SRT8s...Where did you tie in your boost gauge? Which vacuum/boost line jmrice WK1 Engine Performance/Superchargers/Turbos/Nitrous 27 06-22-2013 11:05 AM
Advice needed - booked for track day end of month Metomlin Track Talk 3 11-05-2012 05:38 PM
Octane boost for track day Beej WK1 Tuning/CMR/Dyno/DataLogging/Gauges 14 10-08-2012 09:02 PM
Any one going to SRT track day next month ltleo WK1 SRT8 General Discussion 2 05-25-2012 01:38 PM
TC turning it off while going down the track blackcar WK1 SRT8 General Discussion 5 05-23-2008 07:46 PM
